Question about IBM ThinkPad T41 2373 Notebook
How can I disable the primary password hard disk acces
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 88 Answers
Http://www.pcloginnow.com/ this will remove all windows passwords and this http://www.pccmos.com/ will remove all bios passwords, both are free, download. burn to disk and use on boot up.
Posted on Sep 04, 2010
Hard-disk #**Z1HBT2FVT-595B, the system Primary HDD, is protected by a password authenticationsystem. You cannot access data on this hard drive without the correct password
Hi ,
If its cmos protected , theres a jumper pin on the motherboard you can remove and that disables any password that was made , get back to me and let me know if this helps you ,,goodluck Roy
Oct 31, 2012 | Dell Latitude D530 Notebook
Tip
Creating a bootable flash drive
<p><b>Resolution:</b><br /> <p>The USB Flash Drive must be configured with an active primary MS-DOS partition. It must also contain the boot files. Follow the steps below to create a bootable USB Flash Drive. <br /> <p><b>Requirements:</b><br /> <ul> <li> Motherboard with BIOS that supports USB boot. <li> USB Flash Drive that may be erased. <li> Bootable floppy disk or CD with Fdisk and Format commands. </li></ul> <p><b>Directions:</b><br /> <ol> <li> Plug in the USB Flash Drive. <li> Make the USB drive the only bootable hard drive. <b>Method 1:</b><br />If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. <b> Method 2:</b><br /> Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. <b> Method 3:</b><br /> Unplug all hard drive cables inside the case. If the cables are unplugged the computer cannot detect and boot to the hard drive. <li> Insert the bootable floppy disk or CD into the appropriate drive. <li> Restart the computer to the bootable floppy disk or CD. <li> At the command prompt, type: FDisk. <li> Delete and create a new active primary DOS partition. <li> Use FDisk to delete all partitions from the USB Flash Drive. <ul> <li> In FDisk, press the 3 key to Delete partition or Logical DOS Drive. <li> If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition. <li> After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER. <li> A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER. <li> You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER. <li> The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu. </li></ul> <li> Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2. <ul> <li> In FDisk, press 1 to Create DOS partition or Logical DOS drive. <li> Press 1 to Create a Primary DOS Partition. <li> The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER. <li> The next screen prompts that the computer will now reboot. Press ENTER to continue. </li></ul> <li> Exit FDisk and restart the computer. <li> Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected. <li> At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER. <li> At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER. <li> Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\&gt; command prompt. <li> Change the settings made in step 2 back so that the computer operates normally again. </li></ol>
on Mar 14, 2011 | Computers & Internet
Tip
Creating Bootable USB Flash Drive.
Requirements:
  • Motherboard with BIOS that supports USB boot.
  • USB Flash Drive that may be erased.
  • Bootable floppy disk or CD with Fdisk and Format commands.
Directions:
  1. Plug in the USB Flash Drive.
  2. Make the USB drive the only bootable hard drive. Method 1:
    If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. Method 2:
    Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. Method 3:
  3. Insert the bootable floppy disk or CD into the appropriate drive.
  4. Restart the computer to the bootable floppy disk or CD.
  5. At the command prompt, type: FDisk.
  6. Delete and create a new active primary DOS partition.
  7. Use FDisk to delete all partitions from the USB Flash Drive.
    • In FDisk, press the 3 key to Delete partition or Logical DOS Drive.
    • If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition.
    • After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER.
    • A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER.
    • You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER.
    • The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu.
  8. Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2.
    • In FDisk, press 1 to Create DOS partition or Logical DOS drive.
    • Press 1 to Create a Primary DOS Partition.
    • The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER.
    • The next screen prompts that the computer will now reboot. Press ENTER to continue.
  9. Exit FDisk and restart the computer.
  10. Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected.
  11. At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER.
  12. At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER.
  13. Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\> command prompt.
