Question about eMachines T6524 PC Desktop
Need motherboard wiring connections diagram for Emachines T6524 computer!
4 Suggested Answers
tonys_tiger
  • 791 Answers
SOURCE: I need a W2040 motherboard wiring diagram
must be easier to move the hd to a hd-caseing and start transfer to a another computer......to much time-consuming.
Posted on Mar 27, 2012
  • 20 Answers
SOURCE: need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
Posted on Apr 18, 2008
frankzjm
  • 191 Answers
SOURCE: specs and pictures for a t2865 emachine computer
ok, you may look the motherboard manual:
1) set USB from page 14
2) set the front panel four connectors look from page 12
the manual reference :
http://www.lurkhere.com/~nicefiles/AU31_manual.pdf
hope help you fix it.
Posted on May 18, 2009
T6524 wont power
If it doesn't power on, make sure all the cables within the computer are attached, if it doesn't turn on still after that, the reset/power cables could be in the wrong slot, but if it powered on before this probably isn't the case.
I'd say the power supply could be blown, you may have to replace the power supply, as well as the motherboard possibly. When one goes, the other usually goes as well, but that's not always the case.
Feb 25, 2013 | eMachines T6524 PC Desktop
Mar 27, 2012 | eMachines W Computers & Internet
Emachines T6524 will not reboot, get no signal message on monitor
shut down your computer and remove the side cover and remove the memory from the slot and switch on the computer if you hear beeps switch down the computer and insert the memory if you still hear beeps means the tre is an memory failure you need to change the memory while removing memory you didnt hear any beep it means there is problem with your motherboard remove the processor heat sink and the processor clean the surface then insert the processor to the slot apply a thin level of heatsink compound and fix the heat sink then switch on the computer
Dec 29, 2011 | E-Machines eMachines Desktop PC
Need a smbus controller for an emachines t6524..anyone? thanks so much
Go to this download page HERE. This is for the Radeon Xpress 200 motherboard chipset. Select the motherboard/ IGP catalyst download. When installing it will stop and ask what you want to install. Select southbridge driver.
Apr 16, 2011 | AMD Athlon 64 3500+, 2.2GHz...
Have an e machine t6524 that was rebooting itself now it won't boot up at all. Keeps beeping
Hardware fault. Simple test: if you can boot in the BIOS then the hard disk has died - replace it and reinstall. If you can't the the motherboard has failed - in the end it will be easier and cheaper just to get a new pc.
Oct 11, 2010 | eMachines T6524 PC Desktop
I NEED TO KNOW HOW TO CONNECT THE POWER SUPPLY FOR AN EMACHINES T1120 COMPUTER. CANNOT FIND A SCHEMATICS DIAGRAM ANYWHERE.
After reading an article about Emachines awhile back, I found out the reason you can't find the schematic- it isn't available, as some motherboards are made specifically for Emachines and therefore not distributed, as they might normally be, but again, others are, but you have to identify them and go through another source to get them- Emachines, appartantly, will not supply them. All is not lost, however...all motherboards have, basically, the same hookups and connectors for the power supplies, hard drives, etc.- they are standard. I found a web blog that explains the power switch, reset, and power led, which will help. Here it is: http://www.computing.net/answers/hardware/emachine-power-sitch-wiring/56545.html
This site will explain about the 24 pin connector from the power supply
http://www.tomshardware.com/forum/53750-7-installation-manual-rs480m-w3400-emachine-motherboard
If you google "motherboard wiring" you will find sites that have illustrations of the motherboard, and explain which connectors go to which sockets, and how to identify them.
With a little patience and determination, you should be able to hook everything up from the various blogs on the net. Hope this helps.
Apr 17, 2010 | E-Machines eMachines Desktop PC
Specs and pictures for a t2865 emachine computer
May 15, 2009 | E-Machines eMachines Desktop PC
Emachines T6524 has lost green color in monitor
this is a internal problem with the display. you need repair
Feb 05, 2009 | eMachines T6524 PC Desktop
eMachines T6524  PC Desktop Logo
310 people viewed this question
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
