When fan is running it is noisy - Heating & Cooling
    President:
  • 1,515 Answers
Hi, normally when a fan motor starts to make noise, this is a warning that the bearings are worn, and the motor will give out after a period of time. Not knowing what kind of set up you have, a central system, or a wall or window unit and the age of the unit, makes it hard to tell you what you can check, so I will guess and give you some ideas you can do. If it is the indoor blower motor, check to see if it has oiler caps on the body of the motor, they will be on top at the front and rear of the motor. You will see these small round chrome or red plastic plugs that can be removed to oil the bearings. If not, it will have sealed bearings and they can't be oiled. If so, you can pick up what is called zoom oiler's at Orchard supply, or other hardware stores that have a telescopic spout that pulls out for long tight spots and give them several shots of oil. If the bearings are not real bad, this will help a lot. If not, you can have the motor checked to see if the windings are weak and the bearings are going and have it changed out, or try and live with this noise until the motor just dies out. If the noise is loud now, you may want to do this now. Hopefully you have oil ports. From what you have said, the motor is noisy, I would say you are loosing the bearings or they are dry and need oil if they are not sealed. Check with a good strong light, and make sure the power is off before you put your hands in there. This oil bottle is only a $1.19. Please don't forget to rate me on this as I know you will be kind to me. I will be here if you need my help if you decide to take this on your self. I can walk you through the process. You can reach me with my user name below. Please keep me posted on this.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Sep 04, 2010
My Haier dehumidifier is really noisy. If we turn it off and restart it, it will run quietly for maybe 4 minutes and then start getting really noisy again. Any ideas what is causing it and what I can do...
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Take care.
Aug 14, 2010 | Haier Dehumidifiers
Noisy chpset fan on MSI KT2 Ultra-ARU
yes, go to Zalman.com and get a cooler if you mobo is out of warranty.
Feb 24, 2010 | MSI KT3 Ultra Motherboard
HP Pavilion dv6449us laptop noisy fan
you may find replacemente in some electronics shops dedicated to laptops spares.
Nov 27, 2009 | HP Pavilion dv6000z Notebook
Fan noisy
Two common factors why CPU fans are noisy:
1. The collected dusts under your fans.
2. Your computer is running over the neutral power that your Power supply can handle, i.e. overclocking, high graphical games and videos.
solutions:
1. clean fans (power supply fans, exhaust and others)
2. replace CPU fans with branded and proven to be quite fans.. it may be an additional cost but proves to be very silent. :)
Nov 05, 2009 | HP Compaq Presario SR2023WM PC Desktop
Exhast fan seems jammed. When you try and run it you get a bad loud hummm like the motor is jammed. The fan had been noisy when running before, so wondering if it was loose before this.
Noisy can indicate a bearing failing and it sounds like it finally siezed. Try spinning the fan by hand and run it again. It might need the bearings lubricated to get a little more life out of it.
Eric
Jun 25, 2009 | Whirlpool GH7145XF Microwave Oven
Very noisy fan
Hi
you need to replace the fan as this will be the cooling fan which cools the oven down. and can not be disconneted .
regards
Mar 21, 2009 | Kenmore Ovens
Noisy fan
I believe your laptop needs to be serviced. if you see dust and fluff, it might damage the fan and would need replacement
Mar 05, 2009 | Acer Aspire 4315-2963 Notebook
Extremely noisy fan!
First turn off your pc, pull out the main cooling fan and clean with with an oil or a wd-40.
Jan 15, 2009 | Computers & Internet
My hp pavilion a6110n product nogg781aa .Has anoisy cooling fan .How do I chang it.
If it's the processor fan that's noisy you can purchase a replacement. The fan and heatsink are normally a complete assembly you can find from many vendors online. This computer has a type AM2 socket; you need to make sure to get a cooling fan for that type. Be sure the replacement will fit into the same space as the original.
If it's the power supply fan thats loud, there may be a couple of possible causes. It may just be a noisy fan, in which case you can replace the power supply. Make sure to get one that has at least the same power rating as the original. Or the fan may be running at its maximum speed. I don't know about this computer in particular, but many computers control the fan speed depending on how hot the processor is (determined by sensors built into the main board). If the fan is running at its top speed, it can be quite noisy. This might be due to a defective power supply or problems with the fan control on the system board
Nov 19, 2008 | Computers & Internet
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
