Question about Dishwashers
My ESL 6115 ssems to be stuck between cycles, it beeps as its finished the cycle, but it still has water in the bottom, and wont accept a new cycle, so not working also the light at the top righthabd side of the door with a sign of an arrow pointing at a straight line is constantly flashing. your help would be greatly appreciated!!
SOURCE: Bosch Dishwasher SHV4313GB/17 Wont switch off !
I had exactly the same problem as clarelou - pump wouldn't switch off - cycle wouldn't stop and machine couldn't be reset. There was an external flood that came into the kitchen so the base of dishwasher had externally filled with water. Took machine out, tipped it back and to the side - water drained out and it then immediately restarted. Bosch couldn't help on their phone-line and wanted to send out an engineer - reckon you've saved me £100+ thanks very much!
Posted on Jun 29, 2008
aborcass
  • 2651 Answers
SOURCE: Fisher and Paykel Dishdrawer beeping constantly
leave it unpluged to stop for now, the machine has detected a leak and is constantly running hte pumps within the drawers to try to remove any water.. problrm is the water detector is in bottom under the lower drawer and htere is no pump to remove that water ..canbge a fickle machine as far as leaks are concerned, but the easy reason is usually misloading of the drawer itself, was an item put in that was too tall , preventing the lid from coming down and sealing off drawer causing water to overflow down the side??? there should be(so logn as no previous repairmen have taken it) a tech/trubleshooing guide taped to teh back wall behind the lower drawer, which is easily removed by unlocking hte hinges on either side of the front of drawer, explained in your manual
Posted on Nov 03, 2008
SOURCE: eco and rapid cycle light flashing rapidly
had something jamming pump impeller which prevented machine pumping water out. The motor is connected by a bayonet fitting to the pumpand is easy to get at and clear obstruction.
Posted on Dec 20, 2009
Testimonial: "problem fixed"
  • 760 Answers
SOURCE: No lights on, didnt complete the drain cycle, stopped working now
There is a thermal fuse located in the control panel inside the door. It could be blown, but if so what caused it. they come with a retrofit pigtail to prevent loose connectins on the fuse. You may have a short somewhere in the dryer, and just blow the fuse again. Could be bad motor,fill valve, or heater, or even the control board. I'd try one fuse first.
Posted on Jul 26, 2010
Testimonial: "yes! that was it! I bypassed it for now and tested it and it works. I will replace the fuse tomorrow. Thank you. you saved me $$$."
SOURCE: Brada dishwasher EF2401 - water in bottom
I just moved in to a new house with brada dishwasher, everytime I used the water leeks from the bottom, can somebody help me to fix it, or do you think I should throw it away and get a new one.
Posted on Aug 08, 2010
Wash Cycle wont kick on
I wish my refrigerator had a wash cycle too- Dude you posted in the wrong section
Nov 29, 2014 | Hoshizaki KM-630M Crescent Cuber Ice Maker
Hoover HFI 3015 integrated dishwasher beeping on each program cycle selected
Check out the micro switch on the door seems to not indicate that the machine is properly closed or your outlet pump is blocked and needs to be cleaned out,cause it is clogged up and cant remove water properly
Jan 06, 2014 | Dishwashers
Repair mr. Coffee pump
Rare for a Mr. Coffee, but it sounds to me like your disc thermostat is stuck open, or a wire has dropped off. They usually stick closed and burn out the thermal cutouts.
Feb 19, 2013 | Mr. Coffee Coffee Makers & Espresso...
Hi, I have an Electrolux ESL 4115. It seems to be stuck on 50 degrees but wont start as usual when I close the door, the on/off button works and lights functioning as normal but that's all. Thanks
I had a similar problem - seemingly stuck or locked with a solid light showing (in my case on the 65 degree wash). Nothing seemed to unlock it. But when I closed it and went away to think about what to do next - some 5 minutes later - it made its end-of-cycle peeps. It now works fine. All I can think of is that I must have interrupted the previous wash cycle l was using before it had ended, and had left the door ajar. all it needed was the door closing for the cycle to finish. Does that help?
Sep 22, 2010 | Electrolux 24 in. ESI6220X Free-standing...
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
Door stuck
try unplugging and plug back in to reset
Nov 17, 2009 | Hotpoint First Edition FEW12 Front Load...
Fishcer and Paykel Dishwaher is continually beeping but not starting the cycle. It has water in from previous part finished cycle when the beeping started
You have a leak. When the bottom sensor detects the wetness, it won't allow to start.
Pull out the tube put some small tower unser the tube to dry out water.
Unplag power cord for 24 hrs to let the sensor dry out.
Then you will be able to start.
However if you don't replace the lid seal the leak will happen everytime a cycle starts and you will have the same problem over and over again. Good luck to fix the lid seal.
Aug 08, 2009 | Fisher and Paykel Dishwashers
Won't finish spin/drain cycle. was beeping and
long drain? remove lower cover on front..3 screws across bottom edge. there is a screw-on cover to a clean out. has a screen in there and may be clogged. prepare for a lot of water..u might lean it back against the wall to limit the mess. clean out is white plastic right up front.
Jun 12, 2009 | Kenmore Elite 45986 Front Load Washer
Dishwasher wont finish cycle
I have experienced this problem before and it turned out to be the main control board in the console. Not a cheap fix, either. The control boards are not serviceable, and can run over $100. Sorry, I hope I was of some help.
Jul 09, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
