Question about Garden
HI, I HAVE A DEWALT PRESSURE WASHER DPD 3100 THAT IS NOT STARTING UP
4 Suggested Answers
nova2nv
  • 197 Answers
SOURCE: cannot get it to uptake the bleach for spraying
On most pressure washers you wont be able to draw soap/bleach into pump unless you are spraying on low pressure.There is a valve on the inside of inlet hose fitting that closes when high back pressure is sensed.Would it draw bleach into hose when wand tip is removed?
Posted on Nov 21, 2009
kel1guy2002
  • 3740 Answers
SOURCE: DPD 3100 gas pressure washer.
See this diagram:
http://www.mastertoolrepair.com/images/DPD3100_pump.jpg?osCsid=1f3m03ijp5lcht6569kran6rk2
Remove Items 122 (Un;loader) and 138 (Thermail relief). Clean them up as best you can with a nylon brush under some slow running water. Dis-assemble the unloader valve completly to clean (both ends). Then lubrcate them with White Grease and reinstall both parts AFTER placing White grease in the cavity the valves mount into. Very briefly... Test water flow with the engine not running Then start the unit with water off and let run 30 seconds. Turn off engine. Turn ON water supply and test water flow engine OFF. Note you will get a certain amount of white grease initially that passes through the unit. Start unit and rapidly actuate the trigger 1/2 second on 1/2 second off multiple times to force the unloader valve to cycle.
You can get parts here if either of the valves have completly failed:
http://www.mastertoolrepair.com/dewalt-dpd3100-n001194-pump-p-59405.html
The above steps should get your presure washer working properly again.
Thanks for choosing FixYa,
Kelly
Posted on Sep 03, 2011
mxc2
  • 146 Answers
SOURCE: Hi, My Dewalt 3100 pressure
The Dewalt 3100 came with 2 different pumps. The Blue Cat pump and the oil free pump that was made by DeWalt.
You may just have a bad Thermal relief Valve on the unit.
You can find the parts diagram at www.allpartsinc.com
Posted on Oct 01, 2011
Hi, My Dewalt 3100 pressure washer pump wash leaking water from a check valve or overflow plug Do you know whats wrong?
Sep 08, 2011 | Dewalt DPH3100 Gas Pressure Washer
DPD 3100 gas pressure washer. No water going through pressure washer. Have taken screen completely out and still no water moving through
See this diagram:
Kelly
Sep 03, 2011 | Dewalt DPD3100 Gas Pressure Washer
Hi, I have a Dewalt pressure washer 3100 psi. I want to know why the pressure washer works okay for 1 hour then it stop working completely. the oil is fine, the spark plugs are okay, and when I tried to...
There are two common issues that will cause what you are describing. What you need to do is run the machine until it dies as you are describing. Then pull the spark plug and check for spark. If you do not have spark you have a failing stater. It is very common for this problem to only show itself after the machine warms up. If you find that you do still have spark try removing the gas cap and restarting. It is also common for a vacuum lock to occur due to the seal on the gas tank cap. In most cases one of these will be your issue. If not feel free to contact me at 800.247.8103 and I will help you to troubleshoot the issue further.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 08, 2011 | Dewalt DPH3100 Gas Pressure Washer
Dewalt Pressure washer keeps shutting off for no reason. plenty of gas and oil, water running to it. starts fine and as soon as I start spraying it shuts down.
Had a similar issue with my dewalt 4200 pw. Unit starting shutting off after spraying for about 5 min. Then difficult to restart, but would start again eventually only to shut down a few min later. Had new engine oil, new pump oil, good gas. I changed the spark plug and unit runs great again!
Aug 08, 2010 | Dewalt 3800 PSI Pressure Washer
Does briggs and stratton make the engine for dewalt pressure washers
If it is a DPH it has a Honda engine. If it is a DPD it has a Dewalt engine that is made by either Honda or is a Chinese copy of the Honda engine. I looked at a photo of the engine and it looks like a Honda engine not a Briggs engine. Look on the engine data plate and if it says Made In China it is a chinese copy. If it say's Made In Japan it is a Honda. Some Briggs engines are made in China also so it is hard to tell except by the looks of the engine. The Chinese copy of the Honda engine looks exactly like a Honda.
Jan 10, 2010 | Dewalt 3800 PSI Pressure Washer
Cannot get it to uptake the bleach for spraying Dewalt pressure washer 3100 psi
Nov 21, 2009 | Dewalt Garden
My DeWalt Gas Pressure Washer Model DPD3100 is
Hi
Just try the following steps
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Good luck
Regards
PCmania
Jul 05, 2009 | Dewalt DPD3100 Gas Pressure Washer
Power washer not starting what type of oil to use dpd3100
10 w 30 for engine
10 w 30 and specify for [PUMP OIL]
ANY AUTO STORE
THANKS AND PLEASE RATE JJ505
Apr 11, 2009 | Dewalt DPD3100 Gas Pressure Washer
Garden Logo
119 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
