Question about Dynex DX-SC5.1 Sound Card
Sound card i need help with my sound card setting it so i can play and record
  • Anonymous May 29, 2008
    i can`t hear any sound from my pc
Help me
Posted on Jul 10, 2008
Yes
Posted on May 12, 2008
Voice recorder won't play back sound
Can you put this problem to an expert
Dec 15, 2013 | Tascam Dr-05 Portable Recorder
Gigaware no sound
If you have audio cables from your source connected to the capture card, then your Recording device needs to be the Line In of the capture card.
If you connect the source to the Line In on the computer, then you use that as the default recording device. Until I set this, the default audio recording device was my microphone (not connected at the time). In Windows, you need the Manage Audio Devices Recording tab. (In Windows 7 and 8, it's under Control Panel > Hardware and Sound > Sound > Manage Audio Devices.)
If you are recording something playing on your computer, then the stereo mix option may work.
You should be able to use any video&audio software if the drivers are compatible. Thus the software you used for the video recording should work. (Stereo mix may be an exception - not all sound cards actually work when you try to record that content.)
I hope this helps.
Dec 03, 2013 | Televison & Video
SUDDENLY THE SOUND QUIT (HEART A POP SOUND LIKE A BULB POP) PICTURE STILL WORKS BUT NO SOUND- WHAT CAN I DO?
First, you need to find out, if this is a problem from your audio (sound) cord or from the unit or from sound settings.
Connect the player/recorder with another audio cord to the TV. Use a RCA (red and black wire). If sound still doesn't come out,check sound settings.
Go to menu, settings, sound, check all settings under sound. This should me done when playing a moved. If problem still persists after check sound settings and changing cord, then it means the sound card/board of your player/recorder is defective and that's why it won't bring out sound.
At this point, I would suggest you take the player/recorder to a repairman to fix for you because this is not a DIY thing. You need a professional to help you out.
Let me know if you need further assistance, please let me know.
Regards.
Aug 08, 2011 | Toshiba D-R5 DVD Recorder
I have an OS 10.5 Mac and a Logitech desktop microphone. I want to record and play back voice. What software do I need?
Mac come with builtin Sound Recording Service. You need to follow these steps to record sound through your microphone.
  1. Click the Apple menu and select Control Panels; select Monitors & Sound
  2. Click the Sound icon.
  3. Under Sound Monitoring Source, select one of the seven input sources (where the sound will come from): Built-in Mic, External Mic, Sound In, Expansion Bay, CD, Zoomed Video, Internal Modem, RCA In, DAV Analog In, or PC Card. Some systems may not have all choices.
  4. Choose Sound Output Quality: 11.025, 22.050 or 44.100 KHz. Some systems may not have all choices.
  5. Click the Apple menu and select Simple Sound.
  6. Click the File menu and select New. You're presented with a window set up like the controls on a tape recorder.
  7. Click the Record button and start your sound (either speaking or singing into a microphone, or playing your CD, or whatever).
  8. Click the Stop button when you're finished. You can click Play to check what you recorded.
  9. Click Save. You're presented with a Save dialog box in which you can name the sound file and place it in whatever folder you like.
You are done. If SimpleSound isn't in the Apple menu, search for it with Sherlock (press Command-F). To play the new sound file later, just double-click its icon to open SimpleSound.
For further help please visit http://www.ehow.com/how_6538_record-sound-mac.html
Please do rate my solution.
Regards, Rashid.
Oct 28, 2009 | Logitech USB Desktop Microphone
Recording with cubase problem
Need to set it to stereo. There may be a switch on your mixer, and you will also need to change the settings in Cubase to record in stereo, not mono.
Jul 30, 2009 | Lexicon Omega Desktop Recording Studio...
I cant record nor play while in Multitrack View, i can only play while in edit view ...? This is for adobe audition 1.5 ? Anyone know whats going on ???
Need more detail: 1. What sound card are you using?  - You need to make sure the correct hardware is selected as your record and playback types.  For instance, if you have more than one sound card, you could have easily the default one setup, but you really need your recording one - such as an ASIO driver - such as for external USB mixers.
2. What version of Windows?
My best guess is the hardware setup is off.  You have to have the correct hardware setup for Audition to see it.  Wave view and Multitrack view have diferent settings, each, so you have to set them up separately.
Dec 30, 2008 | Adobe Audition 1.5
I have a x-540 speaker system I brought today. Do I need a sound card to make it work with my pc. I hook it up/no sound.
A stereo computer system with resources to produce and record surround sound channels. Such surround sound channels are played or recorded using an audio card added to the computer system, which audio card controls additional speakers and/or microphones. Software for redirecting instructions from existing stereo application programs and sending these instructions to the existing audio device driver and the additional audio device driver is needed. Resources for processing the digital audio data for either extracting surround sound channels from two channel data provided by the application, or for encoding two sets of two channel audio data recorded by the two audio cards is also needed
Dec 02, 2008 | Logitech X-540 Multimedia Surround Sound...
Creative Sound Blaster Audigy Value Problem
Make sure that memory resident programs have been disabled. Defrag your hard drive as well so that audio files you are recording are continuous files on your drive.
Jul 16, 2008 | Creative Labs Sound Blaster Audigy 2 Value...
WinFast PVR2000 - recorded video has no sound
check the software configuration for the tv card to see if it using the correct audio device
Feb 24, 2008 | Leadtek Winfast PVR 2000 (663001C) Video...
Sound problems
Sound Recorder Help When trying to play a sound .wav file you receive the following error message: "Sound Recorder cannot record or play back because a sound device is not .
Computer Sound Card Help Line Out connector is the location which the speakers or headphones will be connected to get sound out of the sound card.
Good Luck, Please dont for get to Vote/Thank You.
Dec 21, 2007 | Toshiba Satellite A60 Notebook
Dynex DX-SC5.1 Sound Card Logo
27 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
