Question about Philips PPF-531 Plain Paper Thermal transfer Fax
Trying to send and receive sms on my magic3 fax machine. whhat is the transmission number, and what is the reception number?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 37 Answers
Your phone company have to tell you that or look it up on the internet of your phone company.
Posted on May 12, 2011
How long will my fax machine hold my send/receive data for? will it save for 4-5 years?
Sorry. Your reception and transmission report data changes as it is used.
The Fax Log shows the specific information concerning transmission or reception activities, the time and date of most recent 40 transmissions or receptions.
Y
yyyyyyyyYYYYY
Nov 19, 2014 | HP Office Equipment & Supplies
Error 386
Hi Error 344,
Is telling you the remote end has hung up the call which means it may not be a fax number (you called a voice line number for example, you can confirm if it as fax by just calling the number on your phone if you hear the whistles of a fax then that's not the cause).
I'm not familiar with the HP model but if it is "Super Group 3" (you can tell this if the transmission speed is capable of above 14.4kbps) and you're trying to call an older fax the remote machine may not be able to recognise the "Calling tone" your machine is sending and so it hangs up. You can try to remedy this by temporarily disabling Error Correction Mode (ECM) in your machines fax set up menu this will disable the Super Group 3 capabilities of the fax and maximum transmission speed will be reduced to the older Group 3 machine. HP website recommends the following:
Error Code: 344, 345, 346, 347, 348, 349 ECM, 350 ECM, 351 ECM, 352 ECM, 353 ECM, 354, 355 Definitions
  • The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power-related problems.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote user pressed the Stop key while the reception was in progress.
  • Under rare conditions, incompatibility between the two machines might cause the remote machine to abandon the call.
Solutions
  • Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Jan 23, 2014 | HP Officejet 6600 e-All-in-One -...
Cannot send or receive faxes to one particular number, but is able to send and receive faxes with other numbers
"cannot send or receive faxes to one particular number, but is able to send and receive faxes with other numbers"
If your machine can receive a fax transmission from one number, it will receive from all numbers.
If your machine can send to all but not to one particular number, please check that there is a fax machine there to receive it.
You can try to send manually and listen for beeps from the other fax -if one is present- then push the START button to initiate transmission.
If their machine is in working order, the transmission should start. (After the initial 'handshake' of course.)
Jun 16, 2011 | Office Equipment & Supplies
When recevie fax their is nothing document but error code coming 242
This link covers all error codes. http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02549&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN#Error232
Error Code: 242 Definition
The remote fax machine is attempting to receive instead of send. Both machines have attempted to start a reception at the same time. On many fax machines, it is possible to accidentally initiate a fax reception in the following cases:
  • There is no paper in the machine.
  • The paper is not correctly loaded and the document sensor cannot sense it.
Solution
Contact the sender to make sure that a document is ready and correctly loaded in the sending fax machine. Also make sure that the remote machine is attempting to initiate a transmission and not a reception.
Feb 28, 2011 | HP Computers & Internet
How to print a fax confirmation?
USER MANUAL Page 3-34
Press STATUS key 3 times. Press YES. Press UP and DOWN keys to select the report you wish to print.
TX Result Report The document number, recipient name, date sent, starting time of transmission, number of document pages, time required, mode.
RX Result Report The document number, caller name, date received, starting time of reception, number of pages received, time required, mode, and reception result are printed.
The machine can also be set to print this report automatically after every 60 transmissions/receptions.
Jan 26, 2011 | Konica Minolta Minolta FAX3900 Digital...
I have a new phone carrier(Vonage) and a new DSL modem from at&t. Prior to obtaining either, my fax machine worked fine. Now, I can't send or receive faxes..(Why)
This is a common issue with all fax machines that use a voip service. Basically, the reception and transmission features of the fax machine are not compatible with voip service. There is a modification that you can perform that usually allows you to avoid this problem, you must lower all transmission and reception speeds of the fax modem; this allows the data to be properly carried over the line without much loss or degradation.
-David.
Nov 03, 2010 | HP 1040 Plain Paper Inkjet Fax
I need assistance with fax error codes # 322 and # 358. What do they mean?
Error code 322- There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
Set the receiving machine to receive at a slower transmission speed
If the session fails after sending several pages of a large document, resend the document as several smaller documents.
Error code 358--
The remote user pressed the Stop key,
The remote machine encountered a system problem such as no paper or a paper jam.
Try
Configure the local fax machine to use a slower reception speed.
Disable ECM mode on your machine.
Try sending a fax to another location.
Mar 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
Can a sharp ux-p410 retrieve old sent faxes from its memory
No, your fax machine only records the fax number of the last 50 transactions
Oct 19, 2009 | Sharp Office Equipment & Supplies
How do i get a confirmation of a fax sent over a month ago?
Reports you can print
You can print these reports whenever you need to. Some of these reports can be set to
print automatically also.
1. Press Report/Help.
2. Choose the report you want by using !".
3. Press Start/Enter when the desired report is displayed.
4. The selected report will be printed. The available reports are shown below:
Report name Content
Multi-Communication This report prints automatically if you have faxed documents to
more than one location by using Broadcasting.
Power Fail Report If you have a scheduled job (such as, delayed fax and send poll)
and there is a power failure, this report is printed automatically
when power is restored.
Report name Content
Help List This report covers the machine’s basic functions and commands.
It can also be used as a quick reference guide.
Sent Journal
Received Journal
These reports show information concerning the transmission and
reception activities. They can be printed on command. Or if the
machine is set to do so, they will automatically print after every
40 transmissions or receptions. For more information, see Fax
Log under the “BASIC FAX menu” on page 13
Phonebook This report shows all of the numbers currently stored in the fax
machine’s memory as One-Touch Dial and Speed Dial.
Sending Confirm This report shows the fax number, the number of pages, elapsed
time of the operation, the communication mode, and the
communication results. To set up your machine to automatically
print, see Sending Confirm under the “BASIC FAX menu” on
page 13
Aug 25, 2009 | HP 1040 Plain Paper Inkjet Fax
PSC 2000 Series 2410 HP all in one
Hi this error code is for:-
The remote fax machine is attempting to receive instead of send. Both machines have attempted to start a reception at the same time. It is possible to accidentally initiate a fax reception after dialing on many fax machines, if there is no paper in the machine or if the paper is not correctly loaded and cannot be sensed by the appropriate document sensor.
*Contact the sender to ensure that a document is ready and correctly loaded in the transmitting fax machine and that the remote machine is attempting to initiate a transmission and not a reception.
Apr 08, 2008 | HP PSC 2410 All-In-One InkJet Printer
Philips PPF-531 Plain Paper Thermal transfer Fax Logo
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
