Question about Digi-Tech Digitech Vocalist Live 4 Harmonizer
I cant turn it on it is plug up to my computer now wat will you please help me ? digital mp3 model mc262
  • Digi-Tech Master
  • 5,603 Answers
I assume you have the correct power adapter to power this. It does NOT get power from the computer. Depending on what country you are in will depend on which voltage adapter you need to use.
Posted on Sep 05, 2010
I had 8 songs that I have recorded on my PSRE433 and I turned it on tonight and they were gone.Can you please advise me as to what happened and how to avoid this?
I am not sure about specifics for your model but if you use the internal memory I understood the data was kept if it either had batteries fitted or the keyboard was left plugged into the mains ( even if the keyboard is turned off )
I guess with hindsight it would have been wise to save the data to a USB backup before turning off.
Nov 10, 2014 | Yamaha PSRE433 Portable Digital Piano with...
Noisy outputs on the korg tr
If this unit is running on a wall wart power adapter, it is possible that the adapter is NOT the correct one. Make sure it is the orginal adapter for the unit. A lot of Korg stuff requires adapters with more filtering or regulation. So called "Universal" adapters usually will NOT work. Please specify your model number as "TR" doesn't compute.
Jul 15, 2012 | Music
Why is my akai advd51 not playing music
Please check the format of file you are flaying from USB device if it is one of these supported by your system.MP3-CD
MPEG1, MPEG2, MPEG4, DIVX, XVID
Dolby Digital, MP3, PCM, WMA.If it is correct try to set the audio settings to simulated stereo or stereo out.Your system is a 5.1 system so it is possible that all channels will not be simulated with a stereo source.
May 26, 2012 | Music
How to connect the foot switch.
Using the CORRECT footswitch for this model, you just plug it into the footswitch jack. You MUST use the correct one for the model.
Aug 05, 2011 | Marshall Amplification Marshall MG50FX 50...
Why cant i get the same brilliant sound out of this unit compared to a carlsbro cdx 12x2mgs-fet digital reverb (not sure on these exact model nos as reading this second hand) this one sounded awsome ,but...
The mixer should have the same sound quality... the effects MAY be quite different. It is hard to know what you are refering to regarding sound "quality". One must setup the mixer correctly. Critical things are the trim controls and faders. Your faders should be near the unity setting when adjusted. Setting the EQ'a ia important and if you are stereo usage, setting the pan control can be important.
Feb 25, 2011 | Behringer Sx2442fx Eurodesk 24channel...
Korg pa-50 no sound from right speaker but has sound from left
Several things to check:
If the speakers are cut off when externaal cables are connected to line outs, possibly the jack sensing switch for the right channel thinks that a plug is in there... you might cycle one in and out to see if that might fix.
Another thing is they LIKELY have a PAN control setting and it might be set full left. The external MP3 would NOT be under PAN control, only the keyboard voices would be affected by it.
Feb 01, 2010 | Music
I cant transform wav files in to audio files with the computer
Here is a link for a good freeware program that will help you:http://www.filehippo.com/download_dbpoweramp_music_converter/ Let me know if this helps.
Nov 27, 2009 | Boss Micro BR Digital Recorder
BR-1180 won't power-up
I Own This Unit And I Tell You What I Love It And Cant See Myself Using A Computer Anytime Soon. You Can Open It Up And Check For Loose Connections By Removing The Screws Shown Here
Youll Wanna Remove The Disk Drive Cover First Indicated By The Blue Dots. Once Inside There Arent Many Connections To Check But Now You Can Unplug The Hard Drive And Try Powering The Unit On Again. See If You Get The Same Result. Once Thats Done Plug The Hard Drive Back In And Try Again To See If It Works.
If It Doesn't Call Roland Theyre Costumer Support Is Awesome And They Can At least Give You An Idea Of What May Be Wrong.
Roland Corporation U.S.
5100 S. Eastern Ave.
Los Angeles, CA 90040-2938
323-890-3700
Also Very Helpful Is This Guide On How To Remove The Hard Drive And Replace It Found Here.
I Hope Some Of This Helps.
Feb 07, 2009 | Boss Micro BR Digital Recorder
Headphones don't work right.
It might be that the contacts for the headphone jack is very dirty. Try using a cotton swab with a wd-40 on it to clean the inside contacts on the jack.
Jan 03, 2009 | Music
Digi-Tech Digitech Vocalist Live 4 Harmonizer Logo
49 people viewed this question
Top Digi-Tech Music Experts
rjivaro
Ben Armstrong
Are you a Digi-Tech Music Expert? Answer questions, earn points and help others
