Question about Marinco 7879cr Marine Stainless Steel Waterproof Electrical Cover With Lift Lid (Fits 54700cr, 5262crr, And 5739cr Duplex Receptacles)
How to i fit mt brenderup abs lid to trailer, and nuts and bolts required
Hi there, yes its a bit tricky, you really need to see a diagram of the pivot bushings and washers etc that go on the pivot end, im afraid i cant help you with that, if your having difficulty fitting the gas struts on the side, remove the brackets from the side of the trailer one at a a time, NB!!! Make sur you have help or else have the lid bsecured in a open position otherwise this will remove your head in one go if it slips!!! fit the struts and then reattach the brackets to the sides. the pivot are is very hard to describe without a diagram im affraid but the bushings basically go between the trailer frame and the lid, the bolt goes from the outseice in and caped on the inside. hope that helps.
regards
brian
Posted on Sep 08, 2010
Do I have to cover my trailer boat when towing?
I do not know the rules of your state but I do not know any that require a cover. The bout should be strapped down to the trailer and anything that can blow out should be removed. I followed a boat the other day that had a hatch unfastened. Round things were blowing out as the lid flopped in the wind. I stopped him, then went back to see what came out. He will be unhappy when he gets on the water and finds he does not have any leader line left.
May 10, 2014 | Boating
How to stop drain pipe from leaking on a 2014 shower 1985 lancr travel trailer
Is it leaking at a glued connection or a jam nut connection? If at the jam nut connection you may need to replace the jam nut washer to get a good seal. If it is a glued connection. You may get luck and reseal the connection by swabbing some ABS glue over the leaking area. ABS glue is thick black glue and may be found at your local RV dealership.
May 01, 2014 | Forest River 2012 Rockwood Windjammer...
There is no nut on the tensioner,just a weird looking thing witch a socket won't fit
Belt tensioner? Usually takes a 3/8 " ratchet or 3/8 " breaker bar to rotate the belt tensioner.
Get in there with an inspection mirror(It's tight quarters!).
Some Toyota's require a skinny wrench to fit onto the 14 mm bolt head.Some are 17 mm.
Socket won't get in there.
Some cars require loosening the engine mount and jack the engine up to gain enough clearance!(Mitsubishi)
Feb 21, 2013 | 2004 Toyota RAV4
How to replace a wheel speed sensor
if abs [also speed] sensor is damaged better off replacing hub most sensors are incorporated into the hub or are a ring style that is a press fit around the hub and still have to remove hub to replace--- larger vehicles and some cross overs u can remove just the sensor not in your case --if just wire damaged can order and replace but if abs needs to be replaced than prior to removing wheel loosen center axle nut dont remove yet jack up and support vehicle- remove wheel,brake caliper,brake bracket,rotor and center axle nut ,disconnect abs wire connection and remove the 3 bolts at rear of hub and remove hub from spindle clean area and reinstall hub careful of wire connection replace all components
May 14, 2012 | 2006 Buick Terraza
My Civic 2004, MT, without ABS has recurrent brake problems. After driving it for a while, the brakes (front) seem to make a cracking noise when braking, and also, it squeaks a lot when braking. Even after...
You need to remove the front wheels and check for any signs of extreme pad wear on both sides, heat buildup, try turning each wheel by hand while off the ground, and look for any loose hardware nut bolts etc.
Jul 31, 2011 | 2004 Honda Civic
How hard is it to change out both front wheel bearings
Not that hard, you will need to remove the brake calipers and rotors. The hardest part is getting the proper size socket to take the axle nut off the spindle if its 4WD. If 2WD they just bolt on from the back of the spindle (4 bolts), and electrical connector for the ABS. Leave the ball joints and tie rods connected.
Jan 28, 2011 | 2000 GMC Jimmy
How do you install the alternator
1990-93 Accord
  1. With the ignition OFF, disconnect the negative battery cable.
  2. Remove the power steering pump. Refer to Section 8 for the complete procedure.
  3. Remove the cruise control actuator but do not disconnect the actuator cable; simply move the unit out of the way with the cable attached.
