Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Every now and then the temp for the freezer and the fridge side rises in the 50's for a couple hours.
  • Frigidaire Master
  • 43,501 Answers
Defrost timer is sticking...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 05, 2010
My GE side by side door seals are hot. Last week, I vaccumed underneath and cleaned ice that had accumulated inside the bottom of the freezer. The drain hold was clogged. I poured 1/2 cup of warm soapy...
It sounds like the defrost circuit is on. Usually this circuit comes on every 8 hours or so and runs for about 20 minutes - or until a thermal sensor on (or near) the actual freezer coil rises to about 50 degrees F - whichever happens first.
The defrost circuit on some fridges not only activate the defrost heater in the freezer coil compartment - but one or more small heaters in the fridge cabinet door jambs where moisture is likely to form on humid days. Some fridges have a selector switches that enable or disable these "moisture control" heater(s). In any case, the defrost should not be on all the time.
Rising temperature in the freezer / fresh food compartment can be the result of a dirty condenser coil. Depending on the fridge, the condenser coil may be viewed and cleaned (vacuumed) from lower front (after removing the toe space bezel) or from the rear - behind an easily removed cover - often made of a thick cardboard / fiber material. You should only vacuum and clean the coils, fan blades, etc. when the fridge unplugged.
The fans that blow cold air from the freezer into the fresh food compartment may no longer be spinning - due to disconnected wires, motor failure or physical obstruction.
The defrost circuit timer may have become stuck in the defrost mode. Even though the thermal sensor will stop the heat once it reaches 50 degrees - if the timer is stuck - it will never enable the compressor. Defrost related repairs are cheap compared to a compressor failure.
Lastly, the compressor or refrigerant lines may have failed. This can be a costly fix. I hope this helps and good luck!
Sep 26, 2011 | Refrigerators
Freezer temp on GE profile French door fridge was rising rapidly. I believe I did not shut the freezer door tightly after retrieving something about 9pm. Outside of freezer on sides of fridge was very...
This is by design. It should be warm. This is where the heat exchanger is located to save space.
No worries.... right now it is being over-worked until it reaches operating temp.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My temp on my fridge is rising. It is usually on
what the problem is the ports that go from freezer to frige are all iced up you just need to defrost a few hours
Mar 12, 2010 | Refrigerators
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
The freezer temp is fine but the fridg temp is 50 degrees. It will not get colder than that. I have left it off for 24 hours to defrost and turned it back on and this did not solve the problem.
try moving the temp around,then if you tryed that already then defrost your frige turn off completly for one day if that dont fix it check if switch is working,last thing is the change the compressor
Sep 10, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Fridge temp goes up and ice forms in fridge
CHECK THE BAFFLE IT MIGHT NO BE OPENING OR CLOSING PROPERLY, THAT`S THE SMALL DOOR LOCATED @ THE LEFT UPPER CORNER OF THE FRIGERATOR
Aug 19, 2009 | Samsung Refrigerators
Freezer -5 Fridge 50
You have a defrost problem. Refrigerator gets cold via freezer. If blocked with frost, will restrict cold air into refrigerator.
Apr 26, 2009 | Refrigerators
Traulsen URS 48 DT Freezer in Freeze/Thaw Cycle/Fridge Side O.K.
I'm not intently familiar with this particular brand, but here's some ideas to check. If the thermostat sticks on, the freezer coils can freeze, blocking air flow and jamming circulation fan. This will cause the temp in freezer compartment to rise. When the ice on the coils thaw, the compartment starts to cool again, but the cycle will continue. Another thought is if this unit has a defrost timer that could be defective. Without seeing the unit, it's hard to determine the exact cause.
Hope this helps.
Jan 04, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
Mar 14, 2007 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
79 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
