My Westinghouse TV will no longer power on. I was reading some of the solutions and it was recommended to replace all six caps in the power supply board. Where can I buy these caps?
  • 11,800 Answers
Http://www.talonix.com/shop/category.aspx?catid=128
Posted on Sep 04, 2010
I have a Westinghouse L2046NV Monitor and it does not come on. The monitor has gotten worse over time. I have removed the power board and found the six capacitors to the right are all bulging and 3 of them...
You may want to get the capacitor kit, but you need to get the board number used in your monitor version.
Eample of the kit:
http://cgi.ebay.com/Westinghouse-L2046NV-REPAIR-KIT-LCD-Monitor-DAC-19M005-/320608826408
I will not use RadioShack caps, since they are not low ESR type which is required for switching power supply, they will not last if you use generic electrolytic caps.
You should remove one cap at a time so you can see what the value is for each cap.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 18, 2011 | Westinghouse L2046NV Monitor
Went out during a storm, even though plugged into a surge protector. What should we look at replacing/repairing? Is it worth it? It's a 42-inch LCD HDTV by Westinghouse.
First place to look will be the main AC fuse and components in the power supply module.
Since you did not provide the model number of this TV, you can go here to see what the power supply looks like for your TV: WWW.SHOPJIMMY.COM
The fuse should be located near where the power cord is attached too.
Please post back what you see or not sure what you are looking at so we can guide you further.
Example of failed Westinghouse: http://s807.photobucket.com/albums/yy352/budm/WESTINGHOUSE/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series
Aug 01, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Hi i have a westinghouse Ltv 32w6 hd when i turn it on i get a blue light no sound and no picture. cantturn it off with on/off button or remote. have to unplug it to turn off blue light. help pls
It can be the main board is bad and not sending the signal to turn on the rest of the power supplies, or the power supply is bad and not supplying the correct voltages to the main board, so you need to inspect the two boards.
Boards for your TV: http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LTV32W6HD+
Please read my guide first.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 27, 2011 | Westinghouse LTV32W6HD 32 in. LCD...
The power supply for my westinghouse lcd tv isn't working. Tv shut down so I pulled off the back panel and removed the power supply. The light on the power supply no longer comes on when it is plugged...
You need to do some voltage checking, please read my guides first and post back what you ifnd, post the pictures will help.
Jan 11, 2011 | Westinghouse W33001 30 in. HD-Ready LCD...
WESTINGHOUSE TV 32 IN LCD TURNS ON FINE, SECONDS
Check for cold soder joint in the 24vdc power supply section, especially on C310.
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
The problem can also be the backlight inverter baord.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://s807.photobucket.com/home/budm/allalbums
Jul 06, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My LTV32w1 Westinghouse TV keeps shutting off while watching after about 5-10 min. It won't come back on unless I unplug, wait about 20 min, plug back in, and turn it on. Then again only 5-10 min and it's...
Ur tv power supply have dying leaking parts call capacitors.The board where the power a/c cord plug into it.That the power supply board.U know basic electronic's,have the tools and know basic soldering?Searches the power supply board for these dying leaking capacitors and replace them,ur tv will power up normal an last.These dying about to be dead are alway bulges up on tops or puff on it tops.These Capacitors must be replaced.Or tries websites like Shopjimy.com,Ebay.com to buy a whole refurbish power board for the replacement.
Jul 05, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Power light flashing tv won't turn on
Power supply board is dead.Replaced the power supply board,will get it stable and work again.The power supply board,that the board where the power a/c cord go into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 01, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Dead set
Im not sure if this will fix your tv, but mine was powering off intermittently. I found a defective
2200uf Capacitor on the power supply board. Take a look at the top of the capacitor cans,
mine was popped up an looked damaged.
Dec 13, 2008 | Westinghouse SK-19H210S Television
Westinghouse 32 in LCD TV
I have had this problem now for about six months with my Niko OPT-3211W. After replacing the Inverter card, VIT70002.00 as suggested nothing changed. I then read that it may be a couple of capacitors in the power supply, but I do not have the skills needed to replace them, nor do I want to pay to fix it. The solution is simple... turn on the TV and wait two to five minutes, then turn off the main power. I suggest using a power strip. Then turn the power back on in two to five seconds. The TV will come back on and it works great from then on. I thought that it was a freak thing, but it keeps working.
Jun 10, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
