Question about Echo Garden
Pull cord stays out and is not wound back in. Unable to start. Mike Campbell, Sussex
How to change the pull rope
Posted on Sep 04, 2010
25hp pull start cord not retacting spring has been replaced
When fitting any pull start spring, you must first pre wind the spring. Once the spring has been at least 1/2 way wound up or tensioned, wrap the pull rope around the spool. When you assemble it and pull the cord, the spring should wind up further to its fully wound position and now retract as normal. If you don't prewind the spring, there will be little or no tension to rewind the rope.
Sep 25, 2014 | Garden
Procedure for replacing pull cord on my mcCulloch M1255 CLS
The first thing you do is to reattach the pull cord to the pulley. If you are lucky both ends of the spring are where they belong. To test this turn the pulley in the the direction the pulley would turn when the starter cord is pulled and see if you can feel the spring winding up.If you can not you will need to pull out pully out and attach the the spring on one end to the pully and the other end to the case. After that you find a notch in the pulley. Place the cord in the notch and start winding the spring. The cord should not be winding up on the pully.Now take the cord out of the notch and let it wind up on the pulley.If the cord is not fully wound up you repeat the process till the rope is wound up all the way.
Sep 05, 2014 | Garden
Rope needs rewound, got tangled up , had to remove the 4 nuts, now need to get in back on wound tight
I assume that you are speaking of a pull start mechanism.
I can not imagine how to put a put pull starter back on "wound tight". Your pulling on the cord tightens a spring which pulls the cord back in. They go back together with the cord fully wound onto the spool.
Usually, I only take these apart to replace the cord. Wind the new cord onto the spool without handle. Reassemble, then pull out on the cord a little when attaching the handle to the cord. This is the only way to get tension onto the spring at the fully retracted position because the catch for the spring is on the machine and the spring itself is on the underside what you are assembling.
If you do not wish to shorten the cord or replace it, then remove the handle, assemble enough to catch the spring, wind one turn tighter then feed rope through hole and reattach handle. Easier said than done.
If your spring is broken, then you will be needing a new one.
:o)
Jun 03, 2011 | Craftsman Garden
Brake spring recoil will not open
I assume you are speaking of the starter cord return spring. Make sure to turn it CCW to wind it, but leave enough slack so that the spool can turn about four more turns without binding the spring when starting. If the cord broke, the spool may have over-run it's stops--try to to pull the spool outward when trying to wind the spring. Leave the cord off until you get the spring correctly wound. When wound, wedge the spool to prevent it from unwinding. Be sure to melt the cord ends before tying the overhand knot--but leave the outer end alone until the handle is slipped over the cord. Hope some of this helps!
Jul 10, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
How does the spring attach to the pull cord after you get it wound back up?
The outer spring should attach to the cord spool in a recess or post. Wedge it to keep it from unwinding, attach the inner cord end and thread it around the spool until nearly wound. Feed it out of the cord port and pull the cord out which winds the spring some more. Make sure the cord can reach full extension without binding the spring (don't let go of the cord!!), clamp the cord with locking pliers, and fit the handle. Melt the cord ends to prevent the knots from pulling out and be sure the cord turns the engine in a CCW direction when pulled!!! Hope this helps!
Jun 20, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I am trying to replace the cord on my mower, but the cord wont spring back in when I attempt to start it. Please help
the spring below the cord 'spool' must be wound tight before new cord is attached.disconnect cord,wind spool in the direction cord would pull it when starting until it stops & hold it there[spring is wound] release it enough to align & attach cord.release spool & allow it to wind cord onto spool.replace cover.
Oct 11, 2009 | Garden
New lawn boy mower pull cord will not pull. Worked first 2x
Did you check the oil before you ran it. They usually come dry and you have to but oil in before running. Sounds like motor might be blown.
Aug 14, 2009 | Garden
We have a briggs and stratton sovereign petrol mower the pull cord has gone loose no give so unable to start mower
If I'm understanding you correctly, the pull chord is out and will not retract so you can pull again?
If this is so, I'm thinking that there may be some obstruction keeping your spring from returning the rope. The spring is wound like a clock spring. When you pull the rope, the spring wants to bring it back. Sometimes a twig or dirt or other type of abnormality might prevent the spring from retracting your pull rope.
You might need to loosen the engine cover to remove the obstruction.
Jun 27, 2009 | Garden
My pull cord will not spring back properly
pull the cord cover off and check to see there is not to much slack in the cord when fully wound...if there is you can rewind the slack onto the spool...the spring may be broken and needs to be replaced
Mar 08, 2009 | 2005 Honda CG 150 Titan KS
Pull Cord
CHORD STUCK , NOW FIXXED BUT METAL SPRING CAME OUT, WHEN WOUND BACK, HOOW DOES IT ATTATCH TO PLATIC COWL AGAIN?
May 15, 2008 | Euro-Pro PT205 Leaf Blower Powerful 12 AMP...
Garden Logo
159 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
