Question about Whirlpool GD5SHAX Side by Side Refrigerator
My Whirlpool Frige ice maker has been freezing at the base of the unit where the ice comes out. This was happening about once a month, now it is happening about once a week. Any Ideas?
  • 2,272 Answers
The ice dispenser drain is getting clogged and causing this.Check the water passing line which is entering the ice maker.The water passing line runs to freezer section at the back of the refrigerator.Also check the water valve.The unit is making ice this clears valve is working but still check the valve if its not getting close causing the unit to get frosted.The drain line and the valve needs to be checked.Defrost the unit for 24 hours by unplugging it from power and then check by reconnecting it again.If still the same problem then the ice makes needs to be removed out of the unit and at the back of the ice maker check the drain line and water valve/solenoid. the fill tube for the ice-maker is frozen.But if all checked ok the valve the fill tube the drain line and still the same problem then the problem is related to ice-maker module,it has to be replaced.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation
Posted on Sep 04, 2010
My Whirlpool 2 Door Frige & Freezer Tice maker outlet Chute Freezes up and blocks flow if ice coming down
you need to replace ice chute flapper. on alot of side by side whirlpool refrigerators there is a seal kit to solve that problem.
Jan 26, 2017 | Whirlpool Refrigerators
Hi, I Have a whirlpool 1844 for 6 month, recently it started to come some water form top of it's cabinet ( the part fan is located) and water is freezing coming down and is making ice candle on the...
Do you have a different model number other than 1844? What you are describing to me sounds like the valve that turns the water on to fill the ice maker is not shutting off completely once the ice maker fills with water. If this is the case the only way to repair is to replace the water valve. Sea Breeze
Mar 04, 2011 | Whirlpool GI15NDXTSS
The automatic ice dispenser is not working. How can I tell if it is the motor or the switch not working?
On my Whirlpool, the water splashes on the rotating parts and sometimes freezes the maker stopping it. Pull the plug on the fridge, use the hose on a vacuum machine plugged into the exhaust to get warm air to the ice maker or use a hair dryer to warm up the ice maker. After you are sure it is defrosted, plug the frige back in and listen for sounds of the ice maker turning or observe every couple minutes to see if the rotating parts are turning
Dec 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is accumulating and freezing on the bottom of the freezer
YOUR DEFROST DRAIN IS PLUGGED, YOU NEED TO REMOVE THEBACK PANNEL THE DE-ICE THE BOTTOM TRAY TO FIND A HOLE, YOU NEED TO CLEAN IT OUT UNTIL YOU CAN RUN WATER THROUGH IT.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Apr 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker stopped making ice - the unit is only 4 months old
Lets try this because I need the model nuber first befor giving the complete solution. Pour water into Ice maker tray turn on and let freeze. If Ice drops into ice bin and water does not come on the the dual water cotrol valve. If ice maker does nothing it wil be you ice maker or the grees F. See around door for model number, Thanks Sea Breeze
Apr 09, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Unit doesn't work when icemaker is on- Kitchen Aid Superba
that is unusual for the ice maker to cause it not to cool, but definitely not unheard of. if the fill tube to the ice maker, or ice maker itself, is leaking down the back of the freezer, behind the evaporator cover, it would form ice around the evaporator fan motor. this would cause the fan not to run, and the temp in the freezer and frige would rise. the ice would melt when it went into defrost, but then build up again. you should remove the rear panel in freezer and see if you see any ice build up around the fan blade, and if so, find where it is coming from. I hope this is the case for you. much cheaper than a compressor or new frige if it is. let me know if you have further questions. good luck, shane.
Sep 10, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool Ice Magic-No Frost Refrigerator (I'm guessing 30 years old)
look above the bottom kick plate, on the right middle, or inside the fresh food interior walls been a long time to remember this sweety machine loved it too everything where it was needed to be
Jun 23, 2008 | Whirlpool Refrigerators
Ice maker stopped working on Frigidaire Model FRS262NHW3...
I would check the valve that provides water to the ice maker before doing any thing with the ice maker head. Check voltage to the valve when the ice maker is in harvest mode. (with a good volt meter). watch the meter for the whole harvest cycle or you will miss the reading. if volage is good 99% chance youve got a bad valve, assuming the inlet tube is not frozen. Best of Luck.
Sep 25, 2007 | Frigidaire FRT18FS5A
Whirlpool GD5SHAX Side by Side Refrigerator Logo
42 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
