Question about Bissell 9200 Upright Vacuum
The suction for my bissell 9200-r model is weak and it stops working. The water suction is very weak and it loses suction funtions after a few seconds or working.. what can i do?
SOURCE: My Bissell Pro-Heat 2x 12
my bissell 9200 won't release water or solution when the trigger is pulled.
Posted on Nov 20, 2008
  • 33 Answers
SOURCE: Bissell ProHeat 2X(9200) hose to cleaner solution no suction
There are a couple areas to check:
1. The black gasket where clearview water collecting unit and the base's front meet. Ensure gasket is in good condition.
2. Check if you're getting sufficient suction: remove the water collecting unit. When you turn on the the unit, you'll feel suction out of a black hose pointing upwards next to the grey dial. If you're not getting sufficient suction you need to check that all the gaskets are seated properly. there are 3 gaskets: (1) an orange one seated between the black hose and the base unit (2 and 3): On the bottom of the unit there is a removeable panel. This panel has a gasket (red) and inside there is a white gasket.
Posted on Jan 25, 2010
SOURCE: bissell powersteamer model 1693 not sucking up water
Ck. the plastic flapper under the Floor Nozzle Window and make sure it is completely closed when the Floor Cleaning/Tools Preheat Dial is in the Floor Cleaning setting. If this flapper is open or partially open, the suction vacuum will draw from the hand tool and not the floor.
Posted on Apr 25, 2010
SOURCE: Bissell Steam Cleaner
my cleaner is not spraying or sucking up the water?
Posted on May 13, 2010
heatman101
  • 43501 Answers
SOURCE: Have a model 9200 that is not dispensing fluid,
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
bnv,nm
Posted on Sep 30, 2010
Bissell carpet shampooer model 9200-9 that is not dispensing cleaning solution
I had the same problem with my Bissell carpet cleaner. I tried all the recommendations but nothing worked. After reading all the blogs, I discovered that many people had the same problem. Fortunately, I still had the receipt from Costco which they honored and gave me a full refund. I was ready to throw it in the trash.
Oct 06, 2015 | Bissell 2X Proheat 9200 rug cleaner
Why won't my Bissell pro heat wont suck up water with the upholstery tool
You may have a valve that switches from floor suction to tool suction. This could be not deployed or stuck.
Nov 09, 2014 | Bissell 2X Proheat 9200 rug cleaner
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
http://www.bissell.com/how-to-videos/
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
May 10, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Jun 30, 2009 | Bissell 9200 Upright Vacuum
My Bissell Model 9200 quit sucking up sprayed solution.
Jun 26, 2009 | Bissell 9200 Upright Vacuum
My Bissell Pro-Heat 2x 12 amps Model 9200-2 The rollers wont turn and the water wont release
Sep 16, 2008 | Bissell 9200 Upright Vacuum
Bissell 9200 Upright Vacuum Logo
75 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
