The most common cause of this problem is a blown thermal fuse located on the blower housing. It is wired in series with the drive motor and turns off power to the motor if it is blown. The heating circuit is activated by the motor through a centrifugal switch. No motor running, therefore no heat.
Please indicate the make and exact model number of the dryer for further troubleshooting and repair advice. You don't
have to accept or reject
and rate this post
to add information
or post comments and follow-up questions should you need further assistance. Accepting a solution does not
stop you from communicating
with an expert. You may continue communicating with the expert as
long as you need assistance regarding the issue stated herein.
There are two parts on the blower housing; one is the thermal fuse and the other is either a cycling thermostat or a thermistor. The thermal fuse is the one on the left. You can bypass the thermal fuse, for troubleshooting purposes only, by taping the wires together or jumping a wire between them. The thermal fuse is indeed blown if the dryer starts and works with the thermal fuse bypassed. You should replace the two components on the blower housing if the thermal fuse is blown. Do not use the dryer with the thermal fuse bypassed due to figure hazards.
Please indicate the make and exact model number of the dryer should you need further assistance.
going to try and locate this fuse and replace. Thanks
