Question about kawasaki Full Suspension Mountain Bike Men
I have an 02 vulcan nomad 1500 fi w/ 28k miles and just recently changed the clutch spring due to gear slipping, worked great. After riding about a week and putting on at least 350 miles, on my way home from a friends it was suddenly very hard shifting up. Shifting gears down seemed ok but going back up was wierd, any thoughts out there? Are cables a suspect? The adjustment is on #1 as it has been since the day I got it.
  • kawasaki Master
  • 2,019 Answers
Sure, cables always start stretching just before they snap, as one strand at time breaks and unravels.
But is could also be a lack of oil in the transmission, friction material coming loose from previous slippage and binding, etc.
You say the adjustment is ok, but how much freeplay does it have?
Posted on Sep 04, 2010
  • dave Sep 04, 2010
    hey kirk, I never lost a drop when gasket, bolts and frame went back together and my window shows good capacity. I don't know what you mean by freeplay, I just never had any issues with clutch or cables and for it to just suddenly start to shift that hard didn't give me any feel hints at all.
  • Kirk Augustin
    Kirk Augustin Sep 04, 2010
    Since cables are multi-strand, when one strand after another breaks, they just start to stretch before they go completely. And as they get longer and longer, you get more and more free play. Which is looseness in the clutch lever, before you feel resistance. And too much free play will always make shifting hard, because the discs are still rubbing a little.
2003 Kawasaki Vulcan Nomad 1500 clutch lever is sticking
Hi, Daniel for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Clutch is stuck Vulcan Bagger Forums
Kawasaki vulcan clutch issue
How to bleed hydraulic clutch on motorcycle in an extreme case of air...
Kawasaki VN1500 Service Manual
OEM Parts for Kawasaki
2003 Kawasaki Vulcan 1500 Nomad Fi Owner Manual
Jul 15, 2017 | Motorcycles
2001 kawsaki 1500 vulcan nomad gets hot and jumps from 1st to 3rd back to neutral
Hi, Leonard and the usual suspects are:
1. Shifter pawl improperly adjusted.
2. Shifter drum improperly adjusted or damaged.
3. Shifter engaging parts/dogs badly worn or rounded.
4. Shifter forks bent.
5. Damaged gears.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Neutral problem Vulcan Bagger Forums
2nd slipping into neutral kinda
Kawasaki VN1500 MEAN STREAK Service Manual
2001 Kawasaki Vulcan 1500 Nomad Fi Owner Manual
May 04, 2017 | 2004 kawasaki Vulcan 1500 Nomad
2002 kawasaki vulcan/nomad 1500 fi. Has been sitting for over 5 years, cleaned fuel tank, replaced fuel pump, cleaned injectors and changed oil and filter. Fires up and runs great, has "0" power, can'
Can you push the bike easily? Even in gear with the clutch in?
if yes then the exhorst is 80% blocked either the baffle has collapsed or a rodent has built a home
Oct 05, 2014 | Motorcycles
Need radator for kawasaki vn 1500 classic tourer 2001 is the driffter the same radator as the vn 1500 classic plz hellllllllllllp
TO ALL VN1500 OWNERS....This once happen to me,
I went to the garage to start the bike "Nothing ""The first thing is the lights are bright but no turning over,Next you think the solenoid is kaput but the answer was very simple and the fix takes 30 seconds..
Do not take the bike to bits looking for other problems and look at the clutch leaver and you will see some wires going into a plastic shroud going into the switch in the clutch leaver, Make sure this has not popped out if its connection as it some times may do after a few years due to constant turning on the handlebars,
When this is not connected you will have a bike that will not fire up but comes alive and you will hear a clicking noise but this is from the engine carb area and every function of the bike will work but it will not turn over, Worth looking at and saves sixteen quid for a starter unit you never needed.
Feb 06, 2012 | kawasaki VN 1500 Vulcan Classic Tourer Fi...
Recently purchased a '97 Vulcan 1500 C. Had 11,730 miles on it. After riding about 1,000 miles, the clutch is begining to slip when cold. Seems ok after riding for about an hour. It also clunks, or grinds...
I don't think your clutch is bad, if it doesn't slip when hot. I would be blaming the pull on the lever not enough, or the gears are worn in the tranny. You can adjust the lever and you can try bleeding off the clutch, The engine oil usually cools the clutch, I'm not sure where your filter is, mine is underneath like a car. My tranny clunks and grinds when revving too much, have to wait for the revs to go down before shifting into first. It used to slip on hot days. Hasn't done it but a couple times. I never took out the clutch basket, but it seems fairly easy. If the oil change doesn't do it, and the bleeding of the slave, I would have to dig deeper into complaints about your bike, before I blame the clutch. You might not have to touch it, but you might be looking at something else. Check it out.
Jun 10, 2010 | 1997 kawasaki VN 1500 Vulcan Classic
1996 vulcan 1500, clutch goes away
if your oil is too thick , your clutch will sleep and go away .
if the clutch is old , you obviously will have the same problem .
please explain your problem when you ride
Sep 27, 2009 | 2004 kawasaki VN 1500 Vulcan Classic
1996 vulcanD classic 1500 30,000km
sounds like the gear selector plate plunger is worn or needs a new spring. on most engines a hollow screw @ 3/4" is accessible from under gear box, take it out and stretch the spring and retry to eliminate possibility.
Sep 14, 2009 | 1996 kawasaki VN 800 Vulcan Classic
Clutch slipping while cold, when warm/hot, it operates great.
I have a 2000 Vulcan Nomad FI & had a very similar problem. In fact, it's a very common problem with these bikes. I fixed it by replacing the Clutch Spring. (As Described here: http://www.gadgetjq.com/clutch_spring_replacement.htm
It cost me $40 and 3 hours of time with an impact wrench.
Jan 23, 2009 | 2004 kawasaki VN 1500 Vulcan Classic
Clutch/gearbox problem
its not the clutch but the clutch limiter spring, it gets worn in the center, this is a 1-1/2 hour job to replace and 45 -60 dollars in parts. if you email me at ellentoncustomz@yahoo.com i can walk you through this or give you another site that gives step by step instructions with pictures. also if you attempt this yourself or if a shop does it tell them to use the meanstreak spring it is stronger.
Jan 16, 2009 | 2000 kawasaki VN 1500 Vulcan Classic...
kawasaki Full Suspension Mountain Bike Men Logo
142 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Phillip Edwin
Level 1 Expert
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
