Question about Technics SA-AX730 Receiver
Video Problem I have the next model up from the Technics SA-AX730, the SA-AX930 and for months now, when watching a movie, the video will intermittently switch to a blank, grey screen, and sometimes the video "rolls."  The audio remains, but no video.  If I hit the side of the receiver, the video will reappear.  This usually happens when I watch DVDs, and I cannot say if it does with VHS, since it has been a while since I have watched one.  All the cables are connected firmly.  Is this an internal problem?  Is it fixable?
  • 4,234 Answers
You most likely have either bad connections from the jacks to the main PC board or the video switching chip has an internal problem. Try resoldering all of the input jacks first and update this with your results.
Dan
Posted on May 12, 2008
What are the functions of the impedance button on the Technics SA-AX730
This allows you to select the correct amplifier output impedance for the particular speakers you have connected, Proper selection insures the best efficiency, response and prevents potential damage to speakers or the amplifier, Refer to page 17 of this manual:
http://audio.manualsonline.com/manuals/mfg/technics/technics_sa_saax730.html
Nov 20, 2014 | Technics Audio Players & Recorders
How should I connect my Technics SA-AX730 receiver to my Panasonic TC-40A420U that uses HDMI?
I assume the Panasonic is a TV. I have never heard of green audio outputs. Audio outputs should be red and white (for RCA plugs). There are adapters available that convert the yellow, red and white component outputs to HDMI. You can get them at GameStop (I bought one recently to connect a game system for my daughter). If you have a TV converter box from your cable or satellite provider you might be able to connect the audio out on the cable box to your Technics receiver and run a HDMI to the TV (be sure to turn off the TV's internal speakers through the TV's menu) for video.
Oct 15, 2014 | Technics SA-AX730 Receiver
Why is my centre speaker not working on my stereo setting on phono?
Records are binaural only. There are only two channels of information, left and right. There is no signal available for a center channel.
Aug 29, 2014 | Technics SA-AX730 Receiver
I have a panasonic home theater system and am trying to hook it up tp my technics reciever and its not working how do i do it
EVERY TIME I TUEN ON MY RECEIVER IT STAYS IN THE STANBY LIGHT AND IT DNT ALLOW ME TO LISTEN TO MUSIC
Oct 03, 2013 | Technics SA-AX730 Receiver
Fan is not working?
are u sure the fan is not working because on my ax730 the fan will only come on if im booting over half volume
Jul 27, 2010 | Technics SA-AX730 Receiver
I want to buy a Technics SA-DX940 reciever
ebay cheap as chips just keep your eye out for them there always about look for the sa-ax730 aswell more or less the same
Jul 23, 2010 | Technics SA-DX940
Power surge blew internal fuse
the guide have the fuse you need an looking for !
Jun 09, 2010 | Technics SA-AX730 Receiver
"OVERLOAD" message-Technics SA-AX730
You can't do it yourself only a good technician or repair center.I don't know the fix it cost.
Jul 07, 2008 | Technics SA-AX730 Receiver
SA-AX7
its the orange input on the back of the amp left side of it from the fan says coaxial either above the input or below im not 100% if that will work for you i would suggest you use rca cable.
Dec 20, 2007 | Technics SA-AX730 Receiver
Technics SA-AX730 Receiver PLAYS FINE AT A VERY LOW VOLUME.
Your speakers are way tp powerful you should only use speakers just over what the amp is rated at the most and check your impedance is not lower then 6 ohms and turn the bass to half way i am using 60 watt bookcase psb speakers and they work just fine and they pound no problem
Aug 24, 2007 | Technics SA-AX730 Receiver
Technics SA-AX730 Receiver Logo
59 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
