Question about Microwave Ovens
Nn-h644wf microwave turns off after a few seconds
  • srw11 May 12, 2008
    Problem: nn-h644wf
    posted by srw11 on 05/11/2008
    if the fan running ? yes, fan & light work ok
    is the ports into the food heating chamber clogged? no, all ports are clean.
  • srw11 May 14, 2008
    led panel stay lit and counting down the whole time or does it blink off.
    yes it blinks off after a coupole of seconds
    when i try using the sensor cook button it stays running for 8 to 10 seconds and then turns off
    I've cleaned the unit inside ond out and checked for any loose connections with no joy...
    sounds like a cut out switch malfuntion..
    Just need to narrow down the right part???
    Genius:
  • 1,554 Answers
If the fan running ?
Posted on May 12, 2008
  • Karl Whisenand
    Karl Whisenand May 12, 2008
    it may be the thermal fuse kicking off as the magnetron heats up.
    but if that was true then you could not restart it immediately.
    but if it has to rest and then you can restart it then it is overheating
    does the led panel stay lit and counting down the whole time or does it blink off.
    take a look at this site as it may help you diagnose error.
    http://www.gallawa.com/microtech/datasel...
NN-T945SFX CODE H98 RUNS A FEW SECONDS THEN STOPS
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
Dec 24, 2014 | Panasonic Pansonic microwave
Microwave shuts off after a few seconds. message says to check the manual. What's wrong?
The problem is the magnetron, or the inverter board, "if 7 years old or less" and possibily the keypad control board.
Apr 28, 2012 | Panasonic NN-S262SF Microwave Oven
Panasonic NN-F542BF 1300 watts microwave switches off after 3 seconds
It sounds like you were sold somebody else's problem, it could be a bad magnetron, cracked high voltage diode, and a shorted high voltage capacitor to name a few. I recommend a professional if you feel it is worth getting checked.
Mar 09, 2012 | Panasonic Microwave Ovens
Where is the second fuse in my panasonic nn-s963bf the one for the heating and what does it look like?
There is no second fuse. Look for a thermal cutoff there are a few of those. Test it for open circuit and replace.
Aug 11, 2010 | Panasonic NN-S963BF Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
My daughter put metal in oven it shut off. the oven turns buts shuts off after a few seconds. help
metal cannot absorb the microwaves, the microwaves bounce around inside the oven. Eventually they reflect back to the magnetron, which is the part that produces the microwaves. The magnetron can overheat and be damaged.
Dec 21, 2009 | Panasonic NN-T774SF Microwave Oven
Inverter replaced , Failed gain
The magnetron may also be bad, or if there were any weak or inadequate solder joints on the board, that can cause some pretty spectacular failures.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.microtechfactoryservice.com/mag_test.html
(continuity can be good even though it is bad!)
http://www.microtechfactoryservice.com/diode.html (if it is NOT shorted, it\'s probably fine)
http://www.microtechfactoryservice.com/xformer.html
Good luck.
Nov 10, 2008 | Panasonic NN-H644WF Microwave Oven
Microwave Ovens Logo
114 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
