Question about Sony VAIO VGN-N160G/W T2250Notebook
The screen isn't working...i plugged in a vga cable yesterday to use as a screen but it changed the settings a little bit. I went in and plugged the cable in today to change it back to the normal settings but now the screen went blank. When i start up, i can see the Vaio display and the Windows XP display but everything after that is blank
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 88 Answers
PRESS FUNCTION (FN KEY) AND KEEP IT PRESSED DOWN AND THEN PRESS USALLY F5, SHOULD HAVE A PICTURE OF A LITTLE SCREEN ON IT
Posted on Sep 04, 2010
Computer screen messed up after connecting to a Projector.
Sounds like your screen resolution has gotten changed. Plug your VGA cable in and reset it to 1024x768. Then with the laptop on remove the VGA cable. When you connect your laptop to other devices like that, make sure you are not setting the resolution to the same as the TV.
Jan 04, 2013 | Dell Inspiron 1501 Notebook
I plugged in a computer and changed the input to VGA and the TV went blank
It sounds like your tv is in sleep mode.
What are the settings for the computer? Make sure it is set for the vga output. If it is a laptop, this is usually done with a function (FN) key. On your settings screen you can set the resolution and which monitor you are using.
Sep 29, 2012 | Polaroid 2611-TLXB TV
I have a 24" aoc 2436Vh display and a new 15"
I purchased the AOC 2436Vh display yesterday. To get my MacBook Pro to work with it I purchased Apple's Mini DisplayPort to VGA Adapter. Since the monitor comes with the VGA cable, all you need is the adapter to plug it into your MacBook Pro. It works beautifully and set up is easy if you know your way around the Mac. Although the HDMI works perfectly with my PS3, I strongly recommend the Apple Mini DisplayPort to VGA adapter. I hope this helps.
Nov 11, 2010 | Computers & Internet
I want to connect to a pc (vga) but don't have instructions
First ensure your tv has a vga socket at the back. You will need a vga cable with 2 male ends. On the pc goto display properties by right clicking on the screen, goto settings and adjust the slider at the bottom of the window to 800 by 600 resolution and adjust the bit rating to 24 or 16 bit. Plug the cable both into the tv vga socket and the pc vga socket, and boot the pc. Make sure the tv's input is set to pc or vga and you should now have windows on your tv. Hope this helps
Oct 27, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
The screen isn't working...i plugged in a vga cable yesterday to use as a screen but it changed the settings a little bit. I went in and plugged the cable in today to change it back to the normal settings...
Try booting into safe mode (press F8 repeatedly while starting up computer). Once in safe mode, you should have display (probably at 800x600) and you can reset it to whatever and reboot to normal.
If your settings are incompatible with the monitor specs you get results like you are seeing.
Oct 27, 2017 | Sony VAIO VGN-N160G/W T2250Notebook
Ok i have a HP Compaq Presario CQ60 Notebook PC AMD Athlon Dual-Core QL-62 2.00GHz 64 bit. So yesterday 9/23/09 i plugged my laptop into charge shortly later my screen went black. I closed the lid opened...
this might be some problem with ur power settings for ur laptop...
Better change it to default in order to reset every power settings..
Go to control Panel,
Go to Power Options,
Now Select the power scheme as ALWAYS ON
Then apply it & click ok..
Its done..
This wud be simple power scheme problem that generally comes...
Hope this works u out...
Sep 24, 2009 | HP Computers & Internet
Green tint display
The monitor is faulty, not enough red. you can make changes in your display advance settings to try and reduce the yellow and blue to make the screen look a bit better. you might want to try a differant vga cable or check the pins in the plug that nun are bent
Aug 18, 2009 | Star Logic 17" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Dell 2300mp projector, colors bad
try reseating the vga cable. Try removing the cable, the green tint should disappear meaning that the color or lack of one of the primary colors blue/red/green were missing due to bad connection. or maybe you have a bad vga cable.
Feb 26, 2009 | Dell 2300MP Multimedia Projector
Trouble setting up VGA cable to watch movies from my computer on my TV?
First, make sure the VGA cable is plugged into the AV6 slot on the back of the TV.
You will have to go into your computer, and click Start --> Control Panel --> Appearances and Themes --> Display --> Settings and change the screen resolution to 800 x 600 first.
Then go into the program for your Graphics Card and change the screen resolution to 800 x 600 with a 60Hz Refresh Rate - sinc ethis will most likely be a change for you, your computer screen will seem to "flash" a bit - your eyes will adjust as you become used to this.
The other resolutions that work will be the following, but the 60 Hz refresh rate is the key:
Supported Display Resolution•Computer formats: 640 x 48060Hz, 800 x 600 60Hz, 1024 x768 60Hz, 1280 x 720 60Hz•
Feb 21, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Open Questions:
How do I fix my Toshiba laptop? Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 25, 2018 | Toshiba Computers & Internet
See all Sony VAIO VGN-N160G/W T2250Notebook Questions
Sony VAIO VGN-N160G/W T2250Notebook Logo
111 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
