Question about Konka Televison & Video
The screen says no data base - Konka Televison & Video
  • Konka Master
  • 11,800 Answers
The firmware is missing or corrupted.Since this is a standard tv it will be impossible to update it - the isn't one available and sending the tv to the manufacturer to fix it will cost way more than what the tv is worth. Junk it, it's dead.
Posted on Sep 05, 2010
My phone looses connection very often. it brings up a message saying your answering modem has been disconnected to please check your settings
Try the following, (may work)
To manually select the network operator to use for data connections
You can also manually select your network operator from Connection Setup's
settings screen. Connection Setup will then reconfigure your device's data
connections settings based on the operator that you selected.
1. On the Home screen, slide to the Settings tab and then tap All Settings.
2. On the Connections tab, tap Connection Setup.
3. Select the network Country and Operator you want to use, then tap OK.
Note If you choose a Country and/or Operator that is different from the installed SIM
card network operator, you may not be able to access network services.
4. When prompted to confirm whether you want to configure the data
connection settings based on the selected network, tap Yes.
Connection Setup configures the data connection settings.
5. After the Connection Setup completes the configuration, tap Restart.
May 03, 2011 | HTC HD2 Smartphone
I have a HP xb3000 notebook expansion base for my HP Pavilion dv9500 laptop. The problem is the laptop is having display issues (flickering screen, black screen, horizontal lines, etc). The expansion base...
as the posters said, you can move any working HDD or SSD
be it old PATA or new SATA cables, using and adaptor.
google that see 1million examples.
to any PC, and backup data.
i reading your manual online, remove the hdd, carrier.
as it tell you on page 5.7
it shows the OLD OLD PATA cable.
now most PC made have no such port now
so we buy a HDD enclosure, and it convertes, PATA to USB
and now you can plug it in to any PC mADe and use it.
#1 is old PATA, (parallel interface from dark ages of PC)#2 is power
Jun 12, 2017 | HP Xb3000 Notebook Expansion Base And...
Windows xp won't load. Displays computer brand logo. Logo goes off, then a blank screen.
This is often a hard drive based issue. I prefer to extract all DATA before continuing. Hook up the drive to a good computer and test the drive for malfunctions, after data recovery...
Nov 03, 2010 | Computers & Internet
Screen flashes white then comes back to normal
Your screen may be starting to slowly go bad. The data cable that connects the base part to the screen may be getting shorted out.
Oct 30, 2010 | HP Compaq Presario CQ50-130US Notebook
Print out dos based data under win XP
when your screen is displaying the dos data please press print screen key on your keyboard located near the scroll lock and home key
after that open microsoft paint and select paint from the edit menu
now crop this picture and print it using any software you like
Hope this solves your problem..ThnX
Jul 16, 2009 | Canon BJC 80 InkJet Printer
N72 data base corrupted
hi
u have just restored the phone to its factory settings
but if you do not mind losing data on the phone then you can try a hard reset
* Switch Off the device. * Press and Hold down the keys Green/Talk + 3 + *. * Switch On the device. * If everything goes well then you will see "Formatting" screen. Note: Please make sure that your device is fully charged before you proceed with formatting the device. If the battery goes down during this procedure, It may result in inconsistent state of your device.
hope this helped
cheers
pls rate the solution
Jun 28, 2009 | Nokia N72 Cellular Phone
Navionics gold sd card
Make sure that you go into MAP data and select this chart as the map info. You might just be using the internal base map right now.
Mitch
Aug 05, 2008 | Navionics Gold United States East...
Vb project
One of three ways:
1 make the table using vb creating a Bload screen.
2 using the visual data manager.
3 import a windows access or excel data base table.
Try the data wizard, easiest to use and U can program the program to manipulate the data in the tables.
May 29, 2008 | Computers & Internet
My labtop is on but the screen is black, it is an HP Pavilion dv600
Hold down the power button unit the machine is totally off then reboot. If the screen appears then and boots normally then change the power options and set the monitor power save to off or longer. If still no screen display then there are three other possibilities.
  1. At the base of the laptop screen there is a little hole with a switch inside that switch maybe be stuck down using a small flat blade screwdriver lift switch but be very careful
  2. The monitor data cable loose or fallen out there should be a access panel at the base of the screen to open and check this.
  3. The monitor is faulty and will need replacing
Thanks J
Jan 20, 2008 | Computers & Internet
Televison & Video Logo
51 people viewed this question
Top Konka Televison & Video Experts
Henry  Thomas
Henry Thomas
Computer Repairing
Computer Repairing
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
