Question about Sport & Outdoor - Others
I have a Garmin Forerunner 406 CX sports watch. The GPS on my watch is not accurately recording the paths that I am running.
escapement
  • 2334 Answers
SOURCE: Garmin 50 forerunner failure
It sounds to me as you are having the problem with faulty contacts. They should be cleaned and checked for stiffness- if too weak must be replaced.
The next possible cause can be integrated circuit (IC) failure. In this case only skilled watchmaker can help you and that gonna be costly.
Posted on Dec 17, 2008
SOURCE: My Garmin 305 wont record calories
The 305 uses distance to calculate calories. They sell a "foot pod" that you can use indoors, and that will count your calories by calculating the distance you have traveled. The problem however, is that using distance to calculate calories is so inaccurate! The calorie count that the 305 provides is almost always WAY too high. Other heart rate monitors use heart rate to calculate calories burned, and it is a much more accurate measure. My garmin thinks i burned 700 calories an hour today while i was snowboarding, and, while that would be nice, there is NO way it's true!!
Posted on Dec 30, 2008
shannongreer
  • 75 Answers
SOURCE: GPS problems wit a Garmin Forerunner 405
The instructions say touch and hold GPS and to go outside away from tall buildings and to remain stationary for several minutes. Not really sure what their definition of several minutes is guess thats their way of saying "sit still for as long as it takes." If that doesnt work I would get in touch with Garmin. 1-800-800-1020
Posted on Jun 03, 2009
  • 84 Answers
SOURCE: Garmin forerunner 305 won't come on.
My wife's was always powering off during runs. Then it would not power on at all. There was a connection inside that wasn't making contact. But first First try cleaning the 4 brass connection tabs on the watch and check your charger to make sure the tabs are raised and not squished. Second try to reset the unit. Hit mode reset and power buttons all at the same time. Hold these for 3 seconds and then release. If these do not work here is what I did. There are no screws holding the unit together. I used a exacto blade to very carefully pry the unit apart along the side seam. It's not easy to do. Be very cautious and gentle. Work the thickness of the blade into the joint to gently wedge apart. You are not trying to remove material! Once apart you will see some brass fingers that make a connection between the upper and lower part of the unit. This is where the problem was with my wife's 305. I gently raised these tabs to make a better connection, It's been working ever since. I didn't try it before but try pressing very hard on the unit where it says Forerunner 305. The case is very hard so it might not work. But if it powers up when pushing you found your problem. Hope this helps.Here is a link I found on opening a 205 (Same process)http://ctorunner.googlepages.com/dismantleforerunner205 To put the unit back together use Automotive silicon/gasket maker.Use a tooth pick to put a VERY small amount of silicon around the entire seam. Put the two half's together and wrap tightly with electrical tape. Test the unit immediately to see if it powers on and off. If it does not open it back up and raise the small prongs more that make the connection from the bottom half to the top half. If any silicon squishes out the sides wipe with water and a rag.Let the unit sit over night. In the morning remove the tape.
