Question about Microwave Ovens
Getting blower from top to back in over stove microwave
    Genius:
  • 1,554 Answers
If your redesigning the oven then a good dremel cutting tool will do wonders,
just remove the outer casing and see if you can move the port,
use silver tape where necessary to move to air to rear.silver tape will hold up under heat and cold. its in the air conditioning supply section. very expensive for a roll. 25.00
if you can drop the oven a couple of inches then you can steer the air to the rear using this tape and some air dams.
Posted on May 12, 2008
Stove top light on Microwave will not shut off.
There's a relay in the microwave that is not working.
Oct 01, 2014 | Panasonic Genius Prestige Nn-Cd989s -...
Can you put and over-the-counter microwave over a stove?
Yes, that is what they are made for, As long as it has a vent that can be used to vent the smoke from cooking it can be mounted over the stove. Normally the bottom of the microwave should be mounted 16" to 19" above the stove top. The microwave must have a vent with a blower motor in order to be used above a stove top. Most have a thermal switch that will turn the microwave vent on once the temperature reaches a set point.
Jun 12, 2010 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
I have a Roper Microwave mounted over my gas stove
Usually you should have at least 12" - 18" AND a fireproof "Barrier" as the "Roof" of the stove "Floor" of the microwave shelf.
Jan 20, 2010 | Roper MHE14XKB Microwave Oven
Samsung SMV blower installation
Most Microwaves arrive ready to vent back into the room. For filtered air returned to the room it should face toward the front. For top vent, point to the top. for rear wall vent point toward the back.
Jan 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire Microwave Fan won't shut off plmv169dcd
Had the same issue, leave Microwave unplugged for 30 minutes and then plug back in. My fax stopped blowing and now fucntions 100% normal again HI/LO / OFF
Best of Luck!!! :)
Jan 17, 2010 | Frigidaire PLMV169DC Microwave Oven
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Replace vent over stove with microwave & the
So are you saying that the vent hole doesn't line up with the microwave vent hole? I had a similar problem, it didn't matter since most of the new over the stove microwaves can vent back into the house as an option.
Sep 14, 2009 | Microwave Ovens
Does stove-top need downdraft if microwave has oven-hood combo?
We have a stove with no downdraft, and a microwave with a hood above it. It works just fine. I expect you could keep your downdraft and put a microwave without a hood above it, and that would also work. I don't think, however, you can buy an above the range mocrowave oven, that slides in on brackets, which will not have a hood.
Jan 08, 2009 | Microwave Ovens
Blower motor on above stove microwave not running
The dual fan in the back is the vent / exhaust / hood fa. It will run when you turn it on, or if the stove top gets too hot.
The other fan is the magnetron cooling fan, and it will only run when you are cooking. If it is not running, your magnetron can be destroyed.
You can download GE owner's manuals and installation instructions here. That may help you a lot.
Please reply back with more details if this is not yet a FixYa...
Aug 17, 2008 | Microwave Ovens
I HAVE A OVER THE STOVE MICROWAVE MODEL JVM1443BK02 WHEN SOME THING IS IN THE STOVE OR ON TOP AND I GET STEAM , IGET A F3 ON THE PANEL I KNOW IT,S THE SMART BOARD BUT I UNPLUG THE MICROWAVE FOR 10 MINUTES...
First of all, be sure the microwave's hood vent exhaust fan is on whenever you cook on the stove top! That's essential to protecting the controls of the microwave.
If this still happens even though you use the fan, then your keypad or controller is likely failing, and we can help you with our $39.95 nationwide repair service.
Please reply back and let us know how it goes.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 21, 2008 | GE Microwave Ovens
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
