Question about Vacuums
I have a problem with my model 6585-3 bissell upright powerforce bagless turbo with turbo brush vacuum The brush has quit spinning upon removal i noticed that one side of the brush was free to spin the other side that has the rectangular piece to help hold into place seems to be locked up and will not spin is it corroded or have i lost a piece that joins with it that allows it to spin freely belts are good and motor is turning brush will not budge
  • Vacuums Master
  • 1,534 Answers
Hair and dust build up under the end caps of the brush roll and cause friction. Replace the brush roll and belt. Be sure to clean the brush roll frequently after use.
Posted on Jun 26, 2017
reddevil6
  • 1673 Answers
SOURCE: BISSELL POWERFORCE BAGLESS UPRIGHT FOOT HOSE IS TORN
Take the top cover off, unscrew where the hose hooks onto the back, then you can get to it.
Posted on Feb 22, 2008
SOURCE: Bissell PowerForce Bagless Vacuum (6582)
You just have to twist hard the first time for some reason. If you hold the container with your right hand you actually have to twist the bottom half CLOCKWISE when viewed from above.
Posted on Mar 20, 2009
  • 8 Answers
SOURCE: Bissell PowerForce Bagless Upright
belt need to be replace
Posted on Jun 11, 2009
  • 19 Answers
SOURCE: how to open the inner and outer circular filters
Hello, please open this link and refer to pages 8 and 9 thank you
Let me know if this answers your question at
bsix@hotmail.com
http://www.bissell.com/images/UserGuides/6584_1008.pdf
Posted on Sep 14, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell powerforce bagless extremely loud.
It could be that the belt is worn. You can get replacement belts and the manual here:
Bissell PowerFrorce Belts and Manual
Posted on Nov 21, 2009
How to fix my Bissell vacuum it sounds like a really loud airplane about to take off its isn't that old .
It has a two year warranty so just return it. Sounds like a motor fault unless you have something caught in the drive belt or the brush roller. Tip it over and remove the base plate.
PowerForce® Helix™ Bagless Upright Vacuum' BISSELL®
https://www.bissell.com/powerforce-helix-bagless-upright-vacuum-1700Main Information. Product Title: Powerforce® Helix Bagless Upright Vacuum ' 1700. Model: 1700. Similar Models: 17003, 17004, 1700R, 1700U, 1700V. Quantity: 1. Warranty: 2 year limited. Register. Register Your BISSELL® Product ... Bissell 17003 Google Search
Mar 27, 2018 | Bissell Vacuums
Bissell powerforce manual
You should be able to download manual from this site.
There seem to be quite few filters to worry about.
Good luck.
Bissell User Guide Upright Bagless Vacuum Cleaner 6594 ManualsOnline com
Aug 10, 2014 | Bissell 6594 PowerForce Bagless Upright...
My Bissell powerforce bagless turbo roller will not stop spinning. What disengages the roller?
Hi Hiram. The brush will continue to spin when you're using the upholstery hose. You may want to set your height adjustment to the highest setting and leave the handle locked in the upright position.
Here's a quick link to downloading the User Guide if you need a copy:
http://www.bissell.com/user-guides/?cid=ccsocial
Apr 02, 2013 | Vacuums
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
Rotary brush is not spinning
That means that you need to replace the belt. Here is the belt you need and the manual:
Bissell PowerForce Belt and Manual
Jan 31, 2010 | Bissell 6594 PowerForce Bagless Upright...
I have a bissell powerforce bagless vacuum. My
Its probably is the roller brush causing the noise.
Nov 28, 2009 | Bissell 6594 PowerForce Bagless Upright...
My vacuum cleaner belt keeps burning up as soon as
CHECK ROLLER BRUSH PROBALLY HAS STRING WRAP UP AROUND THE ROLLER OR THE END BEARINGS ARE FROZEN IF SO SRAY WD40 IN BEARINGS TILL THEY FREE UP OR REPLACE ROLLER BRUSH
Nov 03, 2009 | Bissell 6594 PowerForce Bagless Upright...
Vac quit working
I have a Bissell powerforce bagless 12 ampsthe brush will not turn, motor is working not sure if brush is gone or I need a new belt it shows spots of burns like the brush is jamed
Feb 23, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
88 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