  4. Unplug the multi-pin electrical connector.
  5. Remove the terminal nut and remove the wire from the terminal.
  6. Loosen the adjusting bolt; remove the alternator nut. Fig. 3: Alternator mounting on 1990-93 Accords 86803003.gif
  7. Remove the belt from the alternator pulley.
  8. Remove the adjusting bolt, the lower through-bolt and the small support stay.
  9. Support the alternator. Remove the upper through-bolt and remove the alternator.
  10. If desired, remove the alternator mounting brackets. To install:
  11. If the alternator brackets were removed, reinstall them. Coat the bolts with a thread sealer or liquid thread lock. Install the bracket bolts and tighten them to 36 ft. lbs. (50 Nm).
  12. Fit the alternator into place. Install the upper through-bolt and tighten it to 33 ft. lbs. (45 Nm).
  13. Install the small stay, the lower through-bolt and the adjusting bolt. Make certain the adjusting bolt is properly installed.
  14. Install the belt. Install the alternator nut. Adjust the belt tension. Tighten the alternator nut to 19 ft. lbs. (26 Nm).
  15. Connect the wire to the terminal and tighten the nut.
  16. Engage the multi-pin connector to the alternator.
  17. Install the cruise control actuator.
  18. Install the power steering pump.
  19. Connect the negative battery cable.
Oct 18, 2010 | 1992 Honda Accord
How do you replace shocks on 1991 buick skylark
REMOVAL & INSTALLATION Fig. 1: After you open the trunk lid, use a suitable prytool to remove the trim cover 86888036.jpg
Fig. 2: Some vehicles have a cover which must be removed to access the shock retaining nuts 86888037.jpg
Fig. 3: Unfasten the upper shock attaching nuts 86888038.jpg
  1. Disconnect the negative battery cable.
  2. Open the trunk lid and remove the trim cover. If equipped, remove the nut cover.
  3. Remove the upper shock attaching nut(s). If removing both shocks, remove one at a time.
  4. Raise and safely support the vehicle.
  5. Unfasten the lower shock absorber mounting bolts. One wrench will have to be placed on the bolt head side to retain the bolt as you loosen the nut. Usually a 15mm wrench is used to remove them. To install: Fig. 4: After the vehicle is raised and safely supported, use a socket to unfasten the lower retaining bolt 86888039.jpg
    Fig. 5: Remove the retaining bolt, then . . . 86888040.jpg
    Fig. 6: . . . remove the shock absorber assembly from the vehicle 86888041.jpg
  6. Connect the shock absorbers at the lower attachment and install the attaching bolt.
  7. Lower the vehicle enough to guide the shock absorber upper stud through the body opening, then fasten the upper shock absorber attaching nut loosely. Tighten the lower shock absorber mounting bolt to 35 ft. lbs. (47 Nm).
  8. Remove the axle support, then carefully lower the vehicle. Tighten the shock absorber upper nut to 21 ft. lbs. (29 Nm).
  9. If equipped, install the retaining nut cover, then install the rear trim cover. Close the trunk lid.
  10. Connect the negative battery cable.
Oct 08, 2010 | Buick Skylark Cars & Trucks
Is there any special tools required to change front wheel bearing on 2003 mini
you will need a big socket to remove the axle nut--about 20 mm or so. Other than that, I don't think so. Procedures from autozone.com below. it doesn't mention having to press bearing into hub.
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    Front wheels Hub nut Brake caliper Rotor ABS sensor Wheel hub from steering knuckle and driveshaft Wheel bearings
To install:
  1. Install or connect the following:
    Wheel bearing into hub Wheel hub to steering knuckle and driveshaft; torque bolts to 41 ft. lbs. (56 Nm) ABS sensor; torque to 6 ft. lbs. (8 Nm) Brake rotor and caliper New flanged hub nut; torque to 134 ft. lbs. (182 Nm)
Oct 05, 2010 | 2003 Mini Cooper
Broken part on MT 8180 looking for replacement part
ACE Hardware.  What you are looking fore is a "wing bolt" as opposed to a wing nut.  They have them in both SAE and Metric.  At least our local store does.
Oct 29, 2008 | Giottos MT 8180 Tripod
Marinco 7879cr Marine Stainless Steel Waterproof Electrical Cover With Lift Lid (Fits 54700cr, 5262crr, And 5739cr Duplex Receptacles) Logo
151 people viewed this question
Top Marinco Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Marinco Boating Expert? Answer questions, earn points and help others
