Question about SanDisk Sansa E280 MP3 Player
MY SANSA WONT TURN ON AND ITS NOT LOCKED
My sansa wont turn on and even i put the usb on its still not on and the hold button is all the way to the left!
This happened to me. have you tried removing the battery and pluggin it back in? you have to take off the back first, but it fixed mine
Posted on May 12, 2008
Sansa e260 wont turn on indefinately.
did you try the lock on, rec button and the on button as you plugged it into the usb?
May 12, 2009 | SanDisk Sansa e260 MP3 Player
Just says connected until the battery dies.
first off if you can turn the player off
try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
if that doesnt fix your problem try this...
if you can actually connect your sansa to the comp. and see it in explorer try this....
1 connect your sansa to comp via usb cable
2 right click start on windows desktop go to explore
3 scroll down to your sansa's drive rifght click it go to properties
4 go to tools tab and click "check now" under error checking will take awhile and will erase your memory on the sansa but it will probably work again
I hope my post was helpful let me know!!!!
Mar 14, 2009 | SanDisk Sansa e250 MP3 Player
MY SANSA HAS BEEN STUCK IN THE REFRESH DATABASE MODE AND WILL NOT TURN ON NOR OFF . IT WONT EVEN CHARGE EVEN THOUGH IT IS SHOWING A FULL BATTERY HELPPPPPPPPPPPPPP THANK YOU MRS.C.L.C.
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa e250 MP3 Player
Invalid image on sansa c250
hold the record button
plug in the usb jack
release the record button
this should put it in the right mode.
then you need to reinstall the correct firmware.
since sansa doesnt post this on their website, check out the anythingbutipod forums
Feb 18, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Even after resetting my e250, i still get the sandisk screen and it wont go to my menus after i restart it!
I Think You Should Try Starting Your Sansa In Recovey Mode ( Put The Sansa On Hold, Hold Down The Record Button While Turning The Sansa On) Then Plug It In To Your PC  Than Update Your Firmwire
Jan 31, 2008 | SanDisk Sansa e250 MP3 Player
My videos wont convert i need help!
you need to go under settings then click on usb modes then change the mode to msc. if you dont have the option of usb mode, then do the following:
1) Download the sansa firmware updater from the sandisk website (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe).
2) The program then turn off your sansa. (unplug it first).
3) Now move the hold button to the right and then hold down the center (round) button and then the power button.
4) Once your sansa is on, you can stop pressing the other buttons.
5) Now plug in your sansa.
6) Once this is done, your firmware updater should automatically start. If it doesn't, go to C:\programfiles\sandisk\.... and open it.
7) Select the most recent firmware and download it (it should automatically install).
8) Once this is done, disconnect your mp3 player (your firmware will then update).
9) Turn your mp3 player off.
10) Turn your mp3 player on.
11) go to Settings, USB Settings, and select MSC.
12) plug your MP3 player back into your computer and it should now recognize it.
Jan 09, 2008 | SanDisk Sansa e260 MP3 Player
IT wont turn on
tyr holding both the power button and the play button for 20seconds at the sametime
Dec 28, 2007 | SanDisk Sansa e260 MP3 Player
It froze
Sansa Clip Player has some problem. I tried 4 sansa clip players (I purchased at Best Buy for Thanksgiving), and none of them work. Dont even try to exchange them, just return them back.
Oct 24, 2007 | SanDisk Sansa Clip MP3 Player
Wont turn on
hi try charging it completly good luck
Apr 06, 2006 | Thomson Lyra PDP2840U MP3 Player
SanDisk Sansa E280 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
