Question about Mitsubishi WS-65511 65" Rear Projection Television
Green light will not stop blinking
I removed the DM power board with the seven caps. This is all over the internet as a fix. They look perfect is this the issue?
  • tony61 May 12, 2008
    Is this the main solution for when the light never stops blinking? I have read posts abut the 4 other caps inside the DM unit. I found a new DM board 935c986002 for $55. I was going to give it a try.
I replaced the 7 caps on the DM power supply WS65511 tv. The green light still blinks continuously. Checked the install of the caps three times no luck. Checked the fuses on the same board no problem. What is the next step?
Posted on Jun 21, 2008
  • Mitsubishi Master
  • 8,617 Answers
Often the capacitors will show no visible sign of swelling. 90% of the time the blinking light symptom is caused by those capacitors
Posted on May 12, 2008
  • Sonny Berry
    Sonny Berry May 12, 2008
    The other DMs with the 4 capacitors are for different mitsubishi models such some have 4 your model is actually the DM power supply board that has the 7 capacitors and not the actual DM
Remove the LED bulb as it isnt really needed
Mitsubishi green blinking light of death
Hi Jim,
Green blinking light of death on Mitsubishi DLP TV means that the DM failed to booted up. I would advice you to replaced the 7 1000uf electrolytic capacitor on the DM board. Most of the time it fixed the symptoms. Please inquire at tvrepairworld.com if they have an available DM repair kit for V36 chassis (WD-57733 chassis).
Jdvillanueva
Jan 10, 2012 | Mitsubishi WD-57733 57" HDTV
Green blinking light on wd-62725
Test the caps on the power board. tell me if the led is bloinking a number of times.
Oct 24, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Green blinking timer light on my WD 62525 tv
That symptom is almost always caused by bad capacitors that are known to fail through ou the five circuits boards within the chassis. Usually the DM board and The Power Board caps fail which can cause the non stop blinking timer led. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which has the caps with repair instructions that will often repair that issue.
Oct 04, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Green blinking light following a power outage
I rebuild the DM power supply in these sets with about a 50% success rate. Sometimes changing the 7 1000uf caps on the small power supply in the DM will fix it, you'll also have to solder the small 8 pin ICs as well. Do this carefully as you do not want an accidental bridge. If this does not fix your problem, replace the DM-POWER board not the DM Assembly. It's about a 300 dollar difference. You'll need a mitsubishi authorized service center to order the part for you. Goodluck.
Jul 05, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Timer light just blinks. I removed buttons from
A continuously blinking green light is almost always caps on the dm board.If you have access to an esr meter check them that way and replace.
Nov 10, 2009 | Mitsubishi WS-48613 48" Rear Projection...
Blinking green light won't stop
on your particular set the caps are usually not bad the dm board has to be replaced. It's not a cheap repair.
Aug 19, 2009 | Mitsubishi WS-48513 48" Rear Projection...
Mitsu wd-52628 green flashing timer/power light
steady blinking is the DM failing to complete the boot sequence. Your more than likely needing the DM repair kit.
Jun 18, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mits 52525 blinking green light
Good Day;
If you only changed 4 caps,1000 ucfd 35v, it should be 5, if you did not remove the little plug in board, e prom, you may have damaged that. B-4/after changing caps what is the indicator light, green, doing?
Does light stop? Please rtn with more info.
Jun 13, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV Won't Power on Green Flashing Timer Light
The green power light is continually flashing and the tv will not turn on. I hit the reset button and nothing happened. I have exhausted all other troubleshooting methods. Please help, what should I do?
Feb 08, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi fix.....
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Jan 13, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
750 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
