Question about Sony Playstation 3 (PS3) Console
I turned my ps3 on today and the light turned green, then amber and red and the system beeps three times. the red light then just keeps flashing. When i tap it while its blinking it stops but when i do again its the same process. The same thing happens when i try to eject the disc inside - green to amber and back to blinking red. I know it cant be an overheating problem because i haven't used the ps3 for 3 days.
    President:
  • 1,139 Answers
Although you say it can't be overheated, it is possible it is a result of overheating. When you get this error it means a general hardware fault. However, the most common fault found is when either the CPU or GPU processors become so hot that the solder devlopes microscopic cracks that do not close when it cools. This means that there is not a good electrical contact and the PS3 fails. So your PS3 may have been working fine the day before but when you turned it off it would of been hot inside. The circuit board and components would of cooled down essentially making the solder joints contract and open up the cracks in them.
There are guides out there to repair YLOD (yellow light of death) which explain step by step how to fix it. Unfortunately it is not a permanent fix and your console could only last hours after doing it.
Usually you will need a replacement PS3. If it is still under warranty give Sony a call who will replace it free of charge.
Hope this helps and thank you for using FixYa
Posted on Sep 04, 2010
Ps3 turns on then turns off and beeps three times
Sounds like a power supply issue. Unless it is showing any other colours after the green light. Red would be ylod which means a phone call to Sony. Try a new power supply and see if that fixes it.
Dec 29, 2012 | Sony Playstation 3 (PS3) Console
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
Turned ps3 on red light pressed on green light then amber then three beeps then flashing red light
Hello there dean
If you have the yellow light of death, this means the chips inside your PS3 have lost connection to the Motherboard, there are several ways to fix this problem and get back to gaming.
Solution 1
Send the console to Sony they will fix the problem if your in warranty, If your not in warranty than it will cost you $150, the process will take about 4-6 weeks and all saved data may be lost.
Solution 2
Fixing the problem with a PS3 repair guide Max cost $40 cheaper than repair and replacement price.
CONTACT SONY
FIND A VERY GOOD PS3 REPAIR GUIDE
Hope this helps
Let me know if you need any help
Jan 08, 2012 | Sony PS3 40GB Best Sellers Bundle Console
I turned my ps3 on today and the light turned green, then amber and red and the system beeps three times. the red light then just keeps flashing. When i tap it while its blinking it stops but when i do...
i have the same problem but to make matters worse mine wont even turn on now but a bunch of people say you have to take it to sony or i dont know if this works but a bunch of people say is does try turning it on or off (i dont know which one) and press the eject and front power button at the same time hope this works tell me if it does
May 07, 2010 | Sony Playstation 3 (PS3) Console
My ps3 suddenely turned itself off mid-game. turned it back onto standby mode, then when i turned it on the light went green as normal then suddenely red light came on with the green, three rapid beeps...
try this:
it works for slimline PS2. might work for PS3.
1) turn off PS3
2) unplug PS3 and wait a minute or two before plugging back in.
3) turn on PS3
hope this helps.
it could also be overheating.
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
Ps3
if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
insetad of restoring the filing system, restore the default settings ore restart the system
Mar 31, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 problem
Heat Sync issue. CPU and GPU need re-seating as well. Email dwdpcrepair@gmail.com for more help
Mar 30, 2009 | Sony Playstation 3 (PS3) Console
PS3 not working
Good News! PS3 got red light blinking and beeps can be fixed by yourself! With the all-in-one PS3 Repair Package - You will learn the techniques and knowledges to repair your PS3 including motherboard problem, hard disk problem, blu-ray drive errors and much more. Get one copy and secure your PS3 now.
Feb 21, 2009 | Sony Playstation 3 (PS3) Console
PS3 problems
I had the same problem before. You have an extremely rare RRod problem. what u du is go to the sony website, and somewhere, and call the number on the screen. ill just tell u it right now. --- 954-345-7669, and tell them what happend.
PS: They will problably ask for u 2 ship it back to the industry, for further repair.
been there done that
Jun 10, 2008 | Sony Playstation 3 (PS3) Console
Red light blinking on PS3
If your having this problem I know how to fix it but only for about 30-45 seconds.
Okay this is what you do.
1.If your ps3 is turned on press the red button , it should turn green then yellow ,beep and blink red.
now do this 3 times without turning it off.
2.Turn your ps3 off.
3.Turn it on while holding the eject button.
4.Now your ps3 should stay on ,(like I said for about 30-45 seconds).Also the fan should be on.But then after a while it turns back off.And that's as far as I got.
(It really works if you do it right)
Sony Playstation 3 (PS3) Console Logo
163 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
