Question about Dishwashers
My baumatic BDI631 has the instense wash and economy wash lights flashing. Have checked all drainage and it is fine - have also tried adding water and the pump pumps this out fine?
5 Suggested Answers
  • 4 Answers
SOURCE: Indesit IDL40 Slim line
Pull the machine out and tip it carefully to one side, if water comes out from the base then the problem is the union on the upper feed pipe. Remove the top inner dish rack and twist the star shaped nut clockwise gently! Make sure you have got as much of the water out as possible, stand the unit back up and turn put it into cycle.
Posted on Apr 24, 2008
SOURCE: ASKO D1986: Water pump running constantly
Solved by draining water from bottom pan.
Posted on Jan 19, 2009
  • 3230 Answers
SOURCE: Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Posted on May 06, 2009
  • 5 Answers
SOURCE: Miele G646 dishwasher keeps trying to pump out
Had a similar problem with an 846, but with the inlet outlet lamp flashing. the bottom tray had filled with watedr froma dodgy seal. I switched off and disconnected the electricity. Removed the bottom front cover below the door (2 screws behind the pretty kickboard which also had to come off). The bottom of the machien was a big puddle. I dried this out with paper twowel, put the machine back together and it ran fine. I am going to replace the pump seals now as the machine seems otherwise OK.
Good luck with yours. rupertvdpP
Posted on Aug 11, 2009
Testimonial: "true, bottom tray was wet fron small split in waste pipe taped it up and have ordered new one thanks for the info job well done"
Washing machine wont complete drainage at end of wash cycle
Look under the washer tub where the drain hose comes out and attaches to the pump. Your pump impeller is either clogged or worn out. Try removing the pump and checking from there.
Jan 07, 2008 | Fisher Paykel EcoSmart GWL15
I have a Baumatic BDI631 integrated dishwasher which has started making a strange noise when the water is coming out. It is washing fine but makes a buzzing noise when discharging the water which soun
It sounds like something's trapped in the pump touching the impeller. Drain the machine, isolate the electrics and see if you can access the pump, you may find a piece of debris or small article in the pipework.
Jan 05, 2015 | Baumatic Dishwashers
How can I stop my washing machine end indicator light coming on before cycle has finished?.
sound very much like you have a blocked pump or a drainage block. If your machine outlet is connected to a push on spike under the sink, remove it and check Its not blocked. If that is clear CAREFULLY remove the filter cap, Usually on the bottom righthand side of the Machine. I say carefully because if there is water in the Machine it will pour out and flood so do it a bit at a time till its empty. Check the filter it may be clogged up, if it is thats your problem if not it needs further investigating. time to call the repair man. By the way whilst you may have economy 7 I would never advise putting your machine on at night and going to bed if anything should go wrong you are not there to switch off, Ive seen some real nasty stuff over the years where machines have gone rogue unattended, it really isn't a good idea although Thousands would disagree.
Aug 03, 2014 | Tricity Bendix Washing Machines
All lights flashing
Try powering off the machine using the main power switch for at least 10 seconds, then power back after holding down the top solo and start/stop simultaneously.
You may need to check the drainage pipe and water inlet for blockages. Under the filter inside, you can remove part of the drainage system by removing the silver clip and pulling on the plastic segment.
Wash this through, it has a lovely ball bearing inside, but don spend too long wondering how big it is. Big it is.
Check the tubes, for kinks etc... Always disconnect the water supply before detaching the inlet, and be prepared for a mess, if you do decide to remove the drainage outlet pipe.
Failing this, the following post may help:
Check out this solution to the Miele 24 in G646SC Plus Free Standing...
Feb 18, 2014 | Miele 24 in. G646SC Plus Free-Standing...
Baumatic 1206.1 washing machine drainage issue
you probably turned it off before the empty cycle had finished
Jan 22, 2018 | Baumatic Washing Machines
The normal and economy lights are blinking and cannot get to wash through a full cycle. water is in the bottom of the washer
You will have to check if the dishwasher is stuck in the drain cycle or wash cycle.
The normal and economy lights flashing means there is flooding in the unit.
Reset the unit by pressing START button for 4 secs. If the flashing does not stop then you have to call the technician. There may be a leakage which is causing the flood switch to activate.
May 21, 2011 | Viking 24 in. Professional Series VUD040...
The screen is flashing F3, what does this mean?
the drain pump of the washing machine is either got loose or its not working or the drain pump is blocked. Water outlet fault (Grey Hose) If F3 is flashing in the display, there is a problem with drainage. Check: • that no objects are stuck in the drainage hose outlet. • that the drainage pump is not blocked by foreign objects. Clean the pump (see the "CLEAN THE PUMP" chapter MENTIONED BELOW FOR MORE HELP). • that there are no kinks in the drainage hose. ------------------ CLEAN THE PUMP Checking the trap and drainage pump The washing machine has a trap, where coins, hairpins and the like can get caught. To clean the filter and drainage pump: 1. Make sure the machine is empty of water and that it is switched off at the mains. 2. Open the hatch for the drainage pump as shown in the illustration. 3. Drain out the water, into a bowl, for example, by unhooking the drainage hose from the pin inside the hatch. 4. Unscrew the cover anti-clockwise and remove. 5. Remove any foreign objects from the trap and pump assembly. Check to see that the pump blades, right at the back, will rotate. 6. Screw on the cover, replace the drainage hose on the hatch pin and close the hatch.
---------- This will help.please do rate the solution if helped.keep updated for further assistance.
Apr 29, 2010 | Asko W6021 Front Load Washer
Zanussi washing machine will not start cycle.
check water level device,must have in manual,or water pump filter.
Feb 16, 2009 | Zanussi FJS1225W Front Load Washer
Dishwashers Logo
403 people viewed this question
Top Dishwashers Experts
