Question about Ovens
Frigidaire gallery self cleaning convection oven
My oven locked and I cannot get it to unlock. I had broiled something, took out the chicken, and it locked when i shut the door. I got the oven open but now I cannot get it closed because the door is still locked. What do I do?
  • 8 more comments
  • Anonymous May 23, 2008
    tried to self-clean and door locked now stuck what to do?
  • debbie1724 Jul 10, 2008
    I need to know how to operating directions for a convection oven.
  • heybill Jul 27, 2008
    Having the same issue -- self cleaning latch won't release/re-set. Please provide solutions.
  • jazt04 Oct 16, 2008
    I just set the oven to self clean, I quickly opened the door to make sure nothing was inside and the locking mechanism locked in place and I can't close the door. The panel shows locked. Is there something to reset? I tried pushing the cancel several times but to no avail. Tom
  • Anonymous Nov 03, 2008
    door latch won't unlock need sugestions to unlock it, door opens ,but oven don't work how can i unlocked.
    Thanks
  • Anonymous Dec 25, 2008
    Oven door locked and would not release when self clean activated?
  • SarahPerkes Jan 24, 2009
    Well I have the opposite problem. I press the clean mode, and it won't lock at all...I can't figure out what i'm doing wrong... It lets me set the time...and then says "door" but then doesn't lock and then just turns off the clean mode...
  • Anonymous Mar 19, 2009
    my oven locked and will not unlock.. any suggestions on how to release the lock?
  • Anonymous Mar 27, 2009
    what is the normal cycle time for a self cleaning oven,.. mine started at 3hours, is that normal?
  • Laura Gillen Jul 30, 2012
    tried pressing and holding the "clean" button for 5 seconds, Door still locked
Press and hold the "clean" button for 5 seconds.
Posted on Feb 01, 2009
The oven locks when you either deliberately or accidentally hit the self-clean button. It is protecting you from the smoke and extremely high temperature needed to burn off the food drippings turning it to ash. You can turn off the breaker switch for the oven, when you turn it back on, see if the door opens again. If not, wait until the oven cools as it may have a temp control feature to prevents burns and therefore not allow the door to be unlocked until it is cool again.
Posted on Dec 25, 2008
Unlock oven door on model #FGGS3065PF
If the oven display is showing LOC, then the lockout feature was enabled. Press and hold the key pad with the padlock symbol for 3+ seconds. This is just below the Timer On/Off key pad and to the right of the Light key pad. You should see the word DOOR and the padlock icon flash until the door is unlocked and the control panel is released.
If the word DOOR and the padlock icon are lit, then the oven is in the self-clean mode. The lock should release after you cancel the self-cleaning cycle by pressing off and the oven cools down (at least one hour). Unfortunately, sometimes the heat of the self-clean cycle will damage the oven. Either the oven temperature sensor will not give the release signal or the door lock will not disengage. In that case, the oven needs to have the correct part serviced.
The documentation for the Frigidaire FGGS3065PF is available on the product page at Home Depot: https://www.homedepot.com/p/Frigidaire-Gallery-30-in-4-5-cu-ft-Slide-In-Gas-Range-with-Self-Cleaning-Convection-Oven-in-Stainless-FGGS3065PF/204759413 . See page 15 for the Oven Lockout feature. See page 28 for the self-cleaning information.
I hope this helps.
Feb 13, 2018 | Ovens
Why has both top elements stop working at the same time
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Sep 25, 2012 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Gallery oven large element stopped working
Hello -
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
Sep 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a frigidaire gallery wall oven (2003). We set the self cleaning and then canceled. The door is now locked and the fan is running. I tried to reset breaker and it is still locked. How can I get the...
If tripping and turning the circuit breaker off for about 10 minutes does not work, contact Frigidaire. Sounds like the control board and/or door switch will need replacing.
Aug 07, 2012 | Frigidaire 30 in. Electric Gallery Series...
Slow to heat on convection mode, bottom element not get as hot as
Check to see that the convection element is heating. If not, ohm it out, either the element is bad or it is not getting power from the control.
Jun 25, 2010 | Frigidaire 30 in. Electric Gallery Series...
Cannot unlock oven frigidaire electrolux gallery series
hello. this is a common problem. here is a link to provide you with an owner manual which explains how to use the self-clean function
http://www.frigidaire.com/manuals.aspx
and here is a link to speak directly to the folks at frigidaire who will talk you through the solution to your problem
http://www.frigidaire.com/contactus.aspx
let me know how u make out with this as I can offer additional help if needed.
May 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F8 / Convection portion of top oven doesn't work
F8 Oven door lock failure Check lock relay and door switches.
Apr 02, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Hello, what to do is to start another self clean cycle let the unit clean for about 3 minutes then push the cancel button.This should unlock the door if not a tech will have to come to advance the lock motor . good luck
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire self clean electric stove 'f9' message comes on when self cleaning
I had the same problem. All I had to do was clean around the door lock. A small bit of burnt food or something had gotten into the hole around the lock and prevented it from moving all the way into position. Took a tooth pick and 30 seconds of probing to clean it out. Works fine now.
Oct 13, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
2,479 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
