Question about AEG Washing Machines
Hi I have an AEGL16850 washer dryer and it is filling up with water when it is not in use. It is outside warranty and on a Scottish Island so getting and engineer to visit is near impossible. Help!
  • 11,896 Answers
Inside of the washer there are water valves. These valves are provided with power to open and allow water in, then power is release to have them closed. The water valve is in the machine and connects the external water lines to the internal water lines. Chances are the valves are leaking and not stopping the water flow. If you remove the rear panel of the machine you can access the valves.
Posted on Sep 04, 2010
Washer wont stop filling up what does part look like i have anohter washer take part from
Well, I think I may have an easy answer. There is an atmospheric switch. There is a tube within the tub, but on the outside of the area for washing clothes it goes down to the bottom, or nearly so, and when you fill the tub with with water, the water will then when filling, push the air in the tube up to the switch telling it when to stop. Its probably clogged and you need to pop the top of the washer to find it.
Apr 13, 2016 | Whirlpool Thin Twin Washer and Electric...
Will not fill with water
check hose is not kinked and tap is turn on. if both ok turn off water remove hose check filter that is inserted into the fill adapter where the hose fits to the machine is not blocked, if all ok to this point fault could be fill level detector, fill solenoid valve or programmer out put
Apr 09, 2014 | Washing Machines
Front load Whirlpool washer will not fill with water this happened once while under warranty and it was some kind of senser that was out I think it is the sensor again but do not know what sensor
Hi, this could be a faulty door lock. If the washer is put on a spin cycle does it burst into life? If yes then door lock is fine. If no movement then this may just be a bad connection on door sensor (clean contacts) or it may need new door lock.
Mar 02, 2014 | Ariston ARWDF 129 NA 23" Washer-Dryer...
What is the small hose on the back between the washer and dryer for
The hose off your washer will be two fill hoses "Hot" and "Cold" water and a Drain hose. the other things coming off a dryer will be gas line if gas dryer or a vent line for hot air to go outside. If you have a electric dryer you will have a large heavey cord coming off dryer going into over sized plug.
Aug 22, 2011 | Whirlpool Washing Machines
My washer/dryer will not fill with water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 23, 2010 | Hotpoint Aquarius WD63 Front Load...
Water temperature control not working
the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
Jan 17, 2009 | Whirlpool LTE6234D Top Load Stacked...
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
6 months old. Now no water will fill drum! Works as normal but no water!
Hurlewan Your washer is still under manufacturer's warranty which is one full year. If it has Kenmore's name on it you do not need proof of purchase. The only thing you need is your mother-in-law's home phone number at time of purchase because Sears keeps all their records based on phone numbers. Good luck, Gendos post back....
Jun 27, 2007 | Kenmore 43142 Front Load Washer
Indesit 1200 washer/dryer instructions
probable cause is just poor water flow from outside. switch water off. undo hoses and check not kinked. in each hose, there should be a gauze filter. clean this. look inside the valve spigot and check no dirt buid-up. put hoses in a bucket and check water flow is ok. remove drawer and check holes in top of box are clear
Jun 14, 2007 | Indesit WA 115 Front Load Washer
Washing Machines Logo
69 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
