Question about Honda Black Max 3000 Psi Pressure Washer
What type of oil can i use - Honda Black Max 3000 Psi Pressure Washer
    President:
  • Honda Master
  • 1,388 Answers
The engine and the pump can use the same oil. SAE 30 non detergent oil. No need to pay more for speciality oil. Check oil often and look for any unusual signs such as milky or foamy oil in pump which would indicate water leaking past seals. Good luck.
Posted on Sep 04, 2010
What type of oil to use on a empisal d 270 and how put the oil
sewing machine oil ( from a supermarket or sewing shop)and just a few drops in the oil holes
Jun 20, 2016 | Sewing Machines
What type of oil does a 2002 jaguar x-type take? I was never given a manual.
The car takes 5w-30 semi synthetic oil. However, if you have never put synthetic oil in the car I would recommend using regular oil. I would also advise you check with your local jaguar dealer. The reason for this is if your car is not use to that kind of oil from day one it could cause seal leaks.
Jun 15, 2011 | 2002 Jaguar X-Type
What are the advantages of dry type over oil type transformers
The dry type doesn't leak oil. Oil types tend to be better insulated due to the impregnation of the windings with oil and may self-recover from an internal arc-over. The dry type has a smaller package due to no oil, but doesn't dissipate heat as well. The dry type tends to be cheaper in price. Hope this helps!
Nov 27, 2010 | Garden
What oil type to use when changing engine oil in a c50 boulevard?
Standard oil to use id SAE10W30 or SAE 10W40.
If you are still in doubt go to your local motorcycle dealer and ask the question as the normally are willing to tell you the oil type for your particular bike. Good enough?
May 21, 2010 | Motorcycles
I CANT HAVE THE FACTORY OIL TYPE IN MY COUNTRY, CAN I USE ANOTHER TYPE? AND WHAT IS THE TECHNICAL NAME ? MY COMPRESSOR IS GA30 ATLAS COPCO TYPE.
Most air compressors will run fine using 30 weight non detergent oil.
You could drop the manufacturer a e-mail.
Your compressor shouldnt use a lot of oil ... maybe you are in need of some repair? New rings or bearings or seals?
Feb 23, 2010 | Air Tools & Compressors
I have KYMCO S 200 and need to know what needs serviceing at 300 miles. What type of oil to use in engine and gearbox and what type filter if needed.
At 300 miles the only thing you might want to do is check the gearbox oil level and then lube and adjust the chain. Check with the dealer on the filter type. As to what type of oil, use 10w40 motor oil in the gear box. Don't use any synthetic oils, oil marked "EC", or oil with "special" additives. Stick with the major brands; Pennzoil, Quaker State, Mobil or Shell. If in a hot area like Texas or New Mexico go with 20w50.
Please rate my answer. Thanks!
Oct 27, 2009 | Kymco People S 200 Motorcycles
What type of oil I use
The Remington manual for model 111409-01 states: "This Pole Saw requires lubrication only to prevent rust on the guide bar and saw chain. The saw chain provided is pre-lubricated at the factory. With each use of the Pole Saw apply a small amount of lubricating oil directly to the saw chain (see Figure 8). The oil will distribute itself around the chain and guide bar groove during use?preventing rust. We recommend using SAE #30 motor oil for lubrication and rust prevention."
Aug 08, 2009 | Remington Polesaw Wizard
When changing the oil, how many quarts and what type of oil is used?
Most engines have it stamped in block ,beside oil fill hole example 3600ml..read on oil bottle should say 936 ml on quart bottle.Most suzukis over 750cc use 3.9 quarts of oil. DO NOT USE SYNTHETIC OILS..will cause clutch slippage ..Also look under seat,most bikes have a sticker with oil capacity,filter type,spark plug type
Jul 25, 2009 | 1998 Suzuki VZ 800 Marauder
Car won't start after oil change jaguar S type
Sounds like overfill oil pressure too high. Oil level is critical. Engine can be damaged.
See my Solution for oil change.
Jul 10, 2009 | 2001 Jaguar S-Type
Honda Black Max 3000 Psi Pressure Washer Logo
271 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
