Question about Toshiba Satellite M45-S169 Notebook
Dead Toshiba Satellite M45-S169
Similar problem with Toshiba laptop. Mom's machine died on her while checking e-mail. No discernible signs of life since then - not even the power indicator light when plugged in to AC adapter. Out of warranty & extended warranty, of course. Is there an internal power supply that could be the issue?
  • alohman Jul 16, 2008
    I have the exact same problem with my computer. It died on me suddenly and now will not turn back on. I tried taking out the battery and putting it back in which gave me an extra burst of about 4 seconds, after which it promptly died again. I used a volage tester on my charger and it said that it was putting off 15 (voltz?) so that doesn't seem to be the problem. I will look into the other suggestions that have already been posted. Has the orignial poster found a solution? I would be very interested to hear about the soultion.
    Brigadier General:
  • 6,966 Answers
Based on your post if there should no indicator light if and when the AC adapter/charger is plug into the mains and into the power jack of the laptop, then it would be safe to assume that power is no being delivered into the internal circuitry of the laptop.
It is possible that the charger/adapter itself is defective. It could be checked with a voltmeter. You can try bringing it to any electronics shop or a friend with a DVM (voltmeter) to check for the presence of DC voltage at the plug.
Alternately, it can simply be just a fuse or a loose connection/ cold solder at the terminals/pins of the jack. There would be two soldered joints to the motherboard. Unfortunately, it would be more of a challenge to open the laptop than to repair. The repair would be simply reapplying heat (resolder) two terminals/pins of the power jack to the motherboard.
In some instances, it could be busted components like surface mounted fuses, regulators, diodes, capacitor or resistor. At other times, it could be heat related and simply a component got toasted. There were some cases of laptop overheating when used atop a bed, cushion, carpet and others becaue of restricted airflow/ventilation.
All of the above would call for familiarity with electronic components and circuitry, use of a DVM and a soldering iron. Should you be uncomfortable performing a DIY, then perhaps your best bet would be to seek the services of a qualified repair professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 12, 2008
Toshiba satellite m45-s169 will not boot windows
Windows is corrupted or the hard drive has issues, if you have a cd installation disc try a fresh install, if no change! the hardware needs to be checked for possible replacement.
Apr 14, 2012 | Toshiba Satellite M45-S169 Notebook
How do I change the CMOS battery in a toshiba Satellite M45-S169 laptop
open keyboard then check look bettery there
please click yes for vote
Jan 15, 2011 | Toshiba Satellite M45-S169 Notebook
Hi, I re-installed the hard drive on this laptop (Toshiba Satellite M45-S169), but the hard drive is unresponsive. Not sure if I installed correctly, or the hard drive is dead. The power light comes on,...
If drive not spinning, definitely dead. If spins and not recognized by laptop cmos, the logic board on drive is toast.
Afraid that you have a nice cute paperweight.
Sep 03, 2017 | Toshiba Satellite M45-S169 Notebook
I need the M45-S169 manual
Was just looking for that myself - found the Toshiba manual here. Toshiba's site is useless.
Mar 05, 2010 | Toshiba Satellite M45-S169 Notebook
Satellite M45-S169 - will not POST or power on. Power light comes ON for a few seconds then goes OFF. Power ight cycles ON/OFF six times then stops.
Hi rich caller i had this problem also with my laptop toshiba satellite M45-S169 and i find solution for this problem..
Just replaced ram memory and now my laptop works fine hope yours will work too
please respond if my msg helped you..
Apr 03, 2009 | Toshiba Satellite M45-S169 Notebook
Need a driver for a toshiba m45 s169
here is a link to toshiba's Vista support page, you can search for the proper drivers by model number.
Dec 15, 2008 | Toshiba Satellite M45-S169 Notebook
I need a mother board for a M45-S169
laptop mobo's are proprietary, you will have to go through toshiba or a liscensed toshiba repair shop.
Nov 04, 2008 | Toshiba Satellite M45-S169 Notebook
Dead Toshiba Satellite M45 S-169
hi dear
maybe you can try to check your memory module
release your memory module, use am eraser to cleaning your memory. and install it again
Mar 23, 2008 | Toshiba Satellite M45-S169 Notebook
Toshiba Satellite M45-S169 Notebook Logo
215 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
