Question about Fedders A7DH45B2A Dehumidifier
Compressor and fan are working but no water extracted in the bucket.
  • Fedders Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on Sep 09, 2010
LD451EGL no water extraction
Apparently, the fans are running, but the compressor has shut down. It could be a failed compressor, or the charge in the system could have leaked out causing the compressor to shut down.
Aug 01, 2014 | LG Electronics Ld451egl 45-Pint...
The 54701 Kenmore Dehumidifier runs and sounds normal, fan running, compressor on. However , it doesnt collect any water whether a hose is connected or just the bucket. No icing up or any weird noise...
Yes, if the compressor needs to be recharged, a service technician can do it.
In the meantime, try lowering the humidity extraction level to 35%. You may have the extraction level set to high.
Hope this helped you. Thanks for choosing FixYa.
Aug 21, 2011 | Kenmore 54701 Dehumidifier
Compressor runs, fan runs, no water in the bucket.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Aug 15, 2011 | Kenmore 54501 Dehumidifier
I have a DH305 it turns on but does not draw any water out of the air. I took the back off and noticed that the fan is not moving. should it be?
The fan, generally only operates when the compressor is running and then for a short period there after. A lot of this depends on which humidity extraction level the humidifier is set on. If it's set high (50%+), it's not going to do much extraction at all. However, if it's set on 32-35%, it's really going to run and extract humidity/moisture. In the case of your unit, which has a mechanical control, rather than electronic control , The control knob should be set on Maximum.
In addition, if you haven't checked and or cleaned the air intake filter recently, please do so. A dirty or clogged air filter will affect the operation of the dehumidifier. Also, place of the unit is very improtant. You must maintain a minimum of 12" clear air space around the entire unit. And be sure to keep it away from heat generating appliances.
In you want to do an in home test to see if it's work properly. Do the following:
1. Place the unit in the bathroom, plug it in, turn it ON and set the humidity extraction level at Maximum.
2. Turn the shower on hot enough to generate steam. Close the window(s) in the bathroom and Do Not turn on the exhaust fan As you exit the bathroom close the door.
3. Wait 15 - 20 minutes before returning to the bathroom and opening the door. Turn the shower OFF and allow the dehumidifier to run an additional 10 minutes. Then check the bucket for any signs of water. If you find some, the unit is working as it should. If you don't find any water, the humidity sensor may have failed or the compressor needs to be recharged with refrigerant gas.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 16, 2011 | Goldstar DH304 Dehumidifier
No water is extracted into bucket. Motor is on - although don't feel any hot air coming out of unit
It may be just the fan motor running and not the compressor. Which, depending on what level you have the humidity extraction set on, may be the problem. If it's set to high, the fan is running to circulate the air. If the humidity sensor picks up a rise in the humidity level (higher than what you have it set on), the compressor will turn ON. Lower the setting to 32 or 35% and if the air intake filter is clean and not clogged, the compressor should turn on shortly thereafter. In addition, be sure to maintain at least 12" of clear air space around the entire unit.
Many times the higher settings are thought to be how much moisture will be extracted. When in fact, the opposite is the case.
May 30, 2011 | Whirlpool AD40USL Dehumidifier
Does not extract moisture from the air. It runs and cycles on and off. I have changed the filter, turned the device off and reset it. Changed the humidity setting. The device is about 4 years old.
Fred, here is an in home test, that will determine whether your unit is working properly or not.
Please the unit in the bathroom, plug it in, turn it ON and set the humidity level at the LOWEST setting. Turn the shower On hot enough to generate steam. Do Not turn the bathroom's exhaust fan ON and make sure any window(s) is closed. As you exit the bathroom, close the door. Wait 15 to 20 minutes before reentering the bathroom. Then turn the shower OFF and allow the unit to run for 5 more minutes. Then, check the water collection bucket for any signs of water. If you find water in it, it's working as it should. It may simply have been a case that the humidity extraction level was originally set to high.
If you found no signs of water in the bucket, the humidity sensor in the unit may have failed or the compressor is low on refrigerant. Either one is repairable, but the cost of troubleshooting it, finding the part and the time repair it, may exceed the cost of a new unit. As, yours is a 4 years old unit.
Hope this helpd you to troubleshoot and solve the problem. Please let me know. Thanks.
May 26, 2011 | Goldstar DH304 Dehumidifier
Fan working but not compressor. Had been making noise when compressor on but now just fan working
heatman101
Oct 06, 2010 | DeLonghi Dehumidifiers
Dehumidifier does not extract water. Fan works and I've cleaned and checked all connections. How do I tell if tis a bad compressor or coil?
It could be a abad compressor, circuit board, or maybe even a sensor or dehumidistat...
Here is a tip about dehumidifiers that run but do not extract water from the air..
heatman101
May 03, 2010 | Whirlpool AD25BBR Dehumidifier
Unit fan is running but the compressor is not.
It could be a bad compressor, circuit board, or maybe even a sensor or dehumidistat...
heatman101
Apr 24, 2010 | Maytag M7DH45B2A Dehumidifier
Ice on coils
The short answer is "yes but maybe not for much longer!"
If the bucket is filling up with water it's probably working OK. Have you selected "continuous" instead of, say 60% ?
If the bucket isn't filling up with water then maybe the intake filter is clogged with fluff, preventing new moist air from getting to the cold coils and being extracted. Or maybe the fan isn't running?
I hope this info will be a useful starting point for you.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge.
If they do not, please add a comment with more details so I can try to help you further.
Cheers, D
Jun 28, 2008 | Goldstar DH504EL Dehumidifier
Fedders A7DH45B2A Dehumidifier Logo
99 people viewed this question
Top Fedders Dehumidifiers Experts
Bill Long
jasbo
jasbo
Albert
Level 1 Expert
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
