Question about Lavazza Espresso Point Capsule Machine
The part where you put the capsule in on my Lavazza capsule coffee machine is not working properly. The capsule keeps getting stuck inside. The pieces that form the opening do not look right, but I have tried playing around with them and I can't figure out what is wrong.
  • rachel_abram Sep 04, 2010
    It is not the drawer, it is the opening for the capsules that are not working. I believe it is the pieces that form the opening that are out of place. I can move them around but I do not know how they are supposed to fit together. However, it clearly looks different from the outside.
    It was working fine until yesterday. There is something out place where the capsules go in and I just need to be told how to fix it.
  • 503 Answers
this is usually due to the hinged part of the capsule plate failing to return to the normal resting position after ejecting the first capsule. You can resolve this problem by occasionally pulling the capsule plate out of the unit and running it through the dishwasher. You can also scrub it with a toothbrush under hot soapy water. Coffee stains build up on the mechanism preventing the plate from dropping to the rested position. The second capsule hits this and jams rather than riding the ramp into the puncture plate.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Sep 05, 2010
  • 10,865 Answers
Hi Rachel. Chances are that you need a new capsule. Go to this site to get what you need http://www.espressocartridges.com/index.php?main_page=index&cPath=5
J.
Posted on Sep 04, 2010
  • 3,083 Answers
I could find very little about this problem, but did run across one answer on Sovrana.com that might be of help:
The bottom drawer (where the spent cartridges are collected) is stuck:
The drawer has probably overfilled with cartridges. Part of the very limited maintenance of your Espresso Point should be to empty the refuse drawer daily (or more often if the usage is high) from spent cartridges. If the drawer is jammed, simple jiggle it while gently pulling it out. After a few attempts, the "cartridges" inside will settle and you should be able to completely remove it. Some cartridges may fall out, make sure you remove them before replacing the drawer in its receptacle.
You might try contacting Lavazza's support center to see if they have a solution, or have heard of this problem. Refer to the manual that came with the machine to get their support information.
Good luck, hope this helps, and thanks for using FixYa.
3 Suggested Answers
SOURCE: lavazza coffee machine will not heat up the coffee
For Lavazza A Modo Mio only call 0800 599 9200 -they can help over the phone or if still no solution they will refer you to Lavazza UK who have the answers for AMM.
Posted on Feb 16, 2010
  • 19 Answers
SOURCE: My Lavazza Espresso Point Capsule Machine dispenser dry!
Sounds like you need a pump contact me www.lavazzarepair.com
Posted on Nov 12, 2009
Notice deformation of the capsules ,water also leak to the tray
is it everytime little coffee,or sometimes?
If is everytime -you have to descale the machine,if just sometimes you have to cllean flowmeter,wich is on the back of machine.
May 01, 2015 | Lavazza Espresso Point Capsule Machine
Lavazza 2100
You could avoid this problem by flashing water out without any capsule in. In anycase is a simple problem, you need to disasemble the machine and remove the head shower and wash it from dry coffee liquid which is blocked all the showers holes.
Jun 22, 2012 | Lavazza Espresso Point Capsule Machine
Need a canadian supplier for lavazza espresso point capsules
Lavazza Products may be ordered online in Canada from the following site:
http://www.espressocoffeeitaliano.com/ourproducts.php
Contact Information:
Espresso Coffee Italiano of Canada Ltd.
(authorized distributor of the Lavazza Espresso Point System)
201 Drumlin Circle, Unit #3, Concord, ON
L4K 3E7, Canad
Tel: 905-907-5049
Fax: 905-760-5606
Email: info@espressocoffeeitaliano.com
Dec 13, 2011 | Lavazza Espresso Point Capsule Machine
Lavazza coffee machine will not heat up the coffee
Feb 05, 2010 | Lavazza Espresso Point Capsule Machine
Clogged mchine capsule seems to overheat and melt
It sounds like you have a lavazza blue machine rather than the Espresso Point which is pictured above. In all cases contact me at www.lavazzarepair.com
Oct 11, 2009 | Lavazza Espresso Point Capsule Machine
Cold espresso
it may be the the back fuses not working or the two thermostat are not working good, or the worst possibility can be the electronic card.
Mar 19, 2009 | Lavazza Espresso Point Capsule Machine
Coffee not dripping out of the machine
let it run without coffe tablets, if no water comes out probably the conducts are obstructed, may be calcium in the pipes...do water come out somewere else?...
Jan 08, 2009 | Lavazza Espresso Point Capsule Machine
Can't get a full cup of coffee
First, you should not be using your espresso machine as an american coffee maker. It puts way too much pressure on the components of the machine. The standard cartridges are made to do 1.5 - 3.0 ounces of espresso. should you want to make a longer cup of coffee you need to get the aroma point gran caffe cartridges, lavazza code 427. this will enable you too get the longer cup of coffee without putting the added stress on your machine. Also it sounds like your machine mighy have a problem with the volumetric device. are you getting water in the capsule ejection drawer? should you want service you should call 781-393-2929. we are an authorized lavazza distributor and repair center.
Oct 09, 2008 | Lavazza Espresso Point Capsule Machine
LAVAZZA ESPRESSO POINT CAPSULE MACHINE WON'T GO ON
There are two ten amp small bus fuses in the back of the machine directly next to the iec power cord. Should you need service you can call 781-393-2929. We are an authorized lavazza distributor and repair center.
Jun 19, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso Point Capsule Machine Logo
169 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
