Question about Canon MV430i MC Mini DV Digital Camcorder
Message says that it needs cleaning the head. I used the Panasonic Mini DV digital video head cleaner and the problem dos not go away. What shall I do? Please advice. piers_radnorhills@hotmail.com
    Genius:
  • 1,812 Answers
This is most likely caused by a damaged or misaligned video drum and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 04, 2010
Playback flickering
The most common cause of this is dust, debris or contamination on the heads.
Firstly, it's extremely important that you use only DRY LUBRICANT type DV tapes on the Canon branded camcorders.
Different manufacturers design their heads to be used with either Dry or Wet (coating lubricant type) tapes - NEVER BOTH. Canon is DRY type.
Consumers are led to believe that they should be using well known branded DV tapes, such as Sony. This is fine, if your camcorder is a Sony. However, you should NEVER use Sony tapes in your Canon - Sony tapes are of the WET type.
So, the question is, "Are you currently using Dry or Wet type tapes, or a mixture of both?" If you have used either a WET tape, or a mixture of both in your Canon, then this may have contaminated your heads.
If this is so, then don't panic - simply run a special Head Cleaning cassette (for Dry tapes) in your Canon for no more than 5 secs. Note: your heads are very delicate, so only run the cleaning tapes for a few secs at a time.
Also, try to avoid recording over the cassette too many times, as the quality will sometimes degrade each time.
An example of the Dry tapes are the Panasonic ones (Myself and other Pro Videographers often use Panasonic Prof, Studio or Master Quality tapes, as these are some of the better quality Dry tapes on the market).
As your XL2 is a Pro Camcorder, I recommend you stick with Studio quality (or higher) cassettes.
See this link for Dry DV tapes: http://cgi.ebay.com/Panasonic-mini-DV-digital-video-cassette-AY-DVM63SQ-5pk-/170645949017?pt=US_Camcorder_Tapes_Discs&hash=item27bb4a8a59
or
http://cgi.ebay.com/5-Panasonic-Master-HDV-HD-video-tape-HC9-Mini-DV-/220519311691?pt=US_Camcorder_Tapes_Discs&hash=item3357f9a94b
See this link for Head Cleaner cassette: http://cgi.ebay.com/MiniDV-mini-DV-Panasonic-Head-Cleaner-Cleaning-Tape-/220683036059?pt=US_Camcorder_Tapes_Discs&hash=item3361bbe59b
If the problem still exists after head cleaning, then suspect either a faulty cassette (most likely) or damaged heads requiring service.
Let me know how you get on...
Scott
"If this has helped you, please be kind enough to leave a testimonial"
Jul 09, 2011 | Canon XL2 Mini DV Digital Camcorder
RCA CC9360 MINI DV
Try using a head cleaner cassette. You can get one here:
http://www.high-techproductions.com/panHeadClean.asp
or here:
http://www.amazon.com/PANASONIC-DVM-CLA-Mini-Head-Cleaner/dp/B00006JPWW
It could also be that the particular cassette is dirty. You can also clean the head with a Q-Tip dabbed in isopropyl alcohol. Ensure that you play a cassette only after the alcohol has evaporated, or the tape will get stuck.
Should this solution help you in any way, kindly take a moment to "Accept" this solution..
Thanks,
IrishDruid
Jun 06, 2008 | RCA CC9360 Mini DV Digital Camcorder
The camcorder viewer tells me to clean heads. how do i do it?
go to any store were u can buy a mini dv cleaner.what u need to do is to insert the mini dv cleaner into the camera then turn your camera to playback side then u can now play the tape till it finished
Apr 02, 2011 | Panasonic Palmcorder PV-DV203 Mini DV...
Hi; I keep getting dirty heads message - I run it through with a cassette head cleaner and even try to clean manually with a cotton bud and cassette tape cleaning solution, but after about 20 mins...
Have you changed brands of mini-DV tape? Some are poor and flake off or have a bad binder that clogs up the head. Sony and Panasonic fought it out for years as to whose emulsion binder would win out. Try using a new Canon-approved tape and see if it works. If even that clogs up, sounds like a trip to the shop is necessary.
Mar 22, 2010 | Canon XL1S Mini DV Digital Camcorder
Black lines on playback no playback
hi, if you have stuck the head cleaner in and this has not removed the black lines then the head might either need a thorough clean or may be damaged.
Jul 03, 2008 | Panasonic NV-GS17 Mini DV Digital...
Panasonic DV video camera
using a head cleaner might solve your problem, but dont use it to much, it will wear down your head. if this does not solve the problem you may need a head change. This will have to be done by a technician.
Jun 04, 2008 | Panasonic Palmcorder PV-DV53 Mini DV...
Panasonic Video Camera
Hmmm. Try cleaning the tape heads with a mini dv cassette cleaner and see what happens afterwards. I would also recommend playing the tapes on a different camera and if you get the same response, then your audio is gone forever, but I highly doubt that would be the case.
Apr 27, 2008 | Sony Handycam DCR-HC30E Mini DV Digital...
Panasonic camcorder skips on playback
Try to clean the head by using Head cleaning casatte,if the problem remains same .The head is week .For more information u can call 9448259620
Feb 16, 2008 | Panasonic PV-GS300 Mini DV Digital...
Mosaic picture during playback
either use a manufacturer recommended head cleaning tape or have a tech give it a good hand cleaning. Panasonic head cleaning tapes work well.
Nov 14, 2007 | Panasonic AG-DVX100A Mini DV Digital...
Even after using head cleaner, no playback
SOUNDS LIKE YOUR MAIN BOARD IS GOING OUT. NEED TO SEND IN FOR REPAIR
Feb 01, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Canon MV430i MC Mini DV Digital Camcorder Logo
43 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
