Question about Acer Aspire 4730-4947 Notebook
My acer laptop is not charging, at first when i plug it, it will charge but a min later it will stop charging..what do you think is the problem..
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Sep 06, 2010
Acer Aspire 4830T laptop battery behaving vaguely
Do you still have the old battery. If so charge it, and see if it charges properly. If so then you have a bad battery.
Mar 18, 2017 | Acer Aspire Timeline X 4830T 14 Inch...
Plugged in,not charging
I think your battery is faulty. Not charging anymore has reached his lifetime. Replace the battery.
Mar 14, 2014 | Acer Aspire Computers & Internet
Hello, I have an acer aspire 5741 which i bought 5 months back. The problem started a week back and has got worse. It is when i plug the cord for charging on laptop, the blue light on power button and...
it needs a new a\c power block inside they are cheap and semi difficult to repair i wouldnt think it would be over 100$ max but it isnt in my lap to inspect so this is my opinion ok
Dec 21, 2010 | Acer Aspire One PC Notebook
When plugged the power indicator on my acer aspire 5570 flashes orange.it used to be a stable light that changed later to green. now it just blinks for hours.
i think that is the state of your battery,orange when charging,turns green when fully charged,make sure that is inserted properly,might need to be replaced
Oct 22, 2009 | Computers & Internet
Starts charging then stops
It sounds like the battery has some dead cells and needs replacing.
Oct 12, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5315 randomly stops charging.
I think u just answered urself, replace the power jack should solve the problem
Oct 10, 2009 | Acer Aspire 5315 Notebook
My battery stopped charging
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try charging up your battery for more than 30mins. If battery is not charging for more than 30 mins, your battery is faulty.
Note: If machine is under warranty no need to pay for the re
Jun 03, 2009 | Acer Aspire 5570-2758 Notebook
Laptop battery won't charge - Acer Aspire 4520
Since is shows it as charging then your power cable should be working. So it looks like a battery issue but batteries just don't die unless a cell inside dies then they will stop working. Try taking the battery off and making sure that the connections are clean then put it back in. If that doesn't work give the battery a good full charge then bring the battery and laptop back to where you bought it and get them to test the battery to see if a cell died.
Jul 29, 2008 | Acer Aspire 4520-5582 Notebook
MOTOROLA Z3 NOT CHARGING
have the firmware reflash on the phone this should correct the issue that you have had with the phone.
Nov 30, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Acer Aspire 4730-4947 Notebook Logo
134 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
