Question about Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Trinitron color TV 36 inch
my television i need to press the power several times in order to turn it on even if i used the remote it used to take about 5 minutes to come on now nothing. The tv is about 5 years old now when i press the power button the red light at the front blinks about 6 times and nothing comes on. I am no sure if it is the fly back. please help me solve my problem thanks I too am having the same (or very similar problem). The set will work fine. and once in a while when I try via remote to turn it on, it clicks, the standby light flashes, and then it clicks again - having the standby light go back to solid. Turning iff the switch in the front of the set for some time seems to allow it to worki again for a while - thenm the problem wil surace again. The ste never powers itself off while in use. It just won't start from time to time.
    Genius:
  • 1,142 Answers
Can you give the model and the serial #
Posted on May 12, 2008
  • 1 more comment
  • Maanita Chadha
    Maanita Chadha May 12, 2008
    please try a hard rset..remove external power...keep power button pressed for 20 seconds..then plug in power cord back in..turn the tv on..check if it makes a difference
  • Maanita Chadha
    the blinks are diagnostic links.
    please check the link out
    http://www.techlore.com/article/15444/
    it might give you an idea as to what is causing the problem
  • Maanita Chadha
    please let me know what happened.
    if it helped please rate fixya else dont rate anything
    Genius:
  • 1,226 Answers
You should examine the input power of the TV. If you dare to open the back of the TV You should examine the by using the tester to test the continuity of the voltage input of the TV. i guess voltage regulator need to be tested.
Be careful high voltage inside the TV.
The best way is to contact the vendor of the TV or sony service center in your area.
may this help,
melnavz
Color setting for Sony XBR Trinitron 36" any settings
Hello
I thinks that you need to set its colour and other parameters, and posted this problem. If so there is adjustment at the first "Menu" option itself.
Press "Menu" button on your TVs remote control. You will see "Video" function as first selection on the screen. Use "Prog Up or Prog Down" keys to select and hilight the desired parameter. Use "Vol up or Vol down" keys to change it as your taste. That is all.
Normally the "Contrast should be more that 55% to 60% of its total value to get a clear and vivid picture. Colour and brightness are according your individual taste. Ok
If you wants to reset your TV to factory settings,
Turn on the TV.
Hold down "Reset" button on your remote handset and keep it pressed.
Press and release the power button on your TV front panel. the TV will turn itself off.
Release the "Reset key". Ok
Oct 26, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Picture color is distorted.
Try turning off power and let set cool completely. Then turn back on. Letting it cool complety re-arms the autmatic degaussing circuit. It may take several cycles to completly clear it up.
Jul 25, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Wega sony KV-36FS17
if you use your Sat remote control turn your tv on/off and there is an info button on the remote. press the tv button and then press the info button that should to it.
Oct 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony trinitron wega 36 inch
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
Aug 25, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
chances are the power supply in the television is wearing out....If it's an older one I would just as soon replace it....Not going to be cost effective to repair.
Mar 12, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
break the wega into tiny little pieces and it's easier to get out of your house!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Nov 11, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Trinitron 36" TV
Try a "hard reset"===unplug AC for a long time, like overnight.Let me know if there is any change.
Mar 07, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony 36' TV Volume Goes up on own/Stuck on Video 2
There's a setting in the menu. I think it's called "smart audio". It's supposed to adjust the volume automatically for commercials. But I don't think it works that well. Give that a try.
Jan 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony FD Trinitron WEGA KV-36HS510 36" TV Logo
66 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
