Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Why wont my clean water come out at all from my Bissell carpet cleaner? Nothing comes out!
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
SOURCE: Bissell carpet cleaner
The spray hoses are bocked. The only way to clean them is to take the clear plastic cover off, un screw the base, lift cover, pull out red spray nosels, disconnect from main hose and wash under tap. Takes ages to do and is very fiddly.
Design fault as grit gets into spray holes.
Make sure you always clean machine after use,
Posted on Jul 26, 2008
SOURCE: Bissell Carpet Cleaner pro heat- water doesnt come out
I have a model #7920-P Bissell proheat pro-tech rug shampoer and floor cleaner wirth heat flow indicator, perfect pass indicator smart temp ready light upright model. The vacuum, heat, power brush perfect pass indicator all work. the flow indicator and sprayer do not function. I have cleaned all of the filters on the unit plus just about every inch of tubing on the unit.
The trigger mechanism does not seem to be applying the liquid cleaner to the front sprayers. Ther fore , the unit does not pick up any cleaner solution.
Posted on Oct 18, 2008
SOURCE: I have a Bissell pro heat carpet cleaner, the
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Posted on Mar 01, 2009
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
Bissell carpet shampooer model 9200-9 that is not dispensing cleaning solution
I had the same problem with my Bissell carpet cleaner. I tried all the recommendations but nothing worked. After reading all the blogs, I discovered that many people had the same problem. Fortunately, I still had the receipt from Costco which they honored and gave me a full refund. I was ready to throw it in the trash.
Oct 06, 2015 | Bissell 2X Proheat 9200 rug cleaner
My Bissell powersteam powerbrush carpet cleaner wont spray water from the floor jets or the hose. Checked the belt, its doesn't look damaged, also took it apart and cleaned the floor jets, still nothing.
Check any related mechanical and/or electrical parts, including switched, levers, buttons, valves and all water-ways. Make sure all electrical connections are clean, functioning with a multi-meter, and all pieces are NOT broken or malfunctioning and clean. replace any broken or malfunctioning parts that you can't clean or repair.
Oct 15, 2013 | Bissell 1697W Powersteamer Pro Upright...
Bissell carpet cleaner wont put out water or cleaning solution
Look for a blockage in the output of the liquid--where it comes from to where it exits the unit.
Nov 05, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
Water and solution do not dispense.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
wrh
Jun 30, 2010 | Bissell 8910 ProHeat Clear View Upright...
It just wont put any water out to clean carpet....Everything else works
That means that you need to replace the pump belt. Here is the belt you need, it includes instructions:
Bissell Proheat Pump Belt
Apr 13, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell carpet cleaner wont **** water out of carpet.
heatman101
rw245
Apr 11, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wont spray the cleaner n water out
check the dial setting. - presoak, off, cleaner, rinse
is cleaner bottle correctly inserted?
is clean water resevoir empty?
is dirty water resevoir full?
these items will prohibit the water/cleaner from coming out.
Mar 28, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Thankyou,
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
