Question about Sharp AR-235 Copier
SHARP-235, F5-02 CALL FOR SERVICE CODE - Sharp AR-235 Copier
Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service u9-99 what dos it mean and how can i
Posted on Oct 26, 2010
  • 26 Answers
F5 02 = Copy lamp lighting abnormality
Details: The copy lamp does not light up.
Check and remedy: Replace the copy lamp unit
Posted on Sep 07, 2010
3 Suggested Answers
  • 22 Answers
SOURCE: ERROR F5-02 call for service
F5-02 = Copy Lamp Lighting Abnormality.
Possibilities are blown copy lamp, failure of lamp harness (cable) or the MCU board.
You may need to replace either the copy lamp unit or the MCU board.
To check the operation of the lamp..
Enter service mode 5-03
#, [interrup],C,[interrupt],5,[copy button],03,[start button].
The lamp should light up for a few seconds.
Hope this helps.
Posted on Jan 19, 2011
dwylie76
  • 80 Answers
SOURCE: SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
The motor lock signal is detected for 6sec
or more after the polygon motor rotates.
The motor lock signal is detected for 1sec
during rotation of the polygon motor.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
Replace the polygon motor.
Replace the MCU PWB.
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Posted on Oct 25, 2011
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
or disconnection
MCU PWB failure
Check
and
remedy
SIM 61-1.
motor
Oct 22, 2011 | Sharp AR-235 Copier
Call for service error code u2-40 on sharp copier AR-M236
That means there is a bad CRUM chip or the developer unit isn't connecting properly.
Aug 20, 2011 | Sharp AR-235 Copier
Code e7-02 sharp Ar m236
Hi.
that erorr is for SHARP AR405 E7-02 Laser unit problemHere an link
service manual here
Feb 13, 2011 | Sharp AR-235 Copier
ERROR F5-02 call for service code AR 235 MODEL
Hope this helps.
Jan 15, 2011 | Sharp AR-235 Copier
I have a sharp ar-235 what does call service code U2-40 mean
CRUM chip communication trouble = the chip on the toner cartridge is faulty.
1, Try to clear the code press P, *, C, *, to enter the service simulation, on the key pad press 1,6, then the copy start, press execute on the screen.
2, Change the toner cartridge.
If it is a brand new one return to supplier as fault, if it is a refilled new one take back to supplier (the CRUM chip serves as a genuine supplies protection for sharp and 'blows' when the toner is empty the re-filler will have to put a new chip on it)
Nov 04, 2010 | Sharp AR-235 Copier
Sharp AR 235, output light
You have to change the Developer in the developing unit. code is: AR271D
This procedure must be done by a copier tech.
Feb 15, 2010 | Sharp AR-235 Copier
How to rest h2 code on sharp ar-235 what is the simulation process now on sharps
Make sure the thermistor is clean and ok then press, P, Interrupt, C, Interrupt. It asks for a code, Enter 14 press print then press Execute on touch screen.
Sep 28, 2009 | Sharp AR-235 Copier
F9-00 (Print Function) Error Code on Sharp AR-287
this copier will display f9-00 if the nework is not connected or the card is bad this means network connection lost usaally resting copier will work if the network is on if not call service
Mar 03, 2009 | Sharp AR-235 Copier
Sharp AR-235 Copier Logo
1,134 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
