Question about Ovens
How do I light the pilot for the stove on a Garland GV286
  • Ovens Master
  • 2,333 Answers
Send the model number and how old is it? and i can look it up for you
Posted on Sep 04, 2010
  • Sal DeAngelo Sep 04, 2010
    if the pilot won't light put i light in the oven and with a paper clip clean out the holes where the gas comes in and if you have a little steel brush clean the pilot assy.these old stoves after the years clog up and need to be cleaned,and then just light it with a match or a clicker
How do you light the pilot light? if it doesn't have a pilot light how do you light it?
It could be an auto ignite stove. Check the manual. Some of the newer stoves have an electronic ignite to save on gas usage. A pilot light can burn as much as 3 gallons of gas a month.
Sep 04, 2013 | Ovens
I have a gas garland convection oven 10-15 years old. I see the red button to relight the pilot light but I can't find the pilot light itself. Can you tell me where I should be looking?
On the main bake burner is going to be a small pilot burner,got to lift off the oven floor to get to it. It is going to look something like this picture and is attached usually to the side of the main burner.To light the pilot,push that red button light the small pilot burner..hold in the red button for about 20 seconds..release the red button..pilot should be on..if goes off the thermocoupler is going to be in need of replacement
Aug 26, 2011 | Ovens
I have a commercial garland air deck gas oven model G56PB its not staying heated to the set temp. it will heat up to the set temp. then five minutes later the tempreture will drop and will not heat up to...
I have seen Garland's have issues with the pilot light. see if you can watch the cycle.It may takes several minutes. I have seen where the pilot actually lifts off the pilot assembly and go out and cause oven to fail. Turning off and on resets the failure and sometimes it will light. Start there and be patient.
May 11, 2017 | Garland Ovens
Once we light the pilot light it keeps turning off how do we keep it on
makeed sure that the pilot flame is properly direct on the thermocouple if thats ok then replace the thermocouple
Jun 02, 2010 | Garland GPD-60-2 Gas Double Oven
Don't know how to light the pilot light in the oven.It is a Garland ten burner two ovens. It is about 11 years old. Where is the pilot light and how do I light it.
Most commercial ovens have a manually lit pilot. There will be a button somewhere on the range that you will need to push in so gas will come out of the pilot assembly. While holding this button you will the light the pilot and will need to hold the button in for about a minute or two until the pilot stays on after you release the button. Look around the bottom panel,top panel or side panels(you may need to remove one) to find the button. they are usually red and may not look like a button. If you find the button and the pilot does not stay lit then the thermocouple might be bad. If you push the button and do not get any gas coming out of the pilot then there might be debris in the pilot assembly causing the gas not to come out. In that case you could try and tap the assembly or blow with compressed air to clear it. But in most cases you will need to remove the pilot assembly and use a really fine wire(like a metal tie-strap minus the coating) to clear the pilot orfice.
Sep 30, 2009 | Garland Ovens
When Oven turns off so does oven pilot
Hi there, it is possible of the pilot being too close, but usually does not have that effect, unless the pilot is too small. But if you replaced the pilot, it should be clean, so next I would look at the gas pressure, if this is too low, the flame won't have proper burning speed, and strength, and could get drawn out. The control valve may be of the type that has a regulator built in, you may need someone skilled at gas pressure measuring, to do this, your gas supplier, appliance professional, plumber, should be able to do this.
Let us know, and thank you.
Jan 29, 2009 | Garland GPD-60-2 Gas Double Oven
Pilot light
It was an electric ignition
Thank you
Nov 11, 2008 | Frigidaire FGB24S5A Gas Single Oven
Garland gv286
Unless you are a qualified and certified gas tecnician, I DO NOT recommend attempting this yourself. Sorry.
Feb 13, 2008 | Ovens
Pilot light
Maybe. Sometimes these units have small throttle valves near the pilot. If it adjusts...make sure it is about 1/2 inch long....you don't want it blowing out.
Dec 21, 2007 | Garland M-1 GR Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