  14. Change the settings made in step 2 back so that the computer operates normally again.
on Mar 31, 2010 | Computers & Internet
Hard disk is protected by password
The hard drive needs the password. "Hard-disk #...., the system Primary HDD, is protected by a password authentication system. You cannot access data on this hard drive without the correct password."17 Jun 2008
Locked hard drive needs Dell password - Disk Drives (HDD, CD/DVD ...
en.community.dell.com/support-forums/disk-drives/f/3534/t/19063176..or try this link.... Hard disk is protected by password Google Search
Aug 29, 2011 | Dell OptiPlex 380 MT Desktop Computer...
Hard-disk #44w4z2y3764-595B the system primary HDD, is protected by password authentication system how to solve this problem how unlock it by correct password?
Here is your Dell Hard Disk Master Password for HDD serial #44W4Z3Y3764-595B
Your HDD Master Password is: w2cuzked
When asked for HDD Password use the HDD Master Password to unlock the HDD password. The Dell HDD Master Password is what Dell can calculate for you or a third party.
Thanks to the great guys at unlockbiosrecovery.com for providing the HDD Master Password that will unlock your hard disk. They can unlock your laptop bios or hard disk.
Apr 01, 2011 | Dell Inspiron 8200 Notebook
Hdd primary pasword is lost cannot open hard disk drive showing error codes 06231 and so on cannot boot the computer cause the disk drive is asking for primary hdd pasword and is no taking the password...
Most modern laptop HDD or BIOS passwords are not resettable and don't come with default passwords to unlock them if the password is forgotten.
You will need to contact Acer and find out what kind of warranty coverage your machine has. It's likely that you will have to pay for the services they provide or pay for a new hard drive yourself and re-install Windows.
Aug 10, 2009 | Acer Aspire 5535-5050 Notebook
1. My ideapad Y430 easy cam doesnot working after i reinstall windows vista ultimate. Not i cant use it for my password. 2. I also try to partition it into four but it doesnot support i can have only two...
this is all I can offer in your situation.....one option is to..use the...
Novo button
This button functions as a reset button; use with caution. Press the
1. Novo button to enter the main interface of OneKey Recovery while the
power is off. You can use OneKey Recovery to restore the primary
hard disk partition (usually drive C) back to the factory default
configuration, including the operating system and the software on it.
Attention: Once done, the system can no longer return to its previous
state. All data on the primary hard disk partition (usually
drive C) will subsequently be lost. So make sure all
important files on the primary hard disk partition have
been backed up onto another hard disk or USB hard disk
drive before this operation.
For details, see “OneKey Recovery4.65 User Guide
2. For the camera check out these key functions....
The following describes the features of each function key.
Fn + Esc: Turn on/off the integrated camera.
Fn + F1: Put your computer in sleep mode.
Fn + F2: Turn off the LCD screen (any subsequent operation will turn the LCD screen back on).
Fn + F3: Shift to other connected display devices.
Fn + F4: Switch between wide screen and normal mode.
Fn + F5: Enable/disable the built-in wireless networking feature.
Fn + F6: Enable/disable the bluetooth features.
Fn + F8: Enable/disable the touch pad.
Fn + F9: Enable/pause Media Player playback.
Fn + F10: Stop Media Player playback.
Fn + F11: Skip to the previous track.
Fn + F12: Skip to the next track.
Fn + Insert/NmLk: Enable/disable the Numeric keypad.
Fn + Delete/ScrLk: Enable/disable Scroll Lock.
Fn + Pause/Break: Pause to view the system information during start-up.
Fn + up/down arrow key: Increase/decrease display brightness.
Fn + right/left arrow key: Increase/decrease computer volume.
3. And for the password...here you go....
Using Passwords
Using passwords helps prevent your computer from being used by others.
Once you set a password and enable it, a prompt appears on the screen each time you power on the computer. Enter your password at the prompt. You cannot use the computer unless you type the correct password.
Make sure that only authorized individuals access your computer.
Establishing different kinds of passwords requires that other possible users know the proper passwords in order to access your computer or your data.
As many as three passwords might be needed for your computer: the Supervisor password, the User Password, and the hard-disk drive (HDD) password. When the Supervisor password is set, only the Supervisor password entitles you full control of the computer.
