Question about Whirlpool LEQ9857L Electric Dryer
Model #leq9508lwd dryer heat will not kick off!!!
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Whirlpool Dryers Model LEQ9508LWD does not start problem I used to be able to start it by wegling conection of the dryer load door and dryer. now it stoped completly
It sounds to me you could have a faulty door micro switch or the door is not aligned properly. When you open & close door the switch should operate so the drum stops when you take things out of dryer.
There will be a little plastic pillar on the door which presses the switch when door closed. Make sure the door isn't warped.
Pete
Nov 06, 2010 | Dryers
Duet Dryer not heating Tumbles but does not heat.
I would suspect a heating element on this model first. Unplug UNIT remove three screws at bottom of toe kick panel and remove unplug heating element check for continuity at terninals of heating element it will be the first two you will see in front
Hope this fixes your concern
Aug 13, 2010 | Whirlpool GEW9250 Electric Dryer
My ge dryer wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
Gas flame will not turn on,
heatman101
Jun 09, 2010 | GE DWXR485GBWW / DWXR485GBCC Gas Dryer
My dryer takes a long time to dry the heater kicks on and off intermittantly
A dryer is supposed to kick on and off intermittently as its dries. The heating circuits are regulated by a thermostat that will turn the element on or off as the cycle progresses. It also works in conjunction with a humidity sensor (if equipped with an "Auto-Dry" feature) to increase or decrease the heat depending upon the moisture level in the drum.
If your dryer is STILL heating, but you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some items to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. Please include your MODEL NUMBER, so I can determine how your dryer is configured. I hope you find this information is helpful.
Jan 13, 2010 | Dryers
Propane dryer. Can hear the heat kick on but dryer doesn't heat
Try looking at the gas regulator. It should have a solenoid that opens and closes. It sounds to me like this is not opening or is only opening partially. I had this same problem on an oven.
May 31, 2009 | Kenmore Dryers
Kicks relay when hot
Make sure the lint trap is clean,and the exhaust is clear. some models have safety switch to stop fire if unit over heats.
May 30, 2009 | Kenmore 64742 Electric Dryer
Heat kick on then off
these are heat cycles,
the click you are hearing is the thermostat turning the element on or off, most dryers try to acheive a temp of 160 - 180 degrees, when reached the element shuts off for a bit to cool down and not scorch your clothes
you do not have to worry about this
May 26, 2009 | Kenmore Dryers
Whirlpool accue temp dryer gets hot then heat shuts off
Sound like you need a new agnitor for your dryer take the model # to order part and install very carfully good luck
May 09, 2009 | Whirlpool LGQ8000JQ Gas Dryer
Whirlpool ultimate care II gold electric dryer
the top and the front has to come off
Feb 04, 2008 | LG DLG2524 Gas Dryer
Whirlpool LEQ9857L Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
