Question about Vector 1 Million Rechargeable Spotlight
How can I charge battery CP660 6V6AH/20HR without the lamp's built in charger?
Where can I get the charger lead for a neata xk06-044-00885? It's for my daughters 6v car. Many thanks
Walmart, target, toys r us and many more carry the power wheels six volt battery. In this world might by cheaper to get a 6volt car battery charger. Radio shack is another place.
Dec 16, 2014 | Motorcycles
My toshiba laptop l505-s5988 is charging not installing power
Can you be able to power up your laptop using charger only? (without battery installed)
If your laptop can't be charged while on, I assume you can only charge it when it's off.
There're 2 possibilities:
1>
Your charger is defective.
It's not a total failure issue, only the built-in chipset is compromised, so you cannot get the correct voltage your laptop needed.
Your laptop will refuse to accept the charger in this condition.
2>
Your battery is defective.
You can find another toshiba l505 charger to rule out this possibility.
Aug 10, 2013 | Toshiba Satellite Computers & Internet
My dcr sr 80 is not charging
Depending on your camera, the battery may be able to be charged on the camera or by using a separate battery charger. Refer to the section below that relates to the charging method you are using.
Charging while the battery is attached to the camera:
  1. Make sure the battery is firmly attached and the AC adapter is securely connected.
  2. If your camera can charge the battery with a USB connection, use the built-in USB cable to connect it to the computer. If you use a USB charger instead of the computer, check the compatibility of the USB charger.
  3. Turn off the camera. The battery is does not charge if the camera is turned on.
Charging using the battery charger:
  1. If the CHARGE lamp does not light or blinks when charging, the terminals may be dirty. Wipe the dust away with a dry cloth and charge the battery again.
  2. Make sure the metal contacts on the battery are free of corrosion.
Dec 28, 2012 | Sony Handycam DCR-SR80 HD Camcorder
We have bought a battery charger HB 1206S DC6V - 12V 6AMP, but it does not state what is the state of charge do the lightes go out when it has reached changed state or light up please help
Product Detail Model No.: HB-1206S
The item is used for charging 6V-12V lead-acid batteries
Max Charging Current: 6A
AC Power Input: 64W
Output: 6/12V DC 3. 52A
Batteries Capacities: 15AHR-80AHR
Unit Packing: Colorful box
Dimension: 18cm x 10cm x 20cm
G. W. / N. W.: 1. 85KG/1. 75KG
Certifications: GS, CE, BS, ROHS, SAA
Main functions:
(1) The HB-1206S battery charger has the features of convenient operations, reliable safety and high performance.
(2) During charging, if turn up overload, the battery charger will keep itself at normal current and normal voltage with its self-automatic protecting function.
(3) If being short circuit, the battery charger will switch off itself, and turn normal after one or two minutes.
(4) The output current of the battery charger is very stationary, so it can protect the battery charger very well. It only costs 3 or 4 hours to fully charge the batteries.
(5) Indication of charging: the battery charger has 6 pilot lamps. The more pilot lamps shining, the less electric quantity is. The charging process finishes when all the pilot lamps go out.
(6) The battery charger can be switched between 6V and 12V, so it can charge for 6V and 12V accumulators. You can select 6V or 12V according to your own needs.
(7)The operations are very convenient: Put the red clip to the positive pole of the accumulator which indicated "+", and put the black clip to the negative pole of the accumulator which indicated "-", then plug in power source, the accumulator will be charged.
Aug 02, 2011 | GPS
What does the flashing red light mean?!?
The flashing red probably means that the charger is working correctly and is indeed charging the batteries. The light should turn green when charging is complete after anything from 1 to 16 hours depending on how this charger works.
Do the following test: Fit the charger with your batteries and connect it to the mains. After 1 hour check if there is a detectable temperature rise in the batteries. You can do this without interrupting the charge cycle by touching the cells with the back of your fingers. If the temperature is still low, let it continue for another 15 hours or so, checking every now & then for any temperature increase. Should the temperature rise more than a few degrees, then stop the charging by removing the charger from the mains. Should the red lamp remain flashing after 16 hours, then I suspect you to have a defective charger.
Dec 27, 2010 | Duracell AAA NiMH Battery Charger with 4...
Anomalous charging behaviour :- a) plug in discharged battery b) starts off with the yellow light flashing as usual c) after a very short time the lamp goes off completely - instead of staying on...
Okay, might not be reading this right but here goes. If the camera shows the batteries as full then I'd go with that. The charger will come on for a few seconds even with a freshly charged battery because it take that long for the charger to realize the battery is already full. You can't feed an already full battery, so the charger is shutting off completely. Yes normally the light would stay on and the charger would continue to trickle a charge into it it until it is removed. In your case I think you have those batteries stuffed to the gills so the charger is shutting right down. One of the problems with these batteries is as much as the manufacturers deny it they form a memory. Best thing to do with these rechargeable batteries is drain them right down and then replace with a freshly recharged battery.
Dec 17, 2010 | Nikon MH18a Battery Charger
I don't know where to get a replacement battery? It shows SEL CB4-6, (6V 4AH/20HR) on the battery itself?
The replacement battery can be purchased from almost any electronic shop, Radio Shack or online at www.batterymart.com/p-6v-4_5ah-sealed-lead-acid-battery.html
Aug 10, 2010 | Vector 1 Million Rechargeable Spotlight
Wh put my battery int he charger provided with the camera, the ligth blinks instead of being a steady light. My battery will not charge. Waht is wrong? Is it my battery or the charger?
If the [CHARGE] lamp flashes red
The battery is faulty or the battery is loaded in the charger
incorrectly. Remove the battery from the charger and check if its
contacts are dirty. If they are, wipe them off with dry cloth and
then reload the battery into the charger. When experiencing
charging problems, also check to make sure that the power cord
is not disconnected [CHARGE] lamp from the power outlet or charger.
If an error still continues to occur after you perform the above
steps, it could mean that the battery is faulty. Contact your
nearest CASIO authorized service center.
I hope this information helps you out and good luck!
Nov 20, 2009 | Casio Exilim EXZ75 Digital Camera
Vector 1 Million Rechargeable Spotlight Logo
567 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Jim London
Jim London
Lawrence Oravetz
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