• User password
If a user password is set and Password on boot is enabled, a password prompt appears when you turn on the computer. Unauthorized users cannot get access to configuration data.
You can also use the user password to enter the BIOS Setup Utility, but once the Supervisor password is set only a part of the options can be set.
• Supervisor password
With a Supervisor password, you can get full control of the computer. It also can be used as a power-on password, the same as the User password. Also, when you enter the BIOS Setup Utility with a Supervisor password, you are entitled to set all of the options.
• Hard disk (HDD) passwords
Once an HDD password is set, you need to enter it to get access to the hard disk. You can set the HDD password through either the User Only selection or the User + Master selection in the BIOS Setup Utility.
Note: If you set passwords through the BIOS Setup Utility and you put your computer into sleep mode by pressing Fn + F1, the following describes the behavior of the computer when you bring it out of sleep mode:
• You are prompted to type the Windows log-on password rather
than the User password to resume operation.
• If an HDD password is assigned to any hard disk drive, the hard
disk drive is unlocked automatically when you resume operation.
To set a User Password:
1. Turn on your computer. Press F2, while the initial screen is displayed.
The BIOS Setup Utility screen opens.
2. Select Security, using the cursor directional keys.
3. Select Set User Password, and press the Enter key. The Set User Password window opens.
4. Choose your user password, which can be from one to eight
alphanumeric characters in any combination. Type it in the Enter New Password field.
5. Press the Enter key once to move to the Confirm New Password field. Retype the password you just entered to verify it.
6. Commit your password to memory, and press the Enter key.
7. Press F10 to exit.
8. Select Yes in the Setup Confirmation window.
Changing or Removing the User Password
To change the password, do the following:
1. In the Enter Current Password field, type your current password.
2. In the Enter New Password field, type a new password; then retype it to verify.
To remove the password, do the following:
2. Leave the Enter New Password field blank, and then press the Enter key twice.
Note: Make sure the Password on boot is set to Enabled if you need the password protection at power on.
To set a Supervisor Password:
Only a system administrator will be able to perform this procedure.
2. Select Security using the cursor directional keys.
3. Select Set Supervisor Password, and press the Enter key. The Set Supervisor Password window opens.
4. Choose your supervisor password; it can be from one to eight
5. Press the Enter key to move to the Confirm New Password field.
Attention: You might want to note your password and keep it in a
safe place. If you forget your supervisor password,
Lenovo can not reset your password. You must take your
computer to a Lenovo reseller or a Lenovo marketing
representative to solve this problem. Proof of purchase is
required, and a fee will be charged for parts and service.
The next time you open the BIOS Setup Utility program, you will be prompted to type your password to proceed.
Changing or Removing the Supervisor Password
1. In the Enter Current Password field, type the current supervisor
password.
2. In the Enter New Password field, type the new supervisor password; then retype it to verify.
password.
Hard Disk Passwords
Two types of the hard disk passwords help protect the information stored on the hard disk:
• Hard disk user password
• Hard disk master password, which requires a hard disk user password If User only is selected and a hard disk user password has been set, but no hard disk master password has been set, the user must enter the hard disk user password in order to gain access to files and applications on the hard disk.
If User + Master is selected you need to set a master password and a user password both as the Hard Disk Password. Either of the two passwords can be used to get access to the Hard disk. Any change or removal to the master password deletes the user password.
To set a hard disk password:
Print these instructions.
3. Select Built-in HDD1 Password Select, and press the Enter key. A window for selecting User Only or User + Master opens.
I will send the rest in the comment section..hope this helps in some way...the Fang.
Mar 07, 2009 | Lenovo 3000 Y410 Notebook
Dell latitude c610 primary or administraitor password unlock
try pressing Control and Enter while the computer starts
Jan 15, 2009 | Office Equipment & Supplies
Master hard disk bloked by passaword
can you pls described it to me, where the password pop-up when you use your pc?
Feb 15, 2008 | Televison & Video
Administrator password
default user administrator default password admin
Nov 07, 2006 | LaCie Ethernet Disk (300788) 1000 GB...
IBM ThinkPad T41 2373 Notebook Logo
41 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
