Rear wireless speakers keep cutting out - Audio Players & Recorders
  • 158 Answers
Have you introduced a wireless phone or router recently these can interfere with the signal
Posted on Sep 04, 2010
Trying to install stereo in 01 impala. I need to know the stereo wiring diagram. I keep reading that the yellow is 12v constant but have no yellow wire. Any help? Factory harness was cut out -______-
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: White
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Oct 31, 2016 | Cars & Trucks
My acurite inside unit keeps beeping every 5 minutes, please tell me how to stop it. it is 22 F outside right now and I think it is a freeze alarm Mike Doty
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated first. Constant, sporadic beeping is generally due to the unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. Wireless devices that may cause beeping but are not limited to these devices are; scanners; computers w/wireless keyboard/mouse; or other wireless weather instruments. Essentially, any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
Feb 10, 2011 | Acu-Rite Acurite Wireless Weather...
My acu-rite keeps beeping even after a battery change. Why?
I cut the wire that leads to the annoying noisemaker. Carefully remove the rear cover to expose the circuit board (the rear cover is connected to the circuit board so pull them apart carefully). Locate the noisemaker, mine was round and connected to the back cover with black and red wires. Cut the black and red wires and replace the rear cover. NOTE: If you use the alarm feature, it won't work anymore. I read on the Acurite site that the reason it beeps is because of interference with the wireless signal. They suggest not using one of your wireless devices. If you are like me, that isn't a good option.
Nov 11, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
Our Panasonic PT-50LC14 speakers keep cutting out. They work for a time, maybe 10 -15 minutes, then they cut out. Any ideas?
Did you ever fix this problem? I am having the same issue. I pulled the speakers and checked all the connections which seem fine. Funny thing is that when they do cut out, if I tap the side of the speaker panel that particular side will come back on as if it is a loose connection.
Sep 08, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Rear speaker not working.
check for loose connections
or speaker cut.
Apr 17, 2009 | Televison & Video
My main unit will not connect to the rear unit
I had a similar problem but mine cut out intermittently.
First, check to make sure the speakers are plugged in solidly. I was plugged into an outlet with a fancy cover and it caused the connection to short out intermittently.
2. Make sure all your wires are securely attached to the receiver unit.
3. If that doesn't work, try turning off the wirless speakers and the Home Theater system and then turn on both of them.
If one of these doesn't work, Samsung has chat support available onlline.
Good Luck!
Mar 13, 2009 | Samsung HT-TZ512T Theater System with...
Rear S-Air speakers cutting in and out
I read on another review that the HDMI cable is causing this problem because it is beside the S-Air transmitter on the main unit. I could not get my rear speakers to pair or work, and sure enough, when I removed the HDMI cable and hooked up the unit via Component Video to my Sony 52" XBR TV, the speakers paired and worked. When I plugged the HDMI cable in they did not work. I am going to try to purchase a higher-end, more expensive HDMI cable and see if that helps. The whole point of HDMI is for true blue ray 1080p pictures. Hope this helps.
Feb 16, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Wireless speakers
You should have two pieces for your wireless rear speakers setup. A. a wireless card inserted behind the all in one receiver. B. the receiving box that will connect to the 2 rear speakers.Also,you should not have any obstacles to block off the line of site for the rear speaker receiving box to the wireless card.
Best way to test it is too simply leave the rear speakers connected to the rear speakers receiving box on the floor near the a/v receiver with dvd player built in.Play a dvd and see if you have sound coming out from the rear.
solutiondoct
Nov 01, 2008 | Panasonic Home Theater System System
My panasonic wireless surround sound won't work out of the Rear speakers
I have finally got my rear speakers to work. wireless internet or cordless phones will stop the speakers from working, i switched off my wireless internet and hey presto speakers work fine, i just cant have both at the same time.
Jan 20, 2007 | Panasonic DMR-E50 DVD Recorder
101 people viewed this question
 Grubhead
Grubhead
