Question about Samsung SpinPoint P120 SP2504C 250 GB SATA II Hard Drive
Jumper setting for slave drive - Samsung SpinPoint P120 SP2504C 250 GB SATA II Hard Drive
    Scholar:
  • 99 Answers
There is no such master or slave setting when SATA is used.
it is mainly used to tell the motherboard which one is master or slave when connected with IDE cable (PATA).
you don't need to worry about it as you are using a SATA HD.
the boot disk priority can be set in the BIOS
press del or F2 after you press the power button on CPU. you will be put with the BIOS/CMOS setup. go to boot priority and set accordingly, there is also an option to set the default hard disk in case you have more than one HD.
Posted on Sep 05, 2010
    Problem Solver:
  • 14 Answers
There is only one jumper for the SP2504C, that to reduce the speed to SATA I, down from the default SATA II. Instructions for setting the jumper are in very tiny print on the HDD label.
Posted on May 02, 2015
Drawsalot
  • 38 Answers
SOURCE: jumper settings for an older maxtor hard drive
Support can be found at Seagate.com in case this is not the exact drive. The model number you listed was not an exact match.
Posted on Nov 25, 2007
SOURCE: sata drive
what is the Question
Posted on Apr 09, 2008
SOURCE: Jumper Settings
another place to look is on the circuit board where the jumpers are connected you'll see : MS, CS, CAB, a space and TXD.
Cheers
Posted on Jan 19, 2008
Templarius
  • 83 Answers
SOURCE: jumper settings for maxtor
http://www.tacktech.com/display.cfm?ttid=379
Go there and enjoy dude ....
Posted on May 26, 2008
buffalonyman
  • 1865 Answers
SOURCE: When installing a Maxtor Quantum Fireball Plus AS
put the jumper on CS, and use the connector on the end of the ribbon cable
Posted on Jun 11, 2009
Is there a jumper setting to run my hitachi 250 gb sata laptop hdd as a slave ?
There should be, look on the rear of the drive, close to the SATA and power connectors, you should see the jumper connections as well.
It varies from drive to drive, but the jumper setting could be engraved near the connector, look of SL for a slave setting.
If no, look on the label on the top of the drive, there should be the jumper settings listed there.
Some may be ambiguous, my last one offered the option of Master on / off. (Jumper in position 1 for on, no jumper for off) The off in this case was of course slave.
The result being, no jumpers - Slave.
Mar 26, 2011 | Hitachi 250GB Hitachi 2.5" SATA Hard Disk...
Can we use Excelstor Gstor as a Slave Drive? If yes, how? What is the jumper setting required?
To configure the hard drive as a slave drive, you need to set a jumper on the hard drive to SL (slave)
The other jumper settings are MA (master) and CS (cable select).
Mar 20, 2011 | Excelstor Technology J880 Hard Drive
What is the jumper pin placement to make a slave of a DiamondMax Plus 9, 80GB hard drive?
The manual is linked below and section 3.3.1 covers jumper settings.
The slave setting shows the park position so you have a jumper on the drive so you can reconfigure it later.
A quick answer is that the slave setting is no jumper at all on the jumper pins.
DiamondMax Plus 9 Manual - DiamondMaxPlus 9.book
Feb 12, 2011 | Maxtor Hard Drive
I have a maxtor quantum fireball plus as 20.5 hard drive. i want to set it to slave. how do i set the jumpers?
on maxtor drives, you will find the jumper within a cluster of 9 pins. if you look on the bottom of the drive, on the circuit board, the pins should be labeled "ms" "cs" and such. the "ms" and "cs" stand for "master" and "cable select". you rarely use the true "slave" setting anymore, more often than not' "slave" drives are set to "cable select" and are attached to the middle, slave position on the ide cable. in "cable select" mode, the cable decides what device is master and what is slave, depending upon the devices' position on the ide cable.
to set the drive to "slave", set the jumper so that it only has 1 pin under it, and doesnt actually jump any pins, or just take the jumper out. only use the "slave" setting if the "master" device on the same ide cable is actually set to "master".
if the master device is actually set to "cable select" then you will have to set the slave device also to "cable select" and the middle position on the ide cable will set it automatically to be a slave. , instead of using the jumper to make it the "slave".
to set the drive as "cable select", which is what i would recommend, use the jumper to connect the 2 pins which are labeled "cs", the 2nd position from the bottom position on most older maxtor drives, and attach this hard drive to the middle connector of the ide cable.
Nov 25, 2010 | Quantum Fireball Plus AS (QMP20000AS-A)...
Need IDE jumber settings.
There is a little jumper block on the rear of a DVD. by IDE connector. on the case above there will be a Table marked . Master: Slave: CS. Now, you must set the jumper as to your drive's position. IE: Master or Slave, Master is on the plug at the END of the ribbon, the Slave is on the "Other" one. Accordingly the Master has the Master Jumper ON, the Slave the Slave Jumper ON. CS is Cable Select. It isn't all that used.
Feb 11, 2010 | Plextor 52x32x52 PX-230A Internal CD-RW...
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
Reinstalling the original cd rom that came in the computer. do i need to change the jumper settings. it is a samsung sc-148
That depends upon the IDE cable you are attaching the CD ROM to.
There are two IDE cables attached to the motherboard, on IDE 1 connector/cable will be your boot hard drive (C drive) and this will be jumpered to Master and you can attach the CD ROM drive to this cable and set the jumper on the CD drive as Slave.
On IDE 2 connector/cable if there are no drives attached to this cable then the CD ROM drive can be jumpered as Master or Slave..
If there is another drive on the same IDE 2 cable then look at the jumper on that drive, if it is jumpered to Master then the CD drive needs to be jumpered to Slave. If the existing drive is jumpered as Slave then the CD drive needs to be jumpered as Master.
Both drives on the same IDE cable cannot be jumpered with the same setting.
Nov 30, 2009 | Computers & Internet
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Slave jumper setting
SATA drives don't have jumper settings.
You can set master/slave in BIOS.
Mar 29, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Samsung SpinPoint P120 SP2504C 250 GB SATA II Hard Drive Logo
2,745 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
