Question about Motorola Mobility PEBL U6 Cellular Phone
Motorola pebl wont turn on
Have a motorola pebl, it wont turn on , i dont know if it is charging, or the battery is dead, or is it locked
  • Anonymous Aug 21, 2008
    Mine does this once every 3 months or so. I charge it overnight and when I look at it in the morning, everything is black. I open it up and hold down the red (disconnect) button for about 5 seconds and it fires up.
Mine does this also. Openit up and hold down the red button for about 5 seconds, mine seems to come to life then. I would think the green button would be a better button to try, but the red one is what fixes mine
Posted on Aug 21, 2008
    Brigadier General:
  • 7,752 Answers
Take it to a reapir store close to you to have it check....try using a new battery and see if it turns on if that does not work then have it check
Posted on May 20, 2008
Phone will not charge or turn on.
I would try a different charger. Possible the charger went dead. If this doesn't resolve the issues its either a bad battery or phone.
May 04, 2011 | Motorola Mobility PEBL U6 Cellular Phone
Almost dead phone
YRAG - take the phone and have the flexcable replaced as well as fully service
inuyasha - the lcd needs replacing
psasho - no, replaced the battery as well as replacing the lcd
Jul 04, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Pebl wont turn on , when plugged in doesnt do anything, doesn't turn on
try changing the battery if that does not work then take it to the nearest repair store and have it check.
May 11, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Low Battery display
no i have not but that is not a problem.
Feb 11, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Battery
you have to get you charging port replaced, take the phone to a mobile service center or mobile technician close to you and have them service it for you.
Jan 26, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Phone does not stay on
Ljbab try changeing the chargeing cabel
Jan 07, 2008 | Motorola Mobility PEBL U6 Cellular Phone
My motorola pebl wont ring but I can play the ringtones manually. Help
Well look on your settings and set your ringing volume to full . check your phone for any settings that may affect your fone ringing . e.g make sure it isnt on silent , Hope i helped
Oct 16, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Doesnt turn on
you can try taking out the battery for a few days then charged the phone up while pressing the power buttom if a result leave it to charge for a while if no result check your charger if is working correctly maybe damge
Sep 07, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Motorola PEBL U6 Cellular Phone
There could be corrosion on the actualy board or something could have been shorted out. Get a new one.
Jul 01, 2007 | Motorola Mobility PEBL U6 Cellular Phone
My phone dosent turn on or nothinq
When the battery is totally depleted, you will need to use a charger that came with the phone. Sometimes it will take a few mintues (give it 10) for the battery/charging circuit to come on.
Sometimes you can charge from other sources than the charger that came with the phone. You generally will need enough charge on the battery to start the phone.
Example: If I have enough battery to where the boots and turns off, I can generally get it to charge from USB or my car adapter. You will need to get the phone to turn on and boot most of the way up before it will take a low current charge. If my phone is so dead it will not even turn on, I must plug it into the AC adapter. Sometimes even then the light does not turn on right away.
The problem is probably due to the number of amps provided by the charger. When the battery is totally dead, the charging circuit is drawing so many amps that it will prevent low amp chargers from being able to do the job. That's why these phones have such heavy duty AC adapters.
Apr 28, 2006 | T-Mobile Sidekick II
Motorola Mobility PEBL U6 Cellular Phone Logo
139 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
