Question about Viking DDBB363 Bottom Freezer Refrigerator
Interior light stays on...light is hot..food directly beneath light is not cooling
  • 6,784 Answers
HI. There is a door switch that controls the interior lights. This switch is also connected to the fan motor circuits. The actual door switches will be the lone culprits in your case. They are not functioning at this moment. This switch fault will effect the cooling process and cause an abnormally high temperature inside the unit, due to no Evap fan action and interior light heat.
Simply replace the door switches to correct the issue.
Posted on Sep 04, 2010
My refrigerator is not cooling on the refrigerator side
There are so many things that can make your fresh food side not cool. Usually, it is a frosted up evaporator, which is blocking the air flow of cold from coming from the freezer to the fresh food section. This can be caused by a bad defrost timer, a bad defrost thermostat, a bad defrost heater, or a bad control board. It could be a week compressor that is only strong enough to cool the freezer, the evaporator fan may be bad, which blows the cold air from the freezer to the fresh food section, the damper control going from the freezer to the fresh food section, can be stuck in the closed position, or in rare cases, the light in the fresh food section can be staying on, or even the condenser fan that is responsible for keeping the compressor and condenser from getting to hot, may be bad. This is usually behind the bottom of the fridge. You might also have a dirty condenser, which is the coil that is usually underneath the fridge. So you are most likely going to have to call for service.
Jan 29, 2015 | Refrigerators
How do I fix my 16 bottle wine cooler? It has stopped cooling.
You don't indicate the brand or model but it sounds like it is a smart enough device that it provides a trouble indication via the flashing light which I haven't hear of before. Just confirm another device works properly from the receptacles you tried. Is the unit hot? some have overtemp protection - let it cool and try again.
Dec 28, 2014 | Furniture
LIGHTS STAY ON IN FRIDGE
LG had a problem with the control board going bad allowing the interior lights to stay on even when doors are closed. you need to get in touch with LG concerning repair MY UNDERSTANDING is there is a safety recall and it will be repaired for free. in the mean time unsrew the light bulbs so they dont melt down your liner...
Oct 03, 2012 | LG Refrigerators
Our new microwave heats the containers but not the food. Container is too hot to touch. Food "looks" hot, usually boiling - but food isn't even warm.
Check on the material the containers are made of. If they are not microwave friendly then they will cause problems.
Some materials are designed to "Roast" the contents by absorbing the energy.
Check with a Pyrex glass container and water. The glass should stay fairly cool.
Feb 01, 2011 | Whirlpool MH2175XS Microwave Oven
The coil directly beneath the ice container is burning hot. What should we do? Is this normal.
you mean the coil beneath the ice cube maker tray?? yes that gets hot every time the ice maker gets ready to eject the ice. it heats the metal tray a little so it melts a thin layer of ice to allow it to release from the tray easily.. now if it is staying hot all the time then the ice maker head, or if thats not available the entire ice maker can be replaced..
hope this helps,
best of luck,
ttfn
Oct 26, 2009 | Kenmore 57029 Side by Side Refrigerator
Unit will not cool
It's not meant to cool. It's just a drink mixer.
Sep 14, 2009 | Nostalgia Electrics Helman Group 60 Watts...
GE EVOLUTION Glass top. The hot surface(Glass top)
Individual burners, located directly under the cooktop glass, contain a temp sensor which lights up the hot surface lamp when they sense a hot condition. If the light stays on after all burners are cool, one of the sensors has shorted out. The sensors are an integral part of the burner, so the offending burner must be replaced to solve your constant on hot light.
Jul 01, 2009 | GE Kitchen Ranges
Bass will only output when car stereo is cranked
AMPS NEED AIR TO BREATH, AS THEY GET VERY HOT WHEN IN USE, DOES THIS AMP HAVE A COOLING FAN? IF SO CHECK TO SEE IF IT IS WORKING
Jun 19, 2009 | Alpine MRP-M1000 Car Audio Amplifier
The food side not geting cold I set up the control nothing
the small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
Mar 06, 2009 | Amana AFD2535DES French Door Refrigerator
I have a Jenn Air JCD2389GE Side by Side. My problem is that at random times (once, twice a week and sometimes once every two weeks) a puddle of water is on our tile floor just in front of the freezer...
You have a frozen defrost drain. whenever the unit goes into defrost, usually once a day the water instead of running down the drain is running out on the interior and then onto your floor.Fairly easy fix if your game?
  • unplug your refrig
  • remove all food from interior of freezer
  • remove shelving
  • remove 2 screws holding the rear cover in place these are usually painted white to blend witht he cover. btw this is the lower cover so you do not have to remove icemaker or dispenser bucket.
  • once cover is removed defrost all of the ice that you see with a hair dryer
  • once the ice is gone you will see a drain hole in the center beneath the cooling coil ou need to flush hot water thru this hole to clear any ice and sludge that may be in the line. ( I sometimes have to use a syringe or turkey baster filled with hot water to forcefully clear this line)
  • reassemble in reverse order
If you have any further questions or comments leave them here and I'll get back to you. Thanks Peyton
Feb 23, 2009 | Jenn-Air JCD2389G Side by Side...
Viking DDBB363 Bottom Freezer Refrigerator Logo
290 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
