Question about Mercury P4VM800M7 Motherboard
How can connect sata hdd(500gb) mercury mainboard pvm7???
  • 10 Answers
SOURCE: SATA II HDD instaling on ASUS P5LD2
Drivers will not affect whether the drive shows up in BIOS or not.
Your BIOS should have a setting under the 'Advanced' section for IDE and or SATA. Usually this needs to be set to 'Enhanced' mode or 'SATA plus PATA'  Check your jumper settings-The drive should be set to 'Master' (if it even has jumpers).Check the power lead to make sure the drive spins up. Try different power lead and different SATA cable. If possible, try the drive in another machine to make sure it isn't 'Bad out of the Box'
If the drive does not show up in BIOS its a hardware issue or BIOS setting .
Once it shows up in BIOS - you'll be good to go.
Posted on Oct 31, 2007
RADICALpcs
  • 15 Answers
SOURCE: I can't use HDD sata on mainboard ASUS P5RD1-VM
boot from CD rom hit F6 when prompted and install sata driver. then you should be good 2 go. If your using a sata cd rom, swap it for a a ide during o/s install then reinstall after o/s install is complete also enable sata in bios 1st as well. I had the same board with a pent D 3.0 that clocked to 4.122 with OCZ ram.
great board but old usb 1 sata 1.5 ..
Posted on Feb 23, 2008
jonniewalker
  • 1031 Answers
SOURCE: K8V-MX motherboard+HDD size limit
yes the mother board supports SATA However if you connect large Disks to the SATA connectors they are recognized correctly with full size. So leave your 500g and less HDs on the IDE and the big ones on the SATA. you can check this link for the manual for more information ftp://ftp.chiligreen.com/Desktop/Manuals/manual_a_k8v-mx.pdf hope this helps .thanks and Godbless pls appreciate by rating as fixyaa
Posted on Oct 03, 2008
  • 126 Answers
SOURCE: Want to know Celeron processor 430 works with Mercury PVM7 chipset??
Here is the answer directly from Mercury. The answer is yes if it's a Celeron D processor.
Mercury PVM7 Designed for the latest Intel Pentium D/ Pentium 4/ Celeron D Processors with LGA775 Socket
Posted on Nov 13, 2008
map9966
  • 2351 Answers
SOURCE: Sata Harddisk Not detected in Post operation
Hi vijjis,
Make sure your SATA drive is connected to SATA port 1 which is the bottom port. Double check both the data cable & power cable. The data cable only connects one way at the board & at the drive. Same for the power cable. Your SATA drive must be listed in the bios menu & you must list the SATA drive with-in the boot order. If your cabling is all correct & you still do not see the SATA drive in the bios menu than the onboard SATA controller is defective. This can not be repaired because it is integrated into the board. It will not hurt to clear the cmos. See page 15 in your manual. Your board can only run SATA 1.0 = 150MBs. If your Seagate is pinned for SATA II = 300MBs, change the jumper on the drive. (This may or may not work). See if the bios list the drive.
One other option, you can buy a PCI SATA controller.
Here are a few; http://www.google.com/products?q=Promise+pci+sata+I+controller&btnG=Search+Products&hl=en&show=dd
Link to Mercury P4VM800M7; http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=644#
Good luck vijis!
Thank you for using fixya.
Mike
Posted on Dec 11, 2008
My HDD Seagate Momentus 5400.6 500GB is not recognized by win7. I have connected it like a ex USD HDD, but there is no USB devices in Device manager. The hdd is clicking -1sec click, 0,5sec off. Thanks,...
Hi, it might be a file system error.
You could try removing the hdd from the usb enclosure and connect it directly to your pc via SATA.
(power off both of them before doing so)
If it really is the file system then scan disk should repair it automatically when turning on the pc.
Then if the pc recognizes it you can put it back in the usb enclosure.
Jun 30, 2011 | Seagate Momentus 5400.6 500GB Hard Disk...
I got a new SATA 500gb HDD but the motherboard wont detect it.
Access to your Bios Setup & configure the Bios settings.
Features Setup Page : This page sets up some parameters for peripheral devices connected to the system.
CMOS SETUP UTILITY - Copyright (C) 1985-2003, American Megatrends, Inc.
Features Setup
OnBoard Floppy Controller : Enabled
Serial Port1 Address 3F8/IRQ4 : Enabled
OnBoard IR Port : Disabled
Parallel Port Address : 378
Parrllel Port Mode : ECP
ECP Mode DMA Chnnel : DMA3
Parallel Port IRQ : IRQ7
OnBoard PCI IDE Controller : Both
OnBoard SATA-IDE
: Enabled *(Make sure This is enabled)
Audio Device : Enabled
Modem Device : Auto
Ethernet Device : Enabled
If you have got a SATA III HDD, ie if it is a Western Digital Sata III you need to configure the jumpers to work with your older Sata interface port.(Only Sata 1 & 2 ports on your Mainboard Socket 478). As for Seagate Sata III HDD, the configuration is automatic.
If your 500GD HDD is not detected, try updating the BIOS!
A word of caution "Updating the Bios is not for the Novice" Do it at your own risk. Failure in updating the Bios may render your Mainboard useless.
Hope it helps.
May 14, 2011 | PC Chips M955G Motherboard
What is the hdd capacity that can be connected to mercury pvm7 md
Good day,
There is no limit on the capacity of HHD you can connect to your motherboard.
You just have to ensure that you have enough open SATA or IDE ports to accommodate another HDD.
Hope this helps!
Feel free to let me know if this was useful!
Kind regards
Dec 02, 2010 | Mercury P4VM800M7 Motherboard
Does 206M supports SATA Drives 500GB as well as
Enter BIOS SETUP, and check the "boot order" (after connecting the SATA drive) -- ensure that the SATA drive is *NOT* the *FIRST* boot-device.
Oct 23, 2009 | IBM eServer xSeries 206
It wont start.. what is sata?
You have to make sure first, what is your HDD type? is it IDE or SATA (Serial ATA).
Check it out: http://www.wisegeek.com/what-is-sata-or-serial-ata.htm
You should plug the data cable, to your hard disk. Remember, there's no way to plug your SATA cable to IDE HardDisk because the connector are not the same (I don't know if there's a converter between it).
So, make sure it first. If it IDE, find IDE data Cable, and make sure it plugged to your MainBoard and Hard Disk. Do the same procedure if it is SATA Hard Disk, only this time you should connect the SATA cable from your mainboard to your SATA Hard Disk.
Mar 11, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Can I transfer data from 250GB IDE HDD to a SATA II 500GB HDD
Yes you can. You may have to go in BIOS or and select your SATA as the first drive to boot off of though, else it might try to boot off the old IDE. But once you're in windows, it will appear as another drive in my computer.
Thanks and please take a moment to rate as fixya.
Dec 16, 2008 | ASUS A8N-VM Motherboard
Oct 03, 2008 | ASUS K8V-MX Motherboard
500 GB SATA HDD Not Showing in Windowss 2000 Server Plat form
Reset your Cmos
And go into bios and search for a hidden partition
Sep 23, 2008 | Microsoft Windows 2000 Professional for PC
Want to connect my mercury PVM7 PRO MB
what type of motherboard do have? It sud be on right hand-side you will find some pins. USE MEGNIFYING GLASS THERE BE WRITTEN IN SMALL PRINT connect power LED, HDD LED, RESET SW AND POWER SW
Jul 28, 2008 | Computers & Internet
Mercury P4VM800M7 Motherboard Logo
83 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Alun Cox
vsri9
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
