Question about Sanyo DS27590 TV
How do I get this tv on video input. I don't have the tv remote: I have dish network and it's worked fine for almost a year: somehow the input got changed.
    Novelist:
    Champion:
  • 286 Answers
It's been a few months, so I hope that you have gotten this resolved. But if not, or you still have some questions, here are some steps to go through. The link below will walk you through programming your DISH remote to the tv. This way, you will be able to change that input with just the DISH remote!! Hope this helps.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer service
Posted on Jan 21, 2011
I have Dish Network with the Hopper. My reviver has a HDMI slot and hooked mt Roku but cannot find how to switch the "input" to what Netflicks. Ugh, been at it for hours!!
Use your TV remote "input" "source" or "tv video" input button. If using the.Dish remote press the clear tv button then input. Repeat to go back to HDMI. Make sure you press sat to change channels once you get back on the HDMI input for dish
Oct 05, 2014 | DISH Network Televison & Video
How do I connect my LG TV to my dish network
Hello Al, my name is Cheri Torres and I work with DISH Network Internet Response Team. I came across your post and wanted to see if I could help. Connecting your LG TV to your DISH Network receiver should be fairly easy, depending on the connections you are using. If you are using an HDMI cable you will need to connect one side of it to your LG TV and the other end into your DISH receiver, as long as you have an HD receiver. If you do not have an HD receiver you are probably going to want to use composite cables(red, white and yellow). If you are using either of these cables you are going to have to set your TV to an input in order to receive the DISH picture. You can select an input by finding a button on the TV remote or the TV itself that is listed as input, source, AUX, mode or video. You will need to cycle through each one until you find the DISH picture on one of them. Once you have the picture you will need to press SAT on your DISH remote and everything should be working fine from there. I hope this information is useful and if you have further questions feel free to ask!
Dec 31, 2011 | LG 42PG20 42 in. Plasma HDTV
How do i get tv to pick up channels?
Hi Meagan, my name is Cheri Torres and I work with DISH Network Internet Response Team. I came across your post and wanted to see if I could help. Connecting your TV to your DISH Network receiver should be fairly easy, depending on the connections you are using. If you are using an HDMI cable you will need to connect one side of it to your TV and the other end into your DISH receiver, as long as you have an HD receiver. If you do not have an HD receiver you are probably going to want to use composite cables(red, white and yellow). If you are using either of these cables you are going to have to set your TV to an input in order to receive the DISH picture. You can select an input by finding a button on the TV remote or the TV itself that is listed as input, source, AUX, mode or video. You will need to cycle through each one until you find the DISH picture on one of them. Once you have the picture you will need to press SAT on your DISH remote and everything should be working fine from there. I hope this information is useful and if you have further questions feel free to ask!
Dec 29, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have a Dish IR. Not sure of the model number. Uses 4 AAA batts. The problem I have is the every function seems to work fine except for the volume control. In order to change volume I have to use the TV...
It is possible that those buttons have failed, but a bit more likely the remote lost the codes for the TV itself... since almost everything the remote controls... is on the DVR. I apologize if I am guessing wrong in assuming other "TV" buttons (like INPUT) don't function either.
To re-program your remote to recognize your TV (like when the tech first set up the system) choose from the following receiver types to find the correct remote control TV codes for your Zenith.
Remote TV Codes for 722/622/612/411/222/211 Receivers
Remote TV Codes for 625/522/512/510/508/501 Receivers
Remote TV Codes for 811/381/322/311/301 Receivers
Aug 29, 2011 | DISH Network IR Remote Control
I have a Dynex TV and Dish Network receiver. Last year the TV worked fine, I don't think I changed anything, but this year the top of the screen is cut off when I watch NFL games. The top of the score...
You will need to press the "Format" button on your DISH remote This button will have a * on it. By pressing this button repeatedly, you can change the format of the screen set it to normal. Next grab the factory remote for your TV and try the different formats most likely normal will work best on this setting as well.
Daniel Busa
DISH Network
Customer Service
Aug 27, 2011 | Dynex DX-LCD37 TV
Just got dish a week ago everything fine. Yesterday the power went off and now the main TV has arch screen and three different colors on everything on the TV and TV 2's screen is just blue
wvpotts0,
Are you still having problems with your receiver? Depending on the type TV you have, TV 1, on an older TV will use channel 3 of 4. A newer TV will have an input setting. If you have the TV remote, press either the "input", "source", or "tv/video" button to cycle through the input settings till you find a picture. Make sure the green, blue, and amber lights are lit on the receiver. TV 2 should be on channel 60 or 73. I hope this helps.
Ray Calo
DISH Network
Aug 21, 2010 | DISH Network ViP722 DTV Receiver /...
Tv video input wont work on remote that came with dish but vol goes up and down i have insignia tv
The tv video but will have to be accessed by pressing the clear tv button then pressing tv/ video, however some functions are not guaranteed to work on some model tv's.
Oct 27, 2009 | DISH Network IR Remote Control
I have a dish network remote control that I am trying to use to get to my video 1 or video 2 channels on my Sylvania 6420FF tv. The Sylvania remote is dead to the world and I need the Dish remote to get to...
You will need to by a universal remote in most circumstances as the Dish remote may not cycle through the inputs on your tv. You can try the recovery button on the remote it will have a small R on it. Press it many times to se if it it set to cycle through the inputs. Thanks for using Fix Ya.
Aug 01, 2009 | DISH Network 118216 Remote Control
Switch Toshiba projection tv to receive input from video-1?
jbrowne_usa
If your DISH remote is programmed to your Toshiba TV, you can press the TV button at the top left of the remote and then release. This will put the remote in TV mode. Press and release the TV/Video button just below the clear TV button. This will cycle through the inputs on your TV. Continue to press and release until you have Video-1 displayed on your TV screen. I hope this helps.
Ray Calo
DISH Network
Jun 14, 2009 | DISH Network DVR-625 DTV Receiver /...
Televison & Video Logo
225 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
