Question about GE Profile PDW8600J Built-in Dishwasher
I have a GE Profile SmartDispense PDWT4800PSS diswasher. My glasses always seem filmy. I have make sure that I am using the same diswasher (either enzyme or chlorine based) liquid as directed in the liturature. I use Chlorine free. Any suggestions?
    President:
  • 1,197 Answers
If your dishes or glassware appear with a white residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
If you do find my solutions helpful .. please dont forget to rate the Solution. they are our encouragement to Serve you folks better.
Posted on Sep 04, 2010
Bosch Diswasher
Remove the drain hose and check if you have any residual into it. After 11 years your appliance may need a thourought cleaning.
Check also if the pump has enough pressure.
Apr 22, 2008 | Dishwashers
Ge profile front-load washer not draining
Firstly took the bottom front panel off and removed the drain plug/trap. Then the problem should be solved easily. For More information please visit Clothes Dryer Element .
Sep 22, 2012 | GE White Profile Series 15 Frontload...
GE Profile dishwasher with ''SmartDispense'' technology is clogged
Check the reservoir hose , and unclog it if necessary. You may need to disassemble the reservoir/dispenser to solve the problem.
Use to the diagrams below:
Apr 06, 2009 | Dishwashers
Water not draining and glasses look filmy
Call the repairman unless you are comfortable replacing the pump. It sounds like the pump is getting old and weak. The other possibility is that the pump impellers are caked with yuck. Depending on the manufacturer, they are replaceable, if they aren't cleanable.
Mar 17, 2009 | GE 24 in. Profile PDW7800 Built-in...
TOP RACK DOESN'T RINSE
I would suggest you buy some CLR and run it through a full heavy cycle with the washer empty. Be sure to put it in all dispenser areas and sprinkle about 1/4 cup into the washer before starting.
Feb 16, 2009 | GE 24 in. Profile PDW7800 Built-in...
Very filmy looking glasses
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jan 31, 2009 | Bosch 24 in. SHY66C05 Stainless Steel...
GE Profile JGB920SEF2SS
a thermostat that fails at high temp could cause a false temp reading causing the oven not to get up to that 700 deg mark.
Oct 28, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile PDW8600J Built-in Dishwasher Logo
347 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