Posted on Jun 09, 2009
SOURCE: Change battery on Garmin Forerunner 301
Hi - look at this solution for a forerunner 201, which has the same case design. I was just looking myself! R_nz Rank: Apprentice Rating: 96%, 8 votes I've made some progress here, I discovered that there is a small notch beneath the flat black pastic insert that holds the rubber button cover in. By gently prising this out, I can at least expose the pcb with the buttons on. I still can't figure out how to open the case though ****! Comments: Jan 29, 2008 - Well, I got there in the end! As above, I managed to prise the plastic insert cover off the rubber button cover, the peeeled this off as well. Underneath is a mylar printed circuit with the silver domeos of the buttons moulded in. This is siliconed down, but you can peel it up with a fingernail. The top left end (above the on button) is aatached inside the case, so start at the other end. Jan 29, 2008 - .ctd.. Once you have lifted the mylar strip, you can get at the case seam underneath and prise it gently open with a flat blade. The case is glued together with a light silicon or something. My problem was unresponsive buttons and by detaching and then re-attaching the small connector by the big silver block where the mylar attaches to the main board and then re-attaching it, it seemed to fix it! :-) Oct 22, 2008 - As an end-note; I glued my 201 back together with a light Silicone sealer. It seems to be at least rain proof anyway. Forerunner 201 battery replacement (Expert level): Opening the 201 was not easy and could not be done 100% clean, but thanks to R_nz (above) I got it open. My problem was dead (almost) battery, after 6 years of superb operation. I found the battery to be glued (double sided tape) to the back cover. To remove, push it up slowely and pull out. Beware of the short wires. 1. It is a flat battery, wrapped in shrinkable tube. Made by MDTechnology, P/N 043048 3.7V, 500mAh see http://www.mydbattery.com/EN/products.asp?ID=12 2. On the cover, the battery is soldered to the underside of a small PCB, hard to get to (by expert!). If you find a battery, suggest to cut the wires and solder wire-to-wire. Hope that helps
Posted on Jul 08, 2009
Ant will not pair with my 310
Do a master reset and start using Garmin Express
Jul 27, 2014 | Garmin Forerunner 310XT GPS Sports Watch
Why is my garmin f10 not accurate ?
Garmin Forerunner 10 Manual Check this link to donload the user manual to this GPS. Refer its trouble shot page. It has all details.
Jul 04, 2014 | Garmin GPS
Garmin 310xt software
Run the Garmin WebUpdater to load or reload the latest software to the device.
You may also want to contact Garmin Tech Support for assistance.
1-800-800-1020
May 15, 2012 | Garmin Forerunner 310 Xt Gps Sport Watch...
I need help with the GPS on my Garmin Forerunner 450
Information on the Garmin Forerunner 405CX can be found in the manual Download.
What sort of help did you need?
Sep 12, 2011 | Garmin Forerunner?® 405CX Sports Watch for...
I have had my garmin forerunner 205 since end of May 2010. It recently started taking longer than normal to find satelites. On my last run it came up as saying battery low when I had only just charged and...
You need to contact Garmin and have them replace or repair the watch. If the watch is less than a year old, it will be under warranty. Older than a year it may be a repair or replace only situation, Garmin will have to determine that. It is not unusual for the forerunner series to have rechargeable batteries that die off.
Jan 04, 2011 | Garmin Forerunner 205 Gps Training Watch
Could I use the Nike+ pod together with a Garmin forerunner 210?
Nope: Different types of signals.
That being said, there is a foot pod that Garmin makes if you want that type of data sensor. The GPS in the 210 is more accurate than the Nike+ pod, and the Garmin foot pod is about equally accurate with the 210, but allows you to use the watch when there is no GPS signal
Dec 18, 2010 | Watches
My garmin forerunner 305 does not identify my hertbeat
A few things to check: first, you have to moisten the sensors on the inside of the rib band or they won't pick up your heart beat. To do this, put a few drops of water on the ridged areas on both sides. Also, there is a battery in the band which can need replacement. Remove the cover to the battery using a nickel and replace it with a fresh one. If that doesn't work, I have had very good luck with Garmin tech support.
Oct 17, 2009 | Heartbeat Garmin Forerunner 305 Gps...
I just got a new garmin forerunner watch. How do
Follow this link, give all the details of your device and download it:
http://www8.garmin.com/support/userManual.jsp
If this doesn't work - give us next question.
Rate me, please.
Aug 15, 2009 | Garmin Forerunner 405 Fitness Watch/GPS...
My garmin 305
Press and hold the mode and lap buttons for 10 seconds, then release. Most of the time, that will fix it. Garmin has a sort of sleep mode programmed in for certain situations. If that doesn't work, I have had wonderful success with Garmin tech support.
May 16, 2009 | Heartbeat Garmin Forerunner 305 Gps...
My Garmin 305 wont record calories when I'm in the Gym. I select the "Other" sport mode, the little guy skiing, and It doesn't recored or even register calories? It records during my Jog sessions while...
Dec 17, 2007 | Garmin Forerunner 305 GPS Receiver
Sport & Outdoor - Others Logo
239 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
