Question about Frigidaire 24 in. FDBB840DC Stainless Steel Built-in Dishwasher
I have a frigidaire dishwasher. the manual says it is 200,500,700,800 series about 7 years old. yesterday when turned on everything seemed normal except that no water was dispensed. The float seems to work ok. Since we have neer had a problem before with it, it seems puzzling. Is ther an easy way to pinpoint the problem?
  • 15 Answers
SOURCE: Frigidaire FDB740RCS0 Upper Armnot Turning
Make sure the spout leading into the top spray arm is not obstructed at all. Maybe simplistic, but could be overlooked. Just thought I'd put it out there.
Posted on Jan 08, 2009
skrbin
  • 121 Answers
SOURCE: Electrical for dishwasher insallation-missing wires?
black wire is phase,white is 0,you need single phase
pork for this wire if it is on devices.
Posted on Feb 17, 2009
  • 52 Answers
SOURCE: Dishwasher won't wash
pump is likely gone ......without pressure from the pump .the arms will not turn and no water will shoot from the arm jets .....it's kinda like a whirlpool tub that way .....no pump no bubbles ..good luck
Posted on Jul 25, 2009
localwonder
  • 6784 Answers
SOURCE: I have a Frigidaire Gallery Series dishwasher,
HI. this noise will most likely be a damaged pump impeller. It may be loose, cracked,misaligned, or totally separated for the drive stud. The pump is accessible be removing the sump cover and extracting the pump housing. I recommend checking the impeller for damage. replace any failed components that may be visible during the inspection.
CLICK HERE TO ACCESS A COMPLETE PARTS LIST AND PUMP ASSEMBLY DIAGRAM.
Posted on Sep 14, 2009
  • 574 Answers
SOURCE: Frigidaire Dishwasher FDB2810LDC1 not draining
Sure its redeemable if you have the time and money. If I understand you correctly when you move the lowewr spray arm the water drains out? If this is the case then more than likely its a pump motor or solenoid. Reason I say this is on the bottom of the spray arm is a impeller and under that is filter and then pump impeller that drains the water. If its not draining but will by hand then its your pump motor or solenoid. When you start the washer then press cancel/drain do you hear anything? Maybe a humming sound. One more thing could be a thermal fuse for the motor. These are usually not resetable its a one time fuse if it blows you have o buy another one.Hope this helps
Posted on Jan 25, 2010
I have a Frigidaire FDB4315LFBO Dishwasher, about 7 years old. Went to turn it on and everything comes on as usual but you do not hear the water coming on and spraying. Is the water proportioning valve...
Thank you for your post, Dragan!
I understand that your Frigidaire dishwasher is not dispensing water into your tub and everything else is operating properly. This could be an issue with your water valve or control panel. I would recommend making sure your water line is not restricted that could be causing water to not enter the tub. If the water line is in good working condition I would suggest having a professional technician out to perform a diagnosis and repair. This will help you to avoid any unnecessary part purchases. -Matt
Mar 12, 2015 | Frigidaire Dishwashers
Dishwasher does not drain completely
Check your main drain system where your finally connect to let off the dish washer water.
Apr 10, 2010 | Frigidaire 24 in. PLD2850 Built-in...
1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Can't find the model number on Frigidaire dishwasher
The nomenclature should be located on the left side on the inside of the tub right by the front when you open the door. It is most likely an fdb series example fdb1050. however the drain hose pn 154606701 is the factory replacement for most frigidaire dishwashers ten years or less.
Mar 31, 2009 | Frigidaire Professional Series 24 in....
Frigidaire Professional series microwave won't heat
The most likely problem is the magnetron. Check your warranty in owners manual, I believe you have five year warranty on magnetron.
Mar 15, 2009 | Frigidaire FMV156DC Microwave Oven
Frigidaire 24 in. FDBB840DC Stainless Steel Built-in Dishwasher Logo
41 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
