Question about Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator
Noisy frig My Amana, bottom freezer model, makes an intermittent noise that sounds like a weed-eater. It seems to work okay. I recently cleaned underneath and behind it. This helped for a couple of weeks only. Thanks for your help.
  • 93 Answers
It could be that your cooling fan gets noisy at times and stops for a while you could try to put oil on the shaft behind the fan this will help when it does get noisy pull the fridge kisten to the motor if noisy replace it its not to expencive about 40.00 dollaresthanks from gilles
Posted on Mar 15, 2009
Unplugged frig overnite once I plugged back in made a gurgeling sound whenever I opened the door what would that be?
Usually that is caused by a bad defrost heater thermostat or defrost timer. Failure to automatically defrost is the cause of freezing up.
If you don't feel up to doing the work yourself you should have an appliance repair shop look at it.
The gurgling is caused by water in the catch pan under the fridge. When you defrosted it some of the water made it into the drip pan (and maybe overflowed onto the floor). The fan inside the compressor area under and behind the freezer may be splashing in the excess water in the drip pan. This by itself is not a real problem since it is designed to automatically evaporate the water drained during automatic defrosting, but the excess water and potential overflow onto the floor can become a problem.
Mar 10, 2017 | Danby DFF8802 Top Freezer Refrigerator
Amana ABB222DE is the overload/capacitor the same thing as the compressor relay? I just had the compressor relay replaced in amana bottom mount. Frig cools fine but every 2 days or so buzzing noise...
I have been doing refrigeration for over 30 years and I have never seen a compressor with a chip inside of it. Have you tried cleaning the condensor coils? I almost sounds like you have a weak start capacitor. Let me know if i can help you any futher.
Apr 24, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
My refrigerator sounds like someone is running a weed eater behind it. if i turn it off and then back on it stops. this refrigerator is probably 20 plus years old. is it dying?
Your refrigerator compressor is making such noise.The compressor supplies the cool air to the freezer and then freezer it goes to the refrigerator.The vibration is transfered to the plastic boards on the refrigerator and it makes the weed eater noise type.
The coil in the compressor has been worned out.You have to replace it.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 18, 2010 | Kenmore Refrigerators
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Cleaned behind and under the frig and now it won't work
Don't know if this a solution or not. We must have moved something or jarred something when we vacuumed inside the back. After we moved it out again, took the grill off the bottom in the front, cleaned it and put it back on, everthing seemed to work OK. We went to work that morning and when I got home in the afternoon, the freezer and fridge were both working fine.
Dec 14, 2009 | Amana Refrigerators
Unusual fan noise
sounds like you need a new fan motor or blade
Jun 03, 2008 | Amana ARB8057CSL Bottom Freezer...
Buzzing intermittent
most likely the compressor relay is the clicking noise but i think the problem is most likely the compressor is starting to go bad and is lcoking up. if the refig is under 5 yrs old it is most likely still in warranty by amana
Dec 09, 2007 | Amana ABB1927DE Bottom Freezer...
Freezer works fine...refrigerator section
Have you noticed more frost in the freezer than usual? It sounds like you may have moisture building up and freezing around evaporator fan. The fan blade hitting ice will cause the buzzing until it stops it completely or the evaporator clogs with frost and blocks airflow. If you have frost on food in freezer, check the door seals and make sure nothing is keeping doors from closing completely if you release them about 6" from cabinet.
Oct 07, 2007 | Amana ABB1927DE Bottom Freezer...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator Logo
280 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
